Question about kawasaki 10 Random Orbital Waxer/Polisher"
Polishing bonnet undoes itself and flies off after 20 seconds--tightly attached as well
  • 3,400 Answers
Sounds like bonnet is stretched or oversized. You might try putting duct tape or velcro on the back side of pad to help anchor it in place.
Posted on Mar 12, 2011
Bonnet relese wih no cable at all completeley snapped off not a shred at bonnet end
usually down to a snapped cable usually seized mechanism and it is fairly easy to get the bonnet up, first if you look up under the front of the bonnet you can see the two bolts that hold it in place, then using a ratchet, extension, universal joint and a 13mm socket you can undo the bolts and lift the bonnet enough to then release the catch or cable, it can be a bit tricky to do,Also the cables have a habit of coming off the release handle, if you remove the handle held on by 2x 10mm bolts and see if it is still attached. i am going off a fiat as i do not know what car it is,
Apr 05, 2016 | Cars & Trucks
The bonnet open warning light comes on then it goes off
Faulty switch. More likely found above front crossmember , above grill, (bonnet open) will be a swich, it is probably damaged or is earthing to body metal.
Nov 02, 2013 | Polishing Bonnet 10 In Wool
Can you tell me how to install my release cable & handle on town & country1995
Do you mean bonnet release? If so loosen cable/wire by bonnet catch make sure it's free of any cable ties and clips, and is loose. Also inside vehicle try to remove any type of covering behind bonnet lever/handle, then undo any clips pins or nuts that hold handle in place. If you securely attach some wire or strong string to the end of the cable under the bonnet, and carefully pull it into the vehicle, disconnect old cable attach new, then pull it back into the engine compartment. Your cable should be in place ready for reattaching the lever, and bonnet catch.
Jun 03, 2013 | Cars & Trucks
My shuang ma 9101 will not fly forward
I had the same problem. The problem is to do with the little cog in the back of the helicopter that drives the tail rotor. If you reverse the helicopter it creates downward movement but if you fly forward it creates lift. This lift can actually cause the white plastic gear wheel to also lift and it looses contact with the drive cog itself. Undo the two screws to lift off the black casing, prize off the white plastic cog and file the underside down slightly. When you put it back in place it now sits slightly lower and does not lift too high when you fly the helicopter forward. Hope this helps.
Jan 27, 2012 | Toys
I can't seem to undo Allen head screw which fixes sanding attachments to sanding unit
you might have to use an impact driver on this and also you might want to think that it is a left-hand thread, but I would recommend the impact driver to shock the bolt loose.
Jan 23, 2012 | Tools & Hardware - Others
What are all the attachments for and how do you attach them?
Hi Walker0621,
The attachments are for sanding contours and getting into tight places to sand.
I've located an instruction manual for you. It tells what each attachment is for and how to install them. Go to this website and the pdf document with your instructions will open up: http://servicenet.blackanddecker.com/documents/English/Instruction%20Manual/90532198,MS800.pdf
Hope this helps. If it does, I would appreciate a vote. Thanks,
Handie Andie
Apr 01, 2011 | Black & Decker Mouse Sander/Polisher
Hi. My 06 Vantage which i bought second hand has stone chips on the front bonnet and the vallance on the front of the carr at the very bottom the thin strip is cracked and finaly all four alloy are...
That depends entirely of the hourly wages of the shop. Fixing the bonnet, replacing the skirt and polishing the wheels should take about 15 man hours - find the wage and do the math.
Jun 19, 2010 | Aston Martin V8 Vantage Cars & Trucks
Bonnet wont shut down properly the lever in car staying up on toyota corrolla year 2000?
most likely your hood lock is stuck.what you can do to solve the problem is spray some kind of lubricant/penetrant (wd-40)on the lock itself then try closing the hood.it should unstick.if not,then maybe the return spring came loose and does not let the cable retract.if you are not mechanically inclined,then i suggest you take it to a shop and have it fixed.it's dangerous to drive it like this because your hood could fly open at any time causing you to get into an accident.hope this info helps.take care and good luck, manny
Apr 08, 2010 | 1995 Toyota Celica
My dewalt polisher will doesnt turn on when connected to outlet?
I would check the brushes. These are small carbon blocks that transfer the electricity to the armature and are usually easily accessible from outside the tool. Look for two round disk like caps with a screw slot. Undo the caps and take out the brush and you may find it is worn to the limit.
Sep 03, 2009 | Dewalt Dw849 Electric Auto...
I want to drain the coolant out of my 1998 hyundai excel, where is the radiator ****? And how do I open it?
When you open the hood, right in front, just behind the grille, there should be two long flat metal "boxes". One of them is the airconditioning tank, the other is the radiator. Usually the radiator is the thicker of the two, and should have a metal cap. The aircon tank doesn't.
To drain the Radiator, open the cap, then look for the cooloing hose nearest to the ground, these are usually black hoses about 2 inches in diameter, attached to the engine block by round silver hose clamps, usually the screw type.
Unscrew, or release the clamp of the lowest hose and pull it off, you can use a flat screwdriver to pry it off if it's tight. Now simply let the coolant drain out. Remember to re-attach the hose and secure it tightly before refilling! Hope that helps!
Mar 10, 2009 | 1999 Hyundai Accent
kawasaki 10 Random Orbital Waxer/Polisher" Logo
149 people viewed this question
Top kawasaki Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a kawasaki Tool and Hardware - Other Expert? Answer questions, earn points and help others
