Question about Ovens
Leisure zenith 100 range cooker/oven (all electric) = main oven + the clock has stopped working.rest of the cooker / oven still works
SOURCE: the clock & oven on my cannon chichester cooker dosent work
Hi anyone , my chichester ignition button has stopped working - is there a battery located somewhere
Posted on Mar 10, 2008
SOURCE: leisure rangemaster 55 gas cooker
It sounds exactly the same as I am experiencing on my oven of the same model. My theory is that the full flame gas is controlled by a thermostat, and that this has broken hence why the oven only stays on preheat. This will be a matter of a replacement part. Most likely the thermostat is a bi-metal strip that, because it has heated and cooled so many times in it's life it has simply finally given up. Try searching online for the correct part and get a corgi registered fitter or another suitably qualified fitter to come and replace it.
Posted on Apr 07, 2008
SOURCE: Fisher and Paykel electric cooker (Pepper)
There is a combination of 3 buttons you need to push at once. I believe from left to right it is the second and third button together and then the plus button as well
Posted on Apr 11, 2008
No, it's the first 2 buttons on the left pushed together as well as the + or - to set the right time
Posted on Jul 16, 2009
SOURCE: frigidaire oven won't work. top range works fine, but digital clock and digital display stopped working which works oven, so oven also will not work
my frigidaire oven will not light. The broiler works and the oven ingiter lights up, but the oven will not ingite. The electronic display does work.
Posted on Aug 12, 2010
Can't get the bottom oven working on my Zenith 50 cooker
Is it electric oven? Element gone most likely cause. Does the light and fan still come on?
Sep 05, 2012 | AEG Ovens
My90 duel fuel range master cooker : The two fan ovens and the clock have stopped working but the grill and all hobs are fine !! any solution??
the ovens work through the clock auto contacts if the clock not working then the ovens wont. may need a new clock or you can bypass the timer relay contacts if your clever. one of the oven elements may have blown to earth this is the main reason for a clock failing
Aug 04, 2010 | Ovens
Hi i have inherited a Smeg range cooker when I
Unfortunately, I don't have a solution for you. That's because I have exactly the same problem. Did you ever discover how to fix this problem?
Jul 14, 2010 | Ovens
Location of thermal fuse in leisure cookmaster range cooker
where is the thermal fuse located in a leisure cooker
Jul 22, 2010 | Ovens
The bottom oven on my zanussi zuq 875 has stopped working. No power indications of any kind.Top oven works fine. Followed instructions in manual but no power at all.ie; indicator lights, fan ,oven light....
Have you checked that the timer clock is set and not flashing,because the rest of the cooker will work after power outage but for the main/fan oven to work the clock needs resetting.
Hope this helps.
Jun 13, 2010 | Zanussi Ovens
No gas to lower oven - Cannon Camberley
Hey Stephen - try setting the clock then set the cook period. the oven will only work when that's on i think.
May 07, 2009 | Ovens
Clock on cooker flashing
Just to let you know that i have solved the problem with my cooker, (clock flashing after electric going off) i held down the cook period button and the end time button, then i was able to reset the clock by pressing the +button.
Apr 28, 2009 | Hotpoint UY46 Style Line Stainless Steel...
Delonghi professional dfs903 cooker
have a Delonghi dual fuel DTC90DF range.
The oven has been temperamental for a whil, working then clicking off so that you had to turn it on again and it would work for a while again. Eventually there was a bit of smoke coming through the hob and it smelt of electrical burning and stopped working all together. It is the main fan oven that is now not working.
Please help
Bev
Jan 03, 2008 | Ovens
My oven has completely stopped working
hi there as long as your supply to the cooker is ok the problem can only be one of two things the mains terminal block burnt out or the overheat cutout has blown at the back of the cooker
Nov 30, 2007 | Hotpoint UY46 Style Line Stainless Steel...
Ovens Logo
166 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
