Air cond comes up with error code H6.no other activity. The compressor/fan is not working.
  • 1 more comment
  • rod_hucker Mar 13, 2011
    HI tuned007,
    I have identified the error code as being 'No feedback from indoor motor'.
    does this chnage your prposed solution?
    Thx Rod
    okeydoke,I'll organise a pro and let you know outcome.Thx
    Happy to do that once I get the pro in to look at it, which is Wed am our time. cheers rod
  • 2,382 Answers
Hi, the H6 error code means Outdoor Compressor motor position detection sensor error which needs an inverter tester to check it and probably replace it.
Posted on Mar 13, 2011
  • 1 more comment
  • Tunde Autos
    Tunde Autos Mar 13, 2011
    No, it does not change my proposed solution....
  • Tunde Autos
  • Tunde Autos
    Hi, don't forget to accept and rate my solution........
    Thanks for using FixYa
    Genius:
  • 1,157 Answers
Hi rod_hucker,
Just to add, H6 is an Outdoor Compressor motor position detection sensor error. You need an Inverter tester to check this error. You could also try this link for the manual, may not work but just give it a try.
Manual link
--> you need to create an account to be able to download the manual.
Hope it helps.
Thank you for using FixYa.
Posted on Mar 14, 2011
    Sergeant:
    Novelist:
  • 196 Answers
Your compressor position detection sensor is faulty. You'll need an engineer to sort it sorry.
Error code h6 my ac split electrulux?
H6 indoor unit fan stall.
Most likely a faulty fan motor but could be a faulty controller board. My money is on the fan motor which is a DC motor.
Apr 24, 2014 | Electrolux E23CS75SS Air Conditioner
Daikin error code H6 Outdoor Compressor motor position detection sensor error
sir
daikin inverter air conditioner we are replace the indoor pcb then next it gone out door pcb,next we are replaced outdoor pcb also then compressor not working oftre last we are replaced compressor then it will be giving H6 ERROR CODE please give me suggestion
Feb 16, 2011 | Heating & Cooling
Hi, my mistral (MPAC50 just started coming up with an error code E5. it wont go into airconditing mode and only uses the fan
E5 Outdoor activation of compressor over heatprotection or motor lock
Compressor overheated due to condenser block or fan motor lock. Clean condenser/replace out door fan capacitor.
Dec 30, 2010 | Heating & Cooling
Fujitsu inverter air cond. Just stopped working properly. Model outdoor AOT30PMAL indoor unit AST30PBA-W. Code oper. Red led flashes fast continously green led (timer) repeats 13 slow flashes. After power...
It sounds like your inverter is at fault. You will need an inverter tester ( most good service techs will have one ) to prove that the output to the compressor is correct. If the inverter is okay then it will be the compressor at fault with a location error or it is simply seized. A common fault that caused this was the eev remained closed (coil failure ) and caused the compressor to over heat.
May 11, 2010 | Heating & Cooling
ERROR CODE 5 FLASHES CARRIER SPLIT SYST. AIR COND. 42G250HP-1
5 flashing is ' compressor drive' and check the high pressure, condenser fan motor capacitor for proper running
Mar 10, 2010 | Carrier Heating & Cooling
Kenmore room air cond fan runs, no cool. checked
if the fan motor is on but the compressor is not : if the compressor has correct voltage up to the terminals and is not operating, the compressor is bad, if ther is not power to the terminals, the start components may be the culprit, if there is no power to the start componenets then the controller is the issue.
Jul 18, 2009 | Kenmore 75123 Wall/Window Air Conditioner
Air cond dash light works, compressor doesn't go on.
AC's have a low freon switch that shuts off the system to protect the compressor in the advent that you have a freon leak have the system checked for a leak
May 28, 2009 | 1996 Toyota Camry
'96 cadillac deville has no air.cond./heat
Unfortunately for you ( i had the same problem) The A/C compressor HAS to be in working order on these cars or else all heck breaks out with the climate control.
If it's a nice car, get a new compressor installed. If it's borderline- get rid of the car.
I paid 2200 to Cadillac to fix the A/C and climate control only to have the transmission fail in my '93.
I dumped the car soon thereafter....
May 27, 2009 | 1996 Cadillac DeVille
Heating & Cooling Logo
581 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
