Question about Zanussi TC7114W Electric Dryer
My tumble dryer has not worked since I bought it over a year ago. It switches on then goes off again
    President:
  • 3,074 Answers
Http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Posted on Mar 12, 2011
I have a defy autodry tumble dryer - about 5 years old. In good working order, but a few days ago when I pushed the on/off switch in to put the tumble dryer on, it went all the way in. It still works...
I have not personally seen one but in most cases with washers and dryers, access at the rear, removing a few screws might loosen the top from the back panel and that might allow the top to be pry open. The top is usually held in place with clips rather than screws...same as door panel in cars are held flush against the body of the car with clips. I would try removing the top by way of the back. Just a guess.
Feb 08, 2015 | Dryers
My tumble dryer is blowing cold air only. I had a new thermostat put in between 1 and 2 years ago, so hoping it's not that and something else. Can you help me please?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Mar 21, 2011 | Hotpoint Dryers
I have a tumble dryer.
Sounds as if the door switch is the problem. This is normally a safety switch that stops the dryer when the door is opened.
Unplug the dryer.
Remove the door switch and check the switch condition with a continuity meter after removing the wires. Try turning the switch on and off....the meter should read power on and off when you do that.
You may have to remove the front of the dryer to get to the door switch.
Good luck,
I hope this helps
Oct 05, 2009 | Hotpoint Dryers
Dryer won't heat. I just replaced the felt seals on the drum, the door switch didn't work but after I unplugged it & reconnected it worked. Could it be the doorswitch? I replaced the high temp switch a...
A tumble dryer that isn't heating up at all needs checking with a continuity test meter. The most common cause is a heating element failure, or t.o.c's going open circuit. It depends on which make and model of tumble dryer you have as to how easy it is to get to the relevant parts. Some tumble dryers have heating elements that are easily accessible by removing the back panel, and can be tested for continuity or checked for obvious breakage. Others though have their heating elements inside, which aren't accessible without stripping the dryer down. Tumble dryer heating elements are always protected by thermal fuses which are usually simple devices with 2 wires connected. They can be tested for continuity with a test meter
or
If power is getting to the tumble dryer and the socket is definitely OK, then the most common problem with tumble dryers not working is when the door micro switch fails, or the catch on the door that operates the switch either breaks or no longer activates the door switch. Check for broken door catches. There is usually a plastic peg on the door that pushes through a hole in the tumble dryer's casing where the door catch is. Closing the door should operate a simple micro switch. If the plastic peg is broken or bent it might not operate the switch properly
Jul 19, 2009 | Hotpoint NVL333GY Gas Dryer
Dryer will not heat
check heating element,,,and thermister
Jul 06, 2009 | GE DPSR610GGWT Dryer
Already bought a Frigidaire Gallery Dryer about 2 years ago.
kinda if its not spinning, it will over heat and shut down on high limit
Jul 02, 2009 | Dryers
Frigidaire front load won't tumble
do the 2 wire go to the door switch?mike
Sep 12, 2008 | Frigidaire GLEQ642A Electric Dryer
Model 11060052991 kenmore elite dryer
For heat issue I had replaced the heat relay switch a year ago and that worked. For the start button holding issue I replaced the motor relay switch and the dryer is fine again.
Nov 25, 2007 | Kenmore 63942 Dryer
CIC60 01 tumble dryer only works if on/off button is held in
is the new on/off switch new or second hand if its new get it exchange cause these switchs have a spring in them with 2 channel cutouts in them once depressed when it starts to come back up it automatically goes into another channel which keeps it on faulty switch thats all it can be if secondhand again take it back cause its faulty this is the only thing it can be they are simply made so they dont mess up try doing it when its not on the washer love peter
Nov 16, 2007 | Dryers
Zanussi TC7114W Electric Dryer Logo
116 people viewed this question
Top Zanussi Dryers Experts
Tim Whalen
Are you a Zanussi Dryer Expert? Answer questions, earn points and help others
