Question about Acer Aspire One PC Notebook
NOTE BOOK SCREEN DOES NOT COME ON - Acer Aspire One PC Notebook
    Scholar:
  • 115 Answers
Screen does not come ON or not showing any display even the power LED is lit. Sometimes it is due to the laptop was not shutdown properly or the battery was drained or laptop was left idle. This is a simple solution that may fix the problem. If the power LED is lit, turn off the NB, remove all the power sources (battery and charger). Without the power sources, hold the power button for 10 secs and put the power sources back and turn ON the laptop. If this doesn't resolve the problem, it needs to be checked for possible Motherboard problem.
Hope it works!
Posted on Mar 12, 2011
My acer one note book wont come on power turns on screen stays off and no other lite like wifi or anything comes on just power lite screen off nuthing eles just power
Try the following..
- remove battery and power on the note book with power cable.
-if issue not solved ... check if you have access to memory card and reset it.
Jan 27, 2018 | Acer Computers & Internet
My kobo is frozen on starting sync won't turn on or off
Note: If your Kobo device has been physically damaged, it is no longer covered by Kobo's limited warranty. On a Kobo eReader, a physically damaged screen will look like it's been shattered, or you may see vertical or horizontal lines on the screen with a frozen image. If you haven't dropped or damaged your Kobo eReader, but are experiencing issues, try the steps below in the order suggested.
  • Turn your eReader off and then on again.
  • If your screen is frozen, slide the power button to the right and hold it for 10 seconds. Your eReader should turn off.
  • Turn your eReader off and charge it for at least four hours. Note: Your computer should be turned on while you are charging your Kobo eReader.
  • If your eReader isn't charging, try using a different Micro USB cable or a different USB port on your computer. Note: If your eReader's battery is completely drained it can take up to 15 minutes before it reacts to being plugged into power.
  • If you're having trouble while reading a book on your Kobo Aura H2O, Kobo Aura, Kobo Aura HD, Kobo Glo, or Kobo Mini: tap the centre of the screen to bring up the Reading Menu, tap the > Home icon to return to your Home screen, then open your book again.
  • If you're having trouble while reading a book on your Kobo Touch: press the Home button and open your book again.
  • Try a basic reset.
  • If you're still having issues, consider a factory reset.
  • If you're unable to reset your device, please contact Kobo Customer Care
Mar 14, 2015 | Kobo 6" eReader Touch Edition
How to fix white screen on note book 8
If you have a white screen then you most likely have a display failure. Plug your laptop into an external monitor to see if it is the computer or the screen.
Apr 13, 2013 | Computers & Internet
When i turn the page on the sony ready touch I can still see the last page under the next page. Has this happened to anyone else?
Hi patsyhodgins!
At certain point this "goshting" you see its normal operation because of the type of screen (E-Ink) but if you get words mixed or its too difficul to read, you can try a reset:
Note: This will not affect your ebooks:
1. Disconnect the reader from the computer
2. Power off you reader
3. Hit the reset at the bottom for 3 seconds
4. Power on you reader
5. The screen will blink and will display "Opening Book", let the reader load your books
See if the problem persist, if so, you can try a hard reset, make sure the reader is fully charged.
Note: This will delete all content from you reader, I recommend you to back uo your data before proceed:
1. Power off the Reader.
2. Press the RESET button.
3. Power ON the Reader.
4. When the screen shows "Opening book..." , press and hold at the same time the "Page Back" button and the Volume + at the bottom until the "Reset All" appears on the screen
If none of the steps above work, then contact Sony to get the screen repaired.
GoodLuck!
eBookBoy
http://digialreader.freeforums.org
Jul 17, 2011 | Sony Reader Touch PRS-600
My acer note book charges but screen wont come on
1. It may be the ram sticks are not secure or seated properly.
2. It may be that the luminous tube that give the LCD it light has failed. In any instance you will need to have your laptop serviced by a tech. There could also be a bad inverter. This may be on the motherboard itself if so then a mother board needs replacement.
May 01, 2010 | Acer Aspire 3680 Laptop
I have a DELL LATITUDE D610 note book i need a
LCD screens are available on the Internet - here are some WEB sites that sell LCD screens :-
www.lcdparts.net
http://www.yallstore.com
http://www.shope2.com/
Dec 20, 2009 | Dell Latitude D600 Notebook
COMPAQ PRESCERIO C 702 TU NOTE BOOK- NO SOUND
Before installing the audio drivers please install the UAA drivers first. Then restart the computer and install the remaining drivers. Carefully follow on-screen instructions, if any, during the installation.
UAA Driver
ftp://ftp.hp.com/pub/softpaq/sp32501-33000/sp32646.exe
Audio Driver
http://ftp.hp.com/pub/softpaq/sp36001-36500/sp36090.exe
Modem Driver
http://ftp.hp.com/pub/softpaq/sp36001-36500/sp36089.exe
Wireless Lan Driver
ftp://ftp.hp.com/pub/softpaq/sp34001-34500/sp34152.exe
Synaptics Touchpad Driver
ftp://ftp.hp.com/pub/softpaq/sp35001-35500/sp35444.exe
Intel Chipset Drivers
http://downloadmirror.intel.com/13799/eng/ChipUtil.exe
Ricoh 5-in-1 Card Reader Drivers
ftp://ftp.hp.com/pub/softpaq/sp33501-34000/sp33604.exe
Dec 07, 2008 | HP Compaq Presario V2000 Notebook
Sanyo Projector & NEC Note Book Incompatible.
You have to select I think it is function F8 or Function something to show or activate dual display function. Go to help menu in the computer and that may help you in this matter. Let me know if this helps. Thank you Jay
Jan 29, 2008 | Office Equipment & Supplies
Acer Aspire One  PC Notebook Logo
59 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
