Question about Panasonic Televison & Video
Tv stopped turning on. The TV is getting power, however it just stopped turning on. A repaip shop did not tell me what was wrong with the TV they just said it would cost 350 dollars to fix.
  • 1,591 Answers
Since you provided no make or model, here's the generic response that most likely is your issue.
There's a good chance you have failing electrolytic capacitors either in the power section or the inverter section or both.
Any caps in these sections that look bulged at the top, or bulged/leaking at the bottom need to be replaced.
If you repeatedly turn it on, eventually it'll probably turn on, but every time you turn it off, the TV will get harder and harder to start up until one day it just won't.
Sometimes you have to do the opposite to start it up and unplug it for 5 mins, then try.
If you are handy with a soldering iron and can identify the power supply and inverter / FM section for the backlights, an inexpensive handful of capacitors will likely fix you right up.
Match the capacitance on the capacitors. Go over voltage if you can, and still have them fit.
IE - it's not a bad idea to replace a 10V cap with a 16V or 25V or even a 50V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are positive it's only doing ripple filtering).
Most of the caps that go are 10V 1000uF or 3300uF.
I found some great videos of the procedure (for different brand, but same issue) on youtube.
http://www.youtube.com/watch?v=Mm51C_RDIZE
http://www.youtube.com/watch?v=BNHHrgX_6cs&feature=related
http://www.youtube.com/watch?v=8l0AUj8QUkg&NR=1&feature=fvwp
http://www.youtube.com/watch?v=Y7b_nTaZYcU&feature=related
As you can see, this issue spans plasma TVs, as well as large and small LCD TVs and monitors.
The parts are cheap, and skill required is minimal.
Posted on Mar 12, 2011
My Philips TV turns on and back off instantly. If you know what could be wrong let me know please. Thank you.
Hate to tell you this but mine did the same thing,took it to a shop,said it would cost way more than it's worth,I let them keep it.
Oct 31, 2016 | Philips Televison & Video
Samsung TV not turning ON. My email address is prk Please help... Much appreciated.
Its power supply I will tell you how to fix you need to get few things first
Jan 29, 2016 | Samsung Televison & Video
Blinks red 7 times
Your TV is experiencing high voltage and shutting down immediately. It could be the power supply or circuits.
Please see the following link for Sony Bravia Diagnostic Codes.
http://monitor.espec.ws/files/sony_blink_codes_203.pdf
Aug 18, 2017 | Sony KDL60EX700 60 in. TV
Green power light comes on, the turns right back off. No picture. Please help
I'm not sure what TV model you have. But, thing I can tell you is the most common problem.
Most of the time with flat panel TVs, the power supply for the screen fails. And the TV normally turns itself off to protect other parts in the TV from being damaged. Basically " Protection Mode".
You can try leaving the TV unplugged for 30 minutes so the TV can reset itself; then try again turning it on. If it doesn't work after that, it's time for the TV repair shop.
May 21, 2009 | Sanyo Televison & Video
42 plasma panasonic
DUDEEE this exact same problem happened to me!!!! what happened was it was workin fine then it started turning on and off, then now it goes through these weird phases where i cant turn it off using remote or the power button. every button on the side of the tv and the remote doesnt work. so i have to unplug it to turn it off, what a messedup problem!!! im taking my LG 32LB9D to the tv shop tomorrow i hope to get it assest and possibly fix, ill tell u how to solve the problem if my tv is fixed. :)
Oct 19, 2008 | Televison & Video
NEC Plasma
thats bs, stop calling nec, there are plenty of repibuble repair shops who have or can get aftermarket part
Oct 12, 2007 | NEC PlasmaSync PX-61XM3A 61 in. HDTV-Ready...
Power problems
Something wrong with the power switch? Does it stop if you press any buttons on the TV (including the power button)?
Aug 17, 2007 | JVC AV-32D305 32" TV
Tv not getting ON
You have a short somewhere in your set.Either the power supply or the high voltage circuit. The noise is the power supply telling you that it's over loaded. You need to take it to the shop and get an estimate of repairs. Stargazer
Feb 05, 2007 | LG 30FZ1DC 30" TV
Televison & Video Logo
57 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
