I have a netgear cg814wg wireless cable modem isp cox. the modem was purchased from ebay and it has comcast written on the side. i plugged it into the coaxial and it transmits but my laptop (windows vista) picks it up as limited on ipv6. i chatted with cox and they said it would not work. i want to make it work. help.
  • 1,591 Answers
If cox says it won't work on their system, there's nothing you can do to legally make that unit work. There may even be no physical way to make it work if it's simply using different frequencies or protocols than COX uses.
If you want cable internet from COX, you will have to call them and have them install it. Chances are they won't even charge you for the cable box, or it will be a very small monthly fee - and your internet usage will be on top of that.
Posted on Mar 12, 2011
How to connect hp officejet 4620 to my netgear cg814wg v2
First connect it via USB to a computer and set it up so it works over the cable.
Then re-install it to be wireless, putting in the router requirements.
Then under instructions unplug the router.
It should then be set up to run wirelessly.
Jan 13, 2014 | NetGear CG814WG 54 MBPS WIRELESS CABLE...
I cant get internet from my rouder
Wired or wireless? Shut down the computer. Unplug the NetGear. Unplug the ISP modem, remove battery, if applicable, Check ALL cables and connections, reseat ALL connections. plug in the ISP modem, wait for selftest. Plug in the NetGear, wait for selftest. Reboot the computer. Try connecting with a Ethernet cable if you are trying to connect wirelessly to verify. If that fails, contact your ISP to verify signal comming in. Have a ISP tech come out to analyze the signal.
Jan 06, 2013 | NetGear Computers & Internet
Wifi freeze
IF WHILE SURFING THE NET THE PAGES ARE TAKE TOO LONG TO LOAD THERE ARE IS SOME POSSIBLE ISSUES:
1-A MAL WARE OR VIRUS
2-YOUR ISP CONNECTION IS POOR OR LOW
3-OR YOUR SYSTEM IS NOT CONFIGURE TO LOAD PAGES AT A REASONABLE SPEED.
Apr 21, 2012 | NetGear CG814WG 54 MBPS WIRELESS CABLE...
I am trying to install a netgear cg814wg wireless router manually. I am going to http://192.168.1 but its aking for username and password. I have tried admin for the username and 1234 and password for the...
You can try resetting your netgear router to default settings. the reset is button located on the rear panel of your gateway to reset all settings to their factory defaults.
Here's the router default configurations settings:
User login URL: http://192.168.1.1
User name (case sensitive): admin or superuser
Login Password (case sensitive): password
You can also check and download your router manual & user guides here:
http://documentation.netgear.com/cg814wgv3/enu/202-10297-01/pdfs/FullManual.pdf
Good luck,
Ryan
May 26, 2011 | NetGear CG814M Wireless Cable Modem...
I need to open 6 gaming ports to access Xbox 360 live. How do I do this
here is a complete guide to doing it here
http://portforward.com/english/routers/port_forwarding/Netgear/CG814WG/Xbox_Live_360.htm
Feb 20, 2011 | NetGear CG814WG 54 MBPS WIRELESS CABLE...
I have netgear wireless N-300 router. Linksys cable modem. Arius phone modem ( comcast trip play). Netgear not reconizing ethernet connection. My connection is yellow ethernet cable to linksys, grey...
If you mean phone modem on PC then no. Check connection between pc and router by acessing the webinterface (instuctions in linksys user manual).
If all OK there then contact your ISP.
Sep 03, 2010 | Computers & Internet
Can not complet setup for Linksys wireless G
You must be using the cable type of isp i guess like comcast,cox or cable vision, Try this Take power cable out from modem and router-
Now PLUG OUT THE CABLE OF POWER TO YOUR MODEM WAIT FOR 2 MINTS. DONT DO ANY THING B4 2MINTS. NOW connect the power cable of router - Hope it may get work- Else try open IE page - type 192.168.1.1 - Press enter - admin is password
leave username blank
Click Mac address clone- Enable- Clone my pc's mac-save settings. Click Wireless - W/l n/w mode mixed - network name - user defined - Channel 6 SSID broadcast - Enabled- Save setings, Click on wireless security on the top under sub tabs of wireless select the wpa security type - make security of your own.
Now do
PLUG OUT THE CABLE OF POWER TO YOUR MODEM WAIT FOR 2 MINTS. DONT DO ANY THING B4 2MINTS. NOW connect the power cable of router.
Mar 30, 2010 | Linksys Wireless-G WRT54G Router
In need of drivers for netgear cg814wg v.2 please!!!
Hey buddy, this is a plug and play modem gateway and does not require drivers for its configuration. If this modem was provided to you by your ISP then please contact them for its configuration as these modems are ISP specific like Timewarner, comcast, cox. If not, then let me know so that I can assist you further.
Oct 11, 2009 | NetGear CG814M Wireless Cable Modem...
Replace netgear CG814WG with WGR614 Possibile???
CG814 and WGR614 both are wireless modem, with 4 LAN port.
the difference is CG814 use so call "stateful" packet inspection, where WGR614 is using NAT, which is less secured, and easily attacked.
both have spam filer, and you can set restriction as to what website or content of the website.
CG814 should cost more than the WGR814. you should ask the resaller for the difference.
Feb 08, 2009 | NetGear CG814M (pn-3201155) Modem
Is my modem a WiFi router?
This RCA DCM 425 is a cable modem only its not even a router, its just a plain cable modem that is being provided by some cable company like Cox and Comcast, try searching again for a different box there they have a brnad name of Linksys, Netgear or Dlink because those are the common manufacturer of wireless router ...
Hope that helps............
Sep 18, 2008 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Computers & Internet Logo
162 people viewed this question
David Payne
David Payne
