Question about Kitchen Ranges
My Digidoor twenty four double garage door is malfunctioning. When activating a remote control, the door only go up for about 30cm and then gets stuck. Afterwards go up and down from the ground to about 30cm until one deactivates the door manually. When opening the door manually the wheels slides all the way opening normally.
  • kgopotso Mar 12, 2011
    Hi There
    should i disamntle the the motor fromt the top? Where do i lubricate the system ? along the chain rail?
    Mr Caroldon
    I looked at the rails and it seems that the chain that rotates back and forth one end of the chain is not attached to anything, with a visible hole at its tip (which i think was suppposed to hook up to the rest of the chain). Before it gets stuck one chain will be moving forward and the other one backwards and then the end of the chain stalls half way. Is this how the chain mechanism works?
Sir when was ur last tym to service it coz normaly after a year..i had same problem as yours bt i fixed my one by oiling the chain it was dry thats why the motor was strugglin to pull i hope u wil get luck thank u
Posted on Oct 24, 2013
  • 10,865 Answers
Hello kgo.. Sometimes these door motors do need a wee bit of tweeking. That said, I would adjust the up pressure a bit so that it goes up as it should. The adjustments are on the motor unit and generally only require a screw driver to make the adjustment.
Be sure to make wee adjustments and then test the door. Joe
Thanks for choosing Fixya!
Posted on Mar 12, 2011
  • Kitchen Ranges Master
  • 17,130 Answers
The fault which is indicated is purely a mechanical one and it needs the assistance of an overhauling of the motor drives,gears and links to the door.
When deactivated the door is disengaged and so moves freely but when the motor as it is activated find the friction of the drive too much which is making it fall short of even opening the door.
Remove the motor from the assembly and manually check the position of the friction. It can also be related to poor bearings , bushes or lubrication. Also check the power of the motor, check the voltage to the motor and also the bearings on the motor.
If you are mechanically minded this can be sorted out easily bu checking the free movement of the drives.
  • Donald DCruz
    Donald DCruz Mar 12, 2011
    As mentioned since you are able to see the first observation , removal of the link to the motor will be enough to manually check the mechanism for free movement. So please see if you are able to do this at first to confirm that it is problem of the mechanism jamming.
  • Donald DCruz
Who do I contact for Digidoor repairs and maintenance in the Lydenburg area?
only link for digidoors repair
one company
use "contact us " their web page
to get the nearest authorized repairer of didgi doors to the lydenburg region
DigiDoor Garage Door Motors Installations Repairs of DigiDoor 1000N...
Oct 14, 2016 | Building Materials
How do I get a free service manual for digidoor 24 garage door opener
Your first problem is you bought a digidoor garage door opener. But check their website, or call the manufacture. You will either be able to download the manual or have to buy a one directly.
Mar 28, 2015 | Building Materials
How to re programme my Digidoor III garage door motor?
Did you check it engages the end switches?
Oct 07, 2014 | Building Materials
Digidoor remote
"Another reason is problems with the radio frequency of the remote control system used, some older systems use frequencies that are liable to interference from various sources such as police and fire department radios and military communications. The effects of this interference are many for example, the garage door may open and close on its own or the operating range of your remote control may become so poor you cannot open or close the door with your remote control even whilst standing next to it."
source
Jul 29, 2013 | Audio Players & Recorders
How do i programme a digi key remote to my digidoor II garage motor, my original fell and no i bought new digi key remote. plz help
How to program a digi-key remote control :
- on the wall console press the light toggle button to switch the light off.
- press and hold the light toggle button, the light will come on and after 5 seconds go off.
- release the button and the light will go on again.
- within 30 seconds press the required key on the digi-e key transmitter (your remote control). The light on the digidoor ac/dc will go off.
- to confirm press again the same button the transmitter (remote), the light on the digidoor ac/dc will flash foor times. Done
Apr 22, 2011 | Audio Players & Recorders
I bought a second hand Digidoor 1 with garage door. The door opens and closes perfectly when the digidoor is off. When I power up the digidoor the motor will not open the garage door when the door is...
You are receiving interference from the digi door. You will have to return this unit and go with a different one on a different frequency. Chamberlain makes a clicker that would work well with that unit. Thanks BB
Sep 21, 2010 | liftmaster Chamberlain Garage Door Opener...
I have a digidoor 2 automatic garage door and it closes in stages not in one motion. The problem started when I stopped the closing motion half way down by remote control to let someone in. Up until then...
It sounds like your obstacle setting might be set too low and the friction of the door is causing the motor to stop. There are two white alan key adjustments on the side of the motor that can be adjusted to change these settings for the up and down sensitivity. If this does not solve your problem contact the Digidoor technical helpline on 2711 4749060, they will be able to assist you.
Aug 24, 2010 | Kitchen Ranges
Kitchen Ranges Logo
542 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
