Question about Nokia E63 Cell Phone
When i plug in my standard 3.5mm headphones into my Nokia E73, it comes up with enhancement not supported in a pop-up. it never used to do this. ive tried changing the settings but this doesnt work. how do i fix this?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 116 Answers
It could be a problem with the headphones or the phone connector pins itself. To summarize,
1. Clean the phone connector area & headphone connector
2. Try the 3.5 mm headphones with another phone
3. Try another 3.5 mm headphone with your E63.
If it's the phone problem perhaps the best way would be to go for nokia care shop.
Posted on Mar 12, 2011
Want to buy earphones. What connection on the lead is needed to connect to system?
You may need to use an adapter to connect the mini stereo plug if the front panel PHONES connector is standard size.
Mar 16, 2015 | Pioneer Audio Players & Recorders
My Skullcandy smoking buds headphones not supporting my nokia x5. it says enhancement not supported. what should i do to make them work for nokia x5 ?
I got the same problem with my skullcandy
on my nokia x 5 -01
If you did manage to find a solution , please mail me and help me out chow1923@yahoo.co.in
Aug 22, 2011 | Nokia Skullcandy Version 2.5 Backphones -...
My nokia 5200 radio does not work
Your enhancement may not inserted properly, enhancement used as antenna. so insert the enhancement(eg: headphone) properly. if you done the same but then aslo there is same problem Then do restore factory setting, else go for Software update, your phone os may crupted.
Apr 09, 2011 | Nokia 5200 Cellular Phone
When i insert the headphone it shows enhancement not supported
some of headphonens are not suitable for ur device so use authorized headphones like
and Go to Tools>settings>enhancement>headphones>set as default
Mar 08, 2011 | Nokia E63 Cell Phone
I need the red/white speaker cords with a pin on other end to hook up bose speakers on my computer
Does a regular 3,5mm headphone plug plugs in? if yes, you can use the standard cable found in every electronics store. If it is smaller, an adapter could be needed. that adapter is as easy to find. Explain the case to Electronic store salesman, or better, show them to him/her.
Aug 31, 2009 | Boston Acoustics BA735 Computer Speakers
No sound through headphones
the pop port on your phone may be dirty or broken
Apr 01, 2009 | Nokia 6300 Cell Phone
Enhancement not supported??
It is either Software or Hardware - both solutions below... best of luck
SOFTWARE
Just in case this setting got mixed up, go to menu - tools - settings - general - enhancement - and make sure your default is set to "Headset". If it is already set to "Headset" then it may be a hardware issue...
HARDWARE
The Nokia detects a 2.5mm jack when inserted and defaults to the standard headset mode (sound comes out through the headset but uses the phone speaker). There could be 2 causes to this (1) short in the headset jack or (2) debris in the headset jack that is making a connection between the contacts.
I recommend that you use a "can of air" sprayed directly in the jack to clear any debris. If this does not work, plug in the phone/headset jack that came with it and ensure that it detects it.
If that does not work, it is a short and you should return it or, if it is out of warranty, get someone skilled to replace or disable the jack (only do this is you have no other option -- Nokia won't touch it after you open and solder it).
Feb 09, 2009 | Nokia N73 Cellular Phone
the technical supported is incomplete, return it with the warranty of were did you buy because it is an incomplete system of your cellphone you better ask it...
regards JAN_yuanjia rate it plsss
Nov 15, 2008 | Nokia 6288 Cellular Phone
Shows headphones on when they not connected so cannot hear calls or ring and hear people unless headphones are plugged in need help please
buddy
try out one thing reset your phone once by using this code, *#7780#,it will ask your password, put it will delete all your phone stuff the contact and the messages before doing this transferr all your matter to memo card.
it will help you.Best Of Luck.
Thanx
Do vote if this solution works for you.
Jan 04, 2008 | Nokia N70 Cellular Phone
N70 headphones
Go to.
Menu/Tools/Settings/Enhancement/Enhancement in use/
Change setting to Headset.
Nokia E63 Cell Phone Logo
327 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
