Question about Brother P-Touch 1180 Label Printer
White line through print on label
My p-touch which is relatively new, I am using red ink cartridge clear backgrou,d suddenly began prinintg with a white line through the red letters. What a waste of expensive materials. Can anyone tell me what's wrong? I've tried four times now, and it makes the white line through the red letters horizontally all the way across each time. So furstrating. Matchine about 6 months old, Used about 10 times.
thanks for any help
  • 114 Answers
Use a q-tip dipped in alcohol to clean the printhead.
Lou
Posted on Aug 10, 2008
HP A636 will not print yellow; tricolor cartridge is new
  • Align the print cartridge.
The printer automatically aligns the print cartridge after a new one is installed. You can also align the print cartridge at other times to ensure optimal print quality. Indications that you need to align the print cartridge manually include borderless prints with white space
along an edge, colors not printing satisfactorily, or poor print quality.
To align the print cartridge from the printer
  1. Load a sheet of HP Advanced Photo Paper in the input tray.
  2. Touch the Setup icon to display the Setup menu. For more information, see "Setup Menu" on page 16.
  3. Touch Cartridge.
  4. Touch Align Cartridge and follow the prompts.
Clean the print cartridge automatically.
If the printed pages are missing lines or dots or contain ink streaks, the print cartridge might be low on ink or need to be cleaned.
CAUTION: Clean the print cartridge only when necessary.
Unnecessary cleaning wastes ink and shortens the life of the cartridge.
  • Clean the cartridge.
Follow these steps to clean the cartridge automatically:
To clean the print cartridge from the printer,
  1. Touch the Setup icon to display the Setup menu. For more information, see "Setup Menu" on page 16.
  2. Touch Cartridge.
  3. Touch Clean Cartridge and follow the prompts.
If the documents are still missing lines or dots after cleaning, replace the print cartridge.
Attaching User Manual (see page 59).
http://h10032.www1.hp.com/ctg/Manual/c01518966.pdf
Feb 18, 2014 | HP Photosmart A636 Compact Photo Printer
How do i change the ink cartridges for the photosmart 7960
Make sure the printer is ON.
2. Open the print-carriage access door by lifting from the front center of the device, until the door locks into place.
The print carriage moves to the far right side of the printer.
3. Wait until the print carriage is idle and silent, and then lightly press down on a print cartridge to release it. If you are replacing the tri-color print cartridge, remove the print cartridge from the slot on the left. If you are replacing the black or photo print cartridge, remove the print cartridge from the slot on the right.
4. Pull the print cartridge toward you out of its slot.
5. If you are removing the black print cartridge in order to install the photo print cartridge, store the black print cartridge in the print cartridge protector. For more information, see Use the print cartridge protector. If you are removing the print cartridge because it is low or out of ink, recycle the print cartridge. The HP Inkjet Supplies Recycling Program is available in many countries/regions, and lets you recycle used print cartridges free of charge.
6. Remove the new print cartridge from its packaging and, being careful to touch only the black plastic, gently remove the plastic tape by using the pink pull tab.
7. Slide the new print cartridge forward into the empty slot. Push the print cartridge forward until it clicks into place.
If the print cartridge you are installing has a white triangle on its label, slide the print cartridge into the slot on the left. The label for the slot is green with a solid white triangle. If the print cartridge you are installing has a white square or a white pentagon on its label, slide the print cartridge into the slot on the right. The label for the slot is black with a solid white square and a solid white pentagon.
8. Close the print-carriage access door.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Jan 15, 2013 | Office Equipment & Supplies
My printer goes through the motion of printing but the paper comes out blank. I've an hp deskjet d2360 and there is ink in it
Possibility cartridge print head dry.
Solution 1:
Do a clean process
cartridge automatically. Press START - Control Panel - Printers and Faxes - HP Deskjet d2360 right click and select Printing Preferences - Select the Color tab - select Printer Services - select Clean cartridge, wait for the cleaning process is completed - Perform Test print. If the print test results, has good graphics, press Finish. If the graph is not clear or drop out, repeat the cleaning process once again.
Solution 2:
1. Open the cover printer, cartridges will move to the middle position.
2. Remove the cartridge (be careful, do not touch the element cartridges or print head by hand), then stick the tip cartridge (print head) to clean water
3. Then, attach the print head to a tissue paper. If there is a tissue paper used in ink (black cartridges, black block lines, and color cartridges, three color red yellow blue lines), means the flow of ink to the print head is normal. If the
tissue paper no trace of ink, attach back into the water, repeat the above process.
4. After process is complete no.3, clean the cartridges with a tissue paper (careful, do not touch the element cartridges or print head by hand, because it will damage the cartridge). After cartridge clear of the water, insert the cartridges into printer.
Sep 24, 2011 | Office Equipment & Supplies
How to change the ink cartridge
Checking the ink levels
  1. Open the HP Director .
  2. Click Settings , point to Print Settings , and then click Printer Toolbox .
  3. After the Printer Toolbox opens, click the Estimated Ink Level tab.
  4. For information on obtaining replacement cartridges, click Print Cartridge Ordering Information .
Replacing the print cartridges
  1. Make sure the HP all-in-one is on. WARNING: If the HP all-in-one is off when the print-carriage access door is lifted to access the print cartridges, the HP all-in-one will not release the cartridges for changing. Damage may occur to the HP all-in-one if the print cartridges are not docked safely on the right side when you try to remove them.
  2. Open the print-carriage access door by lifting from the front center of the device, until the door locks into place. The print carriage is on the far right side of the HP all-in-one. c00228292.jpg 1 - Print carriage access door 2 - Print carriage
  3. When the print carriage is idle and silent, press down on the end of each cartridge to snap it out of the carriage. If replacing the tri-color print cartridge, remove the print cartridge from the slot on the left. If replacing the black or photo cartridge, remove the print cartridge from the slot on the right. c00228293.jpg 1 - Print cartridge slot for the tri-color print cartridge 2 - Print cartridge slot for the black and photo print
  4. Gently pull the print cartridge toward you, out of its slot.
  5. If removing the black print cartridge to install the photo or gray photo print cartridge, store the black print cartridge in the print cartridge protector.
  6. Remove the new print cartridge from its packaging and, being careful to touch only the black plastic, gently remove the plastic tape by using the pink pull tab. CAUTION: Do not touch the copper-colored contacts or ink nozzles. Touching these parts can result in clogs, ink failure, and bad electrical connections. c00228294.jpg 1 - Copper-colored contacts 2 - Plastic tape with pink pull tab (must be removed before installing) 3 - Ink nozzles under tape c00228295.jpg
  7. Slide the new print cartridge forward into the empty slot. Push the print cartridge forward until it clicks into place. If the print cartridge you are installing has a white triangle on its label, slide the print cartridge into the slot on the left. The label for the slot is green with a solid white triangle on it. If the print cartridge you are installing has a white square or a white pentagon on its label, slide the print cartridge into the slot on the right. The label for the slot is black with a solid white square and a solid white pentagon on it. c00228296.jpg
Jan 21, 2011 | HP OfficeJet 6210 All-In-One InkJet...
How to load the ink cartridge
Jan 14, 2011 | HP OfficeJet 6210 All-In-One InkJet...
HP 7780 suddenly stopped printing in red. I have changed the cartridges several times. I am using brand new HP cartridges. Have cleaned the print heads, aligned several times, nothing has heled. The...
Hi Good day!!!
Maybe your print head is clooged (red)
Then most about 98% are more likely to be an ink clog which just needs to be unclogged using something like print head cleaning solution
Basically, if a print head has been left unused for some time... moisture inside the ink begins to evaporate and instead of liquid ink, a thick inky jelly begins to form inside the print head.
When this occurs white lines appear in prints and most people not realizing the problem, will replace their inks... But when that does not work. Some assume they have an electrical fault, and replace their print head, others will replace their printer !
But provided there is no obvious print head damage? In 98% of cases it simply needs a little patience and print head cleaning solution injecting directly into the print head to dissolve the dried ink trapped inside. This will dissolve the clog and allow your expensive ink to flow once again. Most will then print as new.
Thank you for using fixya
Jan 03, 2011 | HP Office Equipment & Supplies
My prints are red with lines Why
Cleaning an ink-jet printer can solve minor problems, maintain print quality, and prolong periods between professional cleanings. Thin white lines across printouts indicate that the ink nozzles need to be cleaned.
  1. p 1 Collect the supplies you need: a soft cloth and cleaning fluid made for plastic. (Water is fine in most cases.)
  2. Step 2 Check the printer manual. If the manufacturer has provided specific instructions, follow them.
  3. Step 3 Turn off the printer.
  4. Step 4 Dampen the cloth with water or cleaning fluid.
  5. Step 5 Wipe the outside of the printer, making sure that no fluid gets inside.
  6. Cleaning Cartridges or Ink Nozzles
  7. Step 1 Use the cleaning buttons on your printer if it has them.
  8. Step 2 Initiate cleaning through the printer software.
  9. Step 3 Open the printer software by double-clicking on a printer icon or opening a document and then selecting Print from the File menu.
  10. Step 4 Click a button labeled Options, Troubleshooting, Clean Print Cartridges, Toolbox, Printer Utilities or something similar. (This varies by manufacturer.)
  11. Step 5 Click a button labeled Head Cleaning, Run Nozzle Check, Clean Print Cartridges or something similar to begin the process.
  12. Step 6 Follow the instructions on your screen.
  13. Step 7 Repeat the cleaning process if the results aren't satisfactory.
  14. Step 8 Go to your printer manufacturer's Web site for detailed instructions on manual cartridge cleaning and interior cleaning.
Nov 15, 2009 | Epson Stylus Photo R300 InkJet Printer
Ptouch weak printing
You need to take a q-tip dipped in alcohol and clean the printhead. Let me know if this helps.
Lou
Sep 09, 2008 | Brother P-Touch 1180 Label Printer
BROTHER P-TOUCH 1100
My Brother p-touch 1100 is feeding the white tape through but not printing black ink on it.  It has a new cartridge.  Can anyone help please?
Jun 19, 2008 | Brother P-Touch (PT1100SBVP) Label...
How do i change an ink cartridge on a HP PSC 1510 printer
To replace the print cartridges
1. Make sure the HP All-in-One is on.
Caution If the HP All-in-One is off when you lift the print-carriage access
door to access the print cartridges, the HP All-in-One will not release the
cartridges for changing. You might damage the HP All-in-One if the print
them.
2. Make sure the paper tray is down and there is letter or A4 unused plain white
paper loaded in the paper tray.
3. Open the print-carriage access door by lowering the door.
The print carriage moves to the far right side of the HP All-in-One.
4. Wait until the print carriage is idle and silent, and then, using your thumb, lightly press down on a print cartridge to release it.
5. Pull the print cartridge toward you out of its slot.in-One
6. If you are removing the black print cartridge in order to install the photo print
7. Remove the new print cartridge from its packaging and, being careful to touch
8. Slide the new print cartridge forward at a slight upward angle into the empty slot.
Using your index finger, push the print cartridge forward until it clicks into place.
white triangle.
its label, slide the print cartridge into the slot on the right. The label for the slot is black with a solid white square and a solid white pentagon.your HP All-in-One
9. Close the print-carriage access door.
If you are installing a new print cartridge, the HP All-in-One begins to print a print cartridge alignment sheet.
10. Load the print cartridge alignment sheet on the right front corner of the glass with the top of the page to the right.
11. Press the Start Scan button.
The HP All-in-One aligns the print cartridges.
Good Luck.
Apr 10, 2008 | Office Equipment & Supplies
Brother P-Touch 1180 Label Printer Logo
62 people viewed this question
CheckitRight
CheckitRight
Soulvisitor
Soulvisitor
Ron Dufek
Ron Dufek
