Question about Daewoo DSA-122L Air Conditioner
FAULT CODE E3 What does that mean? on a DAYTEK
Model wf361. What is causing e3 error?
e3. Drive motor tach fault. This means that the tachometer is not regitering any motor movement when it should. Main reasons for samsung: motor control board fault. Tachometer fault. Motor fault. Also check wireing from motor control board to motor. But this issue is not common at all with samsung.
Feb 15, 2016 | Samsung Washing Machines
What does the E3 code mean on the 540 model and is there a fix?
Troubleshooting the "E3" error code in Maytag MAH6700 ...
fixitnow.com/.../troubleshooting-the-e3-error-code-in-maytag-mah6700-...
Feb 20, 2011 - These codes in your (made-by-Samsung) Maytag washer might pop up during the ... In fact, the E3 error code means that the Machine Control wants to make the motor spin but won't do it because it's getting a weird reading from the tachometer.... MAH6700 and MAH8700 models (they use the same motor).
I have a samsung frontload washing machine. A code E3 is ...
www.shopyourway.com > Denise LaGrasse > Questions
Mar 15, 2014 - My samsung front loader is not working. do not no what E3 means. ...code F26 mean on a Kenmore Elite model 110.4708 washing machine?
How To Fix 3E Error Code On A Samsung Washing Machine
www.appliancerepairlesson.com/.../how-to-fix-3e-error-code-on-a-samsu...
May 15, 2015 - Samsung uses the 3E error code to indicate a drive motor tach fault. ...If you're handy, you can fix your Samsung front load washing machine error code ....My samsung frontload washer shows e3 and the drum does not turn ...
Jan 06, 2016 | Washing Machines
What is error code E3 on Wristech wrist blood pressure monitor Model HL 168ZA
The E3 Fault Code means Error in determining measurement data. In which case, measure again. If this continues to happen contact HoMedics Customer Service @ 800-466-3342.
http://blog.suntechmed.com/blog/23-abpm/310-top-5-reasons-your-automated-bp-monitor-gave-an-error-code
Feb 25, 2015 | Health & Beauty
Kenwood diswasher kdw243a/a e3 fault code?
e3 means there was a longer heating time but not reaching required temperature could be a malfunction of temperature sensor or of heating element. E3 is a temperature error. There are two theromstats, 90 degrees and 78 degrees. I suggest you to call the competent person to substitute either of these thermostats.
Jun 05, 2011 | Dishwashers
What does the code E3 mean?
Apr 08, 2011 | Walgreens By HoMedics Automatic Wrist...
I have a Daytek air conditioner and it is giving the following error message E3 What is the problem and how do I fix it thank you
E-3 means indoor motor mechanism locked or no power to motor.Check& rectify motor and PCB.
Jan 11, 2011 | Heating & Cooling
I have a Daytek 12000BTU airconditioner that is displaying an error E3. What is this error and what spares can i buy to repair this problem.
E-3 means indoor fan motor malfunctioning. You can check by manually rotating motor, if hard, Check for bearings and replace it or replace fan motor.Is it helpful?
Jan 06, 2011 | Heating & Cooling
We are getting error code E3. What does this mean
Looks like you have either a stuck drum (does not spin) or an electrical fault that make the washer think the drum is not moving.
From a 2006 Technical Bulletin:
E3: Machine control is attempting to drive the motor but is not seeing any tach response. Visual Check shows motor is not moving. (Locked or Hall Sensor fault.)
Specifically, it could be:
1. Spin drum stuck – Verify that the spinner moves freely to eliminate this cause.
2. Hall Sensor (integral part of motor) fails or is loose – When the Hall Sensor fails or becomes dislodged, the control doesn't recognize that the motor is spinning and shuts down. The result will likely be an “E3” code in the worst case, or “SUdS” if it is only getting a partial rpm reading. Check wire harness connector(s) to motor.
Unless you are really overloading your machine you likely have an electrical fault, or a failure in the drive train--especially if the problem is intermittent. Probably time to call in a technician.
Aug 13, 2009 | Maytag Neptune MAH9700 Front Load Washer
Bosch washer error code e3 what does it mean?
Error "E3" on a Bosch front loader means there is a problem with the door. Either it is not closed properly (user error or a blockage) or the locking mechanism has a fault. Check to see that there is no object shoved in the latch hole (our 2yo just did that) preventing the door from closing properly. If it is not that, a technician is advised. I tried to get into the machine to fix out issue but could not get to where the issue is.
Aug 02, 2008 | Bosch Washing Machines
Kenwood dishwasher kdw243a
kdw243a code E3 what doesthis mean. ??? pleae.. adres Poland,,,,,, e_mail wiesiekwro@poczta.fm
Dec 14, 2007 | Kenmore Dishwashers
Daewoo DSA-122L Air Conditioner Logo
131 people viewed this question
Top Daewoo Heating & Cooling Experts
Tim Whalen
armandog07
armandog07
Steve
Are you a Daewoo Heating and Cooling Expert? Answer questions, earn points and help others
