Question about Bosch Washing Machines
My machine wont rinse or drain - Bosch Washing Machines
    Brigadier General:
  • 6,277 Answers
Some Bosch washers will not compIete cycles if water is still in the drum I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
Here are my complete, general pre-typed guidance notes for checking filters and motors ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 12, 2011
Washing machine wont drain,rinse,spin,water wont drain out start a cycle but seems not to rinse,spin,drain
Could be a failed lid switch. This is a safety switch that shuts the machine off during cycles.
May 19, 2016 | Washing Machines
Rinses light flashing fast and wont drain drum and finish wash
Try checking the filter for a blockage or pump being jammed with a button , disconnect drain hose at sink hold a few feet off ground over a bucket should pump/ flow quite freely if not then check filter and pump. good luck
Oct 13, 2014 | Miele Novotronic Premier 500 Front Load...
Why is the machine Not rinsing and spinning?
something is blocking it from draining so it wont spin and it wont rinse because it wont spin
Jun 10, 2014 | Brandt WFH1176 Front Load Washer
Whirlpool AWM1019 wahing machine - what does AH code mean on display. Will do all the right things but wont move on ie wash and drain but then wont rinse. On start of any programme starts to fill then AH...
Hi! I checked both the inlet pipe and the rinse drain pipe. Both are fine. What next. The machine gets to 26 and then starts beeping. It is driving me absolutely crazy!!
Jan 23, 2011 | Whirlpool Washing Machines
Machine wont drain
check for faulty water pump or a blockage to the water pump see if you can here a hum when it is time for the machine to drain
NEVER OPEN MACHINE CASE WHILST STILL CONNECTED TO MAIN POWER SUPPLY
Jan 18, 2010 | Tecnik TKL9260 Front Load Washer
My kenmore 80 top load series wont rinse top load wont rinse
drain pump is trying to drain. maybe have something in pump
Jun 22, 2009 | Washing Machines
Rinse cycle wont fill
check your drain hose. needs to be at hieght of tub before entering the drain....should only be 3-4 inches in the drain and secured with a ziptie.
Jun 08, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Wont drain, wont empty, wont go onto rinse, drain or spin during
The filter on this machine is behind the flat at bottom right of machine. Tilt machine back before unscrewing to avoid spillage. If filter is clear get back to me and will explore other possibilities.
Nov 16, 2008 | Washing Machines
Wont drain
Sounds like you have a bad lid switch.I would need additional info on the unit,make,model etc.
Nov 21, 2007 | Indesit W 123 Front Load Washer
Washing Machines Logo
19 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
