Question about Whirlpool Home
Hello, I have a ARMXXL 129 washing machine.
Hello, I have a ARMXXL 129 washing machine. after i push the start buton the first led that indicate the program and the lock led are solid coulor but the machine is not starting the program. if i will wait more than 15 min all the leds starting to blink but the wash machine still not functionning and the only way to stop the blinking is to unplug it. i checked the evacutation, all the alimentations cables..its everyhing ok. can you help me please? thank you by advance
  • 4234 Answers
SOURCE: kv27fS100 - LED BLINKS 15/16 TIMES FIRST AND THEN 2 TIMES CONTINUOUSLY
The initial blinking is normal. The two blinks are the key and indicate an over current condition detected. This can be a problem in any of the circuits. Since the set initially performs as expected and the blinks show up after a little while suggests that the problem is in the high voltage circuit. If you are comfortable working inside the set, check the horizontal output transistor for a shorted condition. That is the most common failure. If you must see a servicer, expect a parts cost in the $25 range. Add in the local labor rate for the total repair cost.
Dan
Posted on Jun 27, 2008
  • 9 Answers
SOURCE: wash cycle will not start door locked led flashes
sound like water has been splashed over circuit
board. dry out and replace any damaged components.
Posted on Mar 15, 2009
SOURCE: Indesit WIDL 106 wont start -ON/OFF-Door Led Flashes rapidly
It is a defectiv controller pcb. I think the eeprom on the controller pcb lost its program (happens often on Indesit machines).
The only solution I know is to change the controller pcb, - not a cheap solution.
I have the same problem with WIDL 106.
Posted on Oct 15, 2009
richardsimpl
  • 230 Answers
SOURCE: Hi there I have Hotpoint
i'm giving my e-mail adress so i can help you more and it won't coast you a thing. i will continue to help until you get it working again. it's richardsimpler@yahoo.com. feel free to e-mail me any time.
Thank you
Richard
Posted on Jan 10, 2010
hbsurfdawg
  • 95 Answers
SOURCE: ariston avxl 129 washing machine has stopped working.
This washer does not have a good track record. There are many many complaints out their on this brand in general. It is also not a cheap purchase.
1st. Suspect is the mother board followed by the motor.
Posted on Nov 20, 2011
Indesit washing machine
Indesit Washing Machine lWB5113 Flashing Lights(Faulty ...
? 3:34
www.youtube.com/watch?v=-lnfePzPwTQ
Jul 29, 2012 - Uploaded by porracaralho caralho
Indesit Washing Machine lWB5113 Flashing Lights(Faulty).mp4 .... older model- stopped in rinse cycle/flashing power and rapid wash lights- ...
How to repair Indesit washing machine that is Flashing ...
? 0:43
www.youtube.com/watch?v=Q9Yq2Cz8UFE
Jun 26, 2011 - Uploaded by XR600RQJ
Washing machine Indesit starts to flash for longer and longer ...How do you unlock the door when the power is off?? every time i turn it ... My washing maschine ( Indesit WITXL 129 ) had the same problem - 6 from 9 LED lights ..
Oct 14, 2015 | Kenmore 24032\24036 Top Load Washer
Power indicator and rpm indicator flashes
See:
? 3:34
Jul 29, 2012 - Uploaded by porracaralho caralho Indesit Washing Machine lWB5113 Flashing Lights(Faulty).mp4 .... older model- stopped in rinse cycle/flashing power and rapid wash lights- ...
? 0:43
Oct 14, 2015 | Washing Machines
What does the error code 07 in an ariston amd 129 ?
the led flashes seven times? then pauses for 8seconds? this is how you determine the service code on a 129 there isn't a F7 code on a 129 on a 125 it's a heater relay stuck.... hope this helps~~
http://appliancejunk.com/forums/index.php?action=dlattach;topic=8959.0;...
Jul 15, 2014 | Washing Machines
Ariston avxl 129 washing machine has stopped working.
Nov 20, 2011 | Washing Machines
What does F02 fault mean?
Hello elaineginolf, welcome to Fixya. Error code "02" typically indicates a lock problem. Since not all models are the same can you clarify the model of Bosch you have ? The post category says WFL2060 but that can't be since that model has no display and faults are indicated by way of led lights flashing in a set pattern. Could it be a WFR2460 with the digital LED display ? Let me know and I'll see if I can assist you from there. Macmarkus :)
Jun 26, 2010 | Bosch Axxis WFL 2060 Front Load Washer
My Ibm is T30 the when i put jack power the indicators of charge batere is on. But when I'm push the power button is doesn't work then indicator light still off. Whwn I push then power button and I put...
Hello there:
here are the hints or ideas
1) You may have a bad or damage, power on connector (soldering) inside the motherboard.
2) Bad Charger , you need to check these with a multimeter, if you know how to do it.
3) bad video inverter or its starting to fail.
4) or simply your video card, is failing. perhaps dust, or the fan for the video card is bad or clog .
Good Luck
Carl
Apr 21, 2017 | IBM Thinkpad T30 Notebook
Hotpoint BWD 129 machine starts to fill -
Try on a cold wash or rince cycle, if this then works it could be faulty heater element.
Feb 12, 2010 | Washing Machines
Hi there I have Hotpoint BWD 129 washer-dryer. The door looked led started blinking rapidly and "delay start" and "super wash" lights and also blinking and machine is not working. Please can you...
Thank you
Richard
Jan 10, 2010 | Washing Machines
Home Logo
64 people viewed this question
Top Whirlpool Home Experts
Craig Butler
Craig Butler
john h
Mike
Are you a Whirlpool Home Expert? Answer questions, earn points and help others
