My aspireone could previously connect to our wireless neetwork but recently it can't even detect any network at all despite there being at least 5 or 6 available. our other laptop can detect, no porblem. pls help
  • 1,591 Answers
I don't know which model you have so I will give the generic answer here.
Open the panels on the bottom of the unit.
If you see a hard disk, that's not it.
If you see RAM, and nothing but RAM, that's not it.
If you see a card with a couple cables plugging into it, that's probably the one.
One cable will run to the ethernet port on the back
the other is for the antennas! - that's the one we want.
Disconnect the power, and remove the battery.
there are 2 tabs, on on each side of the network module - pushing them to the sides should let the module pop up a bit. This makes the cables easier to disconnect.
Since the ethernet port isn't the issue, leave the wider connector in place.
remove the smaller connector, then snap it back in place.
Pull the adapter (thing that looks like a RAM module) gently and just slightly out of the socket, then firmly push it back in and snap it down.
Close up the panel and reinstall the battery and plug the unit back in.
See if you can see any networks now.
If you can, Voila, problem solved!
Posted on Mar 12, 2011
  • 32,281 Answers
The router's password is a Passphrase or the WEP or WPA orWPA2 encryption key. The Passphrase generates the WEP or WPA or WPA2 encryptionkey and this is in the router's wireless settings. To connect to your wireless router, it needs the router'swireless settings configured ie SSID, WPA or WPA2 encryption key and also thewireless cards in all the laptops and or computers needs to be configured withthese router's wireless settings. Then the laptops and desktop computers cancommunicate with your wireless router.
How do I change the password on the kindle for the wireless network?
To add a new Wi-Fi Network:
If you don't see the network you want to connect to in the list of detected networks, you can add it by choosing "Enter other Wi-Fi network" at the bottom of the list of detected networks.
  1. Make sure you are within range of the network you want to add, and that you know the network name and password (if required).
  2. Press the Home button, then press the Menu button.
  3. Navigate to "Settings" by moving the 5-way controller down, then press the 5-way controller to select.
  4. Select "view" next to "Wi-Fi Settings" to display a list of detected Wi-Fi networks.
  5. Use the 5-way controller to navigate down to "Enter other Wi-Fi network" and press to select.
  6. Enter the name of the Wi-Fi network that you want to add.
  7. Enter the password (if required). Press the Symbol key to enter numbers or characters not present on the Kindle keyboard. You can continue to use the keyboard while the Symbol menu is displayed.
  8. Choose "submit." Kindle connects to the new Wi-Fi network.
If your Kindle fails to connect to the new Wi-Fi network, it will display an "unable to connect" message. You can try manually entering all the network information for the Wi-Fi network by choosing "set up network" when you see the "unable to connect" message. If you don't know the network information, try connecting to a different network, or contact the network's administrator.
To forget a Wi-Fi network:
You can tell Kindle to forget the Wi-Fi network you're connected to so that your Kindle doesn't connect to it automatically in the future.
  1. While connected to the network that you want to forget, press the Home button, then press the Menu button.
  2. Navigate to "Settings" by moving the 5-way controller down, then press the 5-way controller to select.
  3. Select "view" next to "Wi-Fi Settings" to display a list of detected Wi-Fi networks. You may have to wait a moment as your Kindle detects networks in range. The Wi-Fi network you are currently connected to displays the word "forget" next to it in the list of available networks.
  4. Choose "forget" to disconnect from the network.
To connect to a Wi-Fi network:
  1. Press the Home button, then press the Menu button.
  3. Select "view" next to "Wi-Fi Settings" to display a list of detected Wi-Fi networks. You may have to wait a moment as your Kindle detects networks in range. Kindle automatically scans for available Wi-Fi networks at periodic intervals. To rescan for available networks at any time, select "rescan."
  4. Select "connect" to connect to a network. If you see a lock symbol next to "connect," the network requires a password to connect.
  5. If necessary, enter the Wi-Fi network password, and choose "submit." Press the Symbol key to enter numbers or characters not present on the Kindle keyboard.
Once you are connected to a Wi-Fi network, Kindle automatically connects to it again whenever that network is in range. If more than one previously used network is in range, your Kindle automatically connects to the network that was most recently used.
Tip: Once your Kindle connects to a Wi-Fi network, that network displays "forget" next to it in the list of available networks. Selecting "forget" disconnects your Kindle from that Wi-Fi network and also prevents Kindle from automatically connecting to it in the future.
Mar 07, 2016 | Tablets & eReaders
Acer AspireOne safe mode setup
You are posting a docking station for a laptop. You need to make sure you Network Connections are good before attempting to use the dock with network.
More than likely you simply lost the drivers for the Network Interface Card,
Jun 04, 2013 | Computers & Internet
I have an acer aspireone notebook and i was wondering if im able to connect to wifi. i have a wireless internet finder that i can plug into it but it doesnt have a cd rom to be able to download the...
All netbooks have both the wired and wireless networking capability built-in. The Acer Aspire One AOA 150 Model No. ZG5 (8.9" screen) netbook has a RJ-45 jack on its left side for wired 10/100 Ethernet. On right-most part of its front is a slide switch to toggle enabling/disabling of the built-in 802.11b/g WLAN for wireless connectivity to WiFi. Click on the following link for a detailed description... http://en.wikipedia.org/wiki/Aspire_one
Pushing the wireless slide switch to the right momentarily will cause either Wireless LAN Enabled or Wireless LAN Disabled in large green letters to appear momentarily at the bottom middle of the screen. Once enabled, look at the Taskbar at the bottom right of the desktop and click on the little terminal icon with ))) and a little red x beside it. This opens the Wireless Network Connection window and you would then do the following...
1. in Network Task sidebar click on the Refresh network list to update the wireless networks
2. in Choose a wireless network on the right side, click on an item in the list to select & hi-light it
3. click on the Connect button to get a pop-up window for Network key & Confirm network key
4. if unsecured network, the pop-up reminds you of the risks but you can Connect Anyway
5. in the pop-ups, you can click to either Connect (for secured), Connect Anyway, or Cancel
6. when connecting, another pop-up window appears with Waiting for the network
7. once connected, the selected network will move to the top of the network list
8. in the desktop's Taskbar, the little terminal icon with ))) will no longer have the little red x
9. right click on the icon to get a pop-up for the status and wireless connection management
Apr 15, 2011 | Acer Aspire One Netbook 8.9" Notebook
Computer doesn't recognize device
remove previous all drivers for this device and install again, if not works , setup your OS freshly.
Sep 26, 2009 | Linksys WUSB54GSC Compact Wireless-G USB...
My new wirless acer aspireone d250 will not connect to my network, it keeps tell me its unable to connect to preferred wireless network
Wireless Network? With password for login OR for free.....? Make sure this....
If your laptop have wireless internal and turn ON. See your indicator WiFi. And your laptop may be detect some hotspots in your area. If ready to know that hotspot, that's mean your WiFi in laptop is WORKING for that purpose. And you can ask to network administrator for your purpose and log into internet (with WPA key or for free...)
Sep 22, 2009 | Acer Aspire One PC Notebook
I am using a dlink wbr-1310 and am able to detect the wireless connection via my HP running vista. Recently had a friend come over and her Vaio running windows xp was NOT able to detect the wireless...
Your friend need to clear her wireless connection so she can connect to yours. Look at the lower right corner on her screen and see the flashing TV screens for the wireless connection. Right click on the icon and click repair. She might have to reboot and then she should see your wireless network and connect as you do,
Jun 23, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Experiencing error when connecting to wireless router
I've had this happen before when using a USB wireless device. Is the wireless on your system built in? Or do you connect it to a USB port? The external devices sometimes try to use their own software to configure wireless so you can shut it off and just use the Windows wireless tool. I assume you setup the wireless with a security key and entered that key into your system to try and connect? Let me know if any of that helps and rate the solution if it does!
Mar 31, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Finding encryption key
This should work give it a try:
1)go to control panel
2)click on internet connections
3)wireless network setup wizard
4)click next
5)set up a new wireless network
6)next
7)Automatically asign a network key
8)set up a network manually
9)print network settings
Dec 21, 2008 | IBM ThinkPad T40 2373 Notebook
Wireless network not detected despite all elements seems working
Hello there.
This is a common problem. What i typically do on notebooks that use Intel Wireless, is install the latest drivers and Intel software from their website. 9 times out of 10 this will make it pick up a network that was not previously found, or fix problems with timeouts and so on.
Please click here then choose your version of windows, click 'Go!' and then click "Download" beside the section called "Intel® PROSet/Wireless Network Connection Software for Windows* XP/2000 32-Bit"
When you download and run this file, and install the software, you can then use the Intel utility to connect to the wireless network.
Hope this helps.
Jun 16, 2008 | Intel PRO/Wireless 3945ABG Network...
Compaq n 600 evo wireless
Aboslutely yes but it should automatically detect wireless network in XP .
You have to reconfigure your network settings on the Laptop.
Dec 26, 2007 | Compaq Evo N610C Notebook
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
