Question about LG GD510 Cell Phone
How to unlock remoove - LG GD510 Cell Phone
    Sergeant:
  • 169 Answers
Go to phone settings, select security settings. then sellect phone security, to unlock the phone be sure you know the unlock code of your phone. Enter the right code then press "OK". thanks
Posted on Mar 12, 2011
Removed paper jam but the error message keeps showing up
Hi, ida you haven't remooved all the jam that was inside, somtimes it a little pice of the page and it under a tooth so you can't see it unless fully rotate that gear.
Or after you remooved the jam, you have to Resset you mashine and Resset your printer, that will fix Yor problem.
Good luck
Oct 17, 2014 | HP Officejet Pro 8600
IR 3300 if take front & Back copies the machine shows E00064-000
sir it is very simple problem.
and the solution is open the machines front door and remoove lock(when uou was relesed lock it was shoing up and down section) the drum unit is remoove out side
and in the machine boottem of the drum unit like that charger roller (pcr) it is called charge roller .itwas when dusted
showing the eooo64-00 error.clean the serfae or chane the the charge roller
And my name is prathap kumar
my office is in guntakal(anantapur district)
cell:9573910647,9059023089
Apr 06, 2011 | Canon iR330-400 PS Ver 1.0
What tools do i need to remoove drain pump from cabrio he washer WTW6700TW and how do i get to it to remoove coins
If you remove the pump turn it upside down to shake out the coins Its secured by two screws cross head or philips......Remove the 2 hoses use an old towel to mop up the water from it ...quite straightforward.Good luck...
Apr 06, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
The thermal paper is wrapping around an upper roller. Inside the sandwiched layers is the fax. This just started happening.
U must to remoove some scrues about 4 scrues? then ease remoove the roller and remoove the jumed paper down
Sep 11, 2009 | Office Equipment & Supplies
I get the message power failure on my cordless phone
REMOOV BAT FROM PHONE ,WAIT 1 MINUTE,TRY AGAIN,REPLACE BATTERY,
Sep 03, 2009 | Vtech CS5121 Cordless Phone
I just downloaded my photos to our computer, did the safe card remooval and now I get Card Locked when I turn the camera on. We have used this same SD card for a while now with no problems.
Check to see if the lock switch is turned off on your sd card....look close on the edge..
Also, try a card reformat if your images are safely on your computer....
Jul 08, 2009 | Canon PowerShot A530 Digital Camera
Service tech's window on a Sharp AR-C260P
You mast remoove 4 screws and take off the back cjver of the mashine
2/ To be shjre? that? tere are no the some cutting peaces of the paper
3. See the papers flag is on correct and did not brocen with the remooving paper///
4/ There are no any coode to reffreshing this mistake
5 you mast visual observe fixin exit unit///
6 it is very ofen problem in copiers and printers///
7 If you a shore? thet the fla jf mooving papar is well, yours machine mast to work well
Mar 22, 2009 | Sharp AL-1641CS Laser Digital Copier
How i remoove write protected from my usb flash pendrive
Your USB pen drive may have a small slide switch on the side of the pen drive. Slide the switch to unlock the write protection.
Feb 03, 2009 | IBM ThinkPad T30 2366 Notebook
Player gets paused by itself
simple problem.
remoove front panel and clean pause micro push button with cleening solvent.or you donot use this button remoove the button bu usind soldering iron.
the problem is with this the swich contact witout pressing the button because of dirt inside it
nuwan
Jan 09, 2009 | Electronics - Others
LG GD510 Cell Phone Logo
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
