Question about Microwave Ovens
HI DONT KNOW HOW TO SET THEALARM TIMER - Microwave Ovens
    Brigadier General:
  • 8,909 Answers
Most major manufacturers supply manuals online so if you were to log on to the manufacturer's web site, you may be pleasantly surprised as usually, if available, one is able to download, by model number, Customer Instruction Manuals, Dealer Network for spare part supplies as required.
The information is normally free of charge.
I hope this helps.
Posted on Mar 12, 2011
Hi how do I set a hisense microwave clock,its been giving me a hard time to set it,please help
I know there is a cook timer and a clock ....Hit clock ...set time..then hit clock again....That's how mine works... Hope that helps
Aug 14, 2017 | Microwave Ovens
Cook works microwave timer stuck
If by "manual timer" you are referring to a knob that you turn to set the cook time, then you may have a failure of the motor that turns the timing mechanism, or a lack of power to it.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
May 10, 2014 | Microwave Ovens
Microwave jes1142
If the timer counts down and nothing else happens, the secondary interlock switch is bad. This switch completes the cook circuit and this is why it doesn't run. You need an ohm meter to diagnose and find the right switch. Switch failure is caused by opening the door when it is in cook mode. Push the stop button first before opening the door and this failure will cease to occur. BE CAREFUL !!
Oct 09, 2013 | GE JES1142SJ Microwave Oven
KOR-63F7SL Timer Sticking
Generally you are better off having it replaced, unless you know someone that is handy at mechanical repairs, there might be a chance to fix it.
Apr 16, 2012 | Microwave Ovens
NN-SD6968 set the timer, press start, timer counts down, microwave doesn't run?
I just developed this problem with my panasonic inverter microwave...does anybody know about this problem?
Apr 12, 2011 | Panasonic Microwave Ovens
The lights are still on but the microwave will not warm nothing up. someone tried to warm up four big white potatoes and it stop cooking. the timer still count down but u dont hear nothing and it dont warm...
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Feb 15, 2011 | Emerson Microwave Ovens
Hi, I have a Kenmore 87103 microwave and it has started acting up lately. When I place something in the microwave and set the timer, the timer counts down however the microwave doesn't work (no sound and...
Mine also does the same thing however I only need to lift the door upwards slightly (after it's closed) and it engages the High Voltage Transformer, thus working as normal.
Once you know that, you can get it to work every time. I beleive the clips on the door don't properly stop latch in correctly and the safety feature keep the microwave from acutally turning truly "ON".
Nov 28, 2010 | Kenmore Microwave Ovens
I have a GE profile double wall oven. I do not have to owners manual. I know I just press clean to clean the ovens, but how long do I set the timer for?
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Sep 25, 2010 | GE Microwave Ovens
When drying cycle is set on timer.circuit breaker trips Timer has been replaced but don't know if it is good. shipped with no packing or paperwork from Sears There is 2000 ohm short between the black power...
if you are sure you have wired the timer correctly you may have a faulty element as to the short between your black wire and ground are you checking this with the dryer disconnected from wall socket also run the dryer on cool if does not trip the power element faulty if it still trips you may have a wiring problem and you will have to check further let me know how you go
Nov 12, 2009 | Microwave Ovens
Microwave Ovens Logo
11 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
