Question about Sony HOME THEATER SYSTEM System
I m receiving a message push power protector - Sony HOME THEATER SYSTEM System
  • 635 Answers
That is an internal failure message . The system is telling you either your speakers are shorted ( even cables could have shorted ) or the internal amplifier Chip has failed. its is asking you to switch off the system by pressing the power button to prevent further damage. You will need professional help to replace the STK power chip.
Posted on Mar 12, 2011
Push Power Protector - Sony MHC-VX777 I am getting Standby message and push power protector .My music system was not operated
Hi!
This is what the manual says:
PROTECT"and "PUSH POWER" appear
alternately.
•A strong signal was input.
Press ?/1 to
turn off the power, leave the system
turned off for a while, then press ?/1
again to turn on the power.
•Check the speaker cables in case
"PROTECT" and "PUSH POWER"
appear alternately again after you turn
the system on.
Jun 05, 2017 | Sony Audio Players & Recorders
SONY Push Power Protector DAV - DZ610
Shahid, my Sony DAV-576WF is getting push power protector (SD detect), think it might be one channel blown, I do have the Schematic Diagram (service manu book) and ee knowledge with tool, could you give me a hand on fixing that when you got time?
It is no a fancy receiver but it does play SACD/DSD, that's the part I like
my email is yuyi429@hotmail.com
Nov 07, 2011 | Audio Players & Recorders
I have Home Theater Sony DAV- DZ151Kb. Display Push Power and then PROTECTOR. I need Help
Push power protect message appears when home theater got problem in amplifier output section and any output amplifier chip becomes bad, receiver set protection mode and refuse to power up to avoid further damage in circuit board.
It is very hard for novice to troubleshoot what output chip is defective out of six amplifier output ICs in unit, check by professional is needed to solve this issue.
Hope these info will help you.
Let me know if you have additional question.
Thanks.
Jan 14, 2011 | Sony Audio Players & Recorders
When I turn on my Home Theater Sony Model hcd-hdx576wf this message appears, "protector, push power". what I can do?
Follow the steps below to troubleshoot if the word PROTECT or PROTECTOR is flashing on the A/V receivers display.
1. Check the speaker wires and speakers for proper connections.
2. Reduce the volume level. IMPORTANT: If the receiver is played back at maximum volume level it may enter the protect mode. Maximum volume listening will cause the receiver to run very hot and may drain the output capacitors.
3. Disable the surround sound option if both the A and B speakers are being used simultaneously.
4. Ensure the top of the receiver has proper ventilation to keep it from overheating.
5. If the message only occurs when using a DVD player, the sampling frequency may be set too high. IMPORTANT: Some receivers provide compatibility with the higher sampling frequencies through alternate connections. Consult the owners manual for specific information.
6. Unplug the AC power cord for about 1 to 2 hours to reset the output transformers.
Dec 17, 2010 | Sony Televison & Video
Message "PROTECTOR"
Disconnect all speakers at the receiver and power it back on. If it stays on, check all speaker wires and speakers for shorts. If it cuts out, it needs service. If you need detailed troubleshooting help on this after testing receiver without speakers connected and it passes, post a comment and I can walk you thru it. Hope this helps.
Oct 24, 2009 | Sony STR-DE625
Keep getting message protector
if all connections and speakers seem ok the problem is internal witch can go from blown power supply to shorted output devices and everything in between , and as always look for repair shop in your area, do not attempt to do it yourself, firehazard and electric shock are the things we all want to avoid ;)
Sep 01, 2009 | Sony STR-DE835 Receiver
PROTECTOR MESSAGE
Yes, It is receiver internal issue.
Jan 02, 2009 | Sony STR-DG820 Receiver
I have a sony DAV DZ230 home theatre system
on my home theater display it shows protector push power
Nov 24, 2008 | Audio Players & Recorders
Sony HOME THEATER SYSTEM System Logo
326 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
