Question about AEG Lavamat 72640 Front Load Washer
I have caught a piece of clothing in the door started the machine and water has started leaking out the door turned off the machine the machine has stopped leaking but I can't open the door have waited for it to reset still not opening turned the machine off before it began it's cycle so it only filled.didn't go into cycle need to open the door too move piece of clothing
  • AEG Master
  • 1,527 Answers
Hello there is a way but it only works on some machines you need 2 people you have to tip the machine on side slightly the other person has to reach underneath and manually unlock it. it a fiddler thing to do but it might work hope it helps
regards
shaun
Posted on Mar 12, 2011
My BOSCH Axxis 24201UC washing machine displays "E:16" (which means "Door not closed properly") all the time, no matter what, and is inoperable
Check that the door switch is closing when you close the door with the latch mechanism. Unit will be dead unless the switch is closed.
Sep 20, 2017 | Bosch Washing Machines
Water coming out the door in rinse cycle
First thing to check is that you don't have a piece of clothing stuck between the door seal. I have had that with a commercial machine. A towel was causing the leak. If it does it on every wash, then either the door lock needs adjusting for tightness or you need a new door gasket.
Apr 17, 2017 | Washing Machines
Clothes get caught between tub and door
just wondering is there a small long panel at the front of this machine at the bottom if so should be a screw at each end ,take panel of im not sure but one of the sprung legs may have come off make sure machine is empty and look for the legs one iver side one might be lying down look at the other one and push leg back into its slot and slightly turn it,some of these machines flick the leg off if its been over loaded at some stage you might see if you look at the drum the front edge is dipping down,i know the one at woke the legs of the drum have come of 3 times over a number of years but they just slot back and its always fine after,hope this helps someone,ROY
Mar 17, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Piece of clothing caught in spinning wheel
Hello, you a side load washing machine. The spinning wheel is a counter weight for the wash tub.
The tub out seal that fit around the tub is worn out. News a new seal. Unplug the washing machine and remove from cover with the door. Once you have the front panel with the door the tub seal is attached to the front by lock clips. Remove the clips or screws. Now, check the interior seal and make sure does have any hole in it. If there is holes then walter will leak on to the floor.
You might have to use a Laundry Mat for a few week while waiting for parts. GB...stewbison
Sep 10, 2011 | Washing Machines
Washer motor humms and won't spin after filing up with water
remove the water pump from the motor but not from the hoses and start the washer. if it starts then you have a sock or something caught inside the pump holding the motor. remove the object or replace the pump if needed. if the motor wont start then unplug the washer,remove the motor and turn by hand. if it feels hard replace motor. if it moves then leave motor out and move the gear case where the motor connects by hand. if it wont move then 2 things may happen. 1)gear case lockup or a piece of clothing caught between the tubs.
if the washer agitates but wont spin with the humming sound then I say the later. a piece of clothing caught between the tubs.
Feb 10, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
My whirlpool duet front loader is leaking water? Not sure from where cause I havn't caught it in the act. But when I go in to get the clothes I have a puddle right under the front door. Cant tell if is is...
empty the washer. then remove the bottom panel of the machine.put some water in it and see if the water is leaking when it is filling or full.I have seen a small hole in the tub just behind the bottom counter balance where the mounting bolt goes you may need to use a small mirror to look under there.f94b104.jpg
Jun 06, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Disintergrating black cardboard material related to water leaking
it is sound proofing and, your dishwasher is safe to use
Jul 01, 2009 | Dishwashers
Washer won't spin
hi thanks for the question. when you close the lid ,does the motor start, and pump out the water. if not ,you need a lid switch or an adjust . if it pumps out the water but no spin, you could have a bearing problem or some piece of clothing caught at top of tub check for these . thanks the appliance doc
Oct 01, 2008 | Maytag Washing Machines
Fridgidaire Front Load Washer
This is usually an indication that the rear tub bearing is starting to go bad. The bearing is located in the rear shell of the wash tub and cannot be replaced. In order to repair, you would have to replace the entire rear shell because the bearing is actually molded into the plastic. This is common with front loader washing machines. Another possibility could be items getting caught in the rubber door boot and leaving rubber marks. However, normally this will be associated with a leak somewhere. Inspect the entire door boot and clean in behind the rubber. Inspect for any rips, tears, or places where clothes can get caught. I have experienced clothing getting snagged and actually pulling the door boot off. If the marks continue to show up on your clothes (they may even turn a brownish color) I would look into an estimate on how much it would cost to have the tub bearing replaced. It is not an easy repair, and it is not cheap. The cost usually runs around $500. I hope this helps.
Aug 08, 2007 | Frigidaire ATF6000ES Front Load Washer
AEG Lavamat 72640 Front Load Washer Logo
62 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
