How to pump ink in 6123cp copy printer? Please give me the guide to do it.
  • 32,281 Answers
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
Posted on Mar 12, 2011
Gestetner 6123cp
i have gestetner copy printer model 6123 cenhelp me removed earror code e-00 please help me
Aug 17, 2013 | Office Equipment & Supplies
Gestener 6123 Copier Printer Paper is sticking onto the drum, how do l solve it
I will need more details from you.There is a drum unit in there and a fuser unit that might look like a drum. ans normaly the paper sticks to the hot roller in the fuser, if the lead edge is solid black
Jun 14, 2011 | Gestetner - AO40 Wide Format Copier Copier
Gestetner 6123cp gives E-06 error. Can you help me?
Gestetner cp 6123p+ shows E-06 error.
please i need your help ?
Apr 08, 2011 | Gestetner P7527 Laser Printer
How do I put in a ink cartidge in my hpdeskjet 940C?
Turn on the printer and lift the top cover. Wait for the print cartridges to move to the center of the printer. Tilt the cartridges forward and carefully lift them out of the printer.
Then install the new cartridges, putting the bootom of the cartridge in first. then raise until it clicks.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 11, 2011 | HP DeskJet 940c InkJet Printer
Will print one copy and then says ink systen has failed unalble to copy,fax or print error 0xc05d1381
The "ink system failure' is caused by air in the ink feed tubes. This happens if you fully run out of ink in a cartridge and the printer sucks up air instead of ink or if you use a poorly filled ink cartridge that has air bubbles. You will need to do a ink tubes purge routine to clear the error. We have a step by step guide to perform the purge posted on our web site at: http://www.ccl-la.com/blog/index.php/category/printer-repair/hp-printer-repair/ The procedure takes about 10 minutes to complete.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
May 18, 2010 | HP Photosmart 3210 All-In-One InkJet...
Our HP Photosmart C6280 All in One printer is giving me the Ink System Failure message, I have unplugged everything & taken out the ink cartridges & put them back in, same message...HELP!
Check out our web site at: www.ccl-la.com Click on the printer repair link, we have a section under HP that gives a step by step guide to fix your printer. The problem is caused by air in the ink feed tubes and the guide shows you how to purge the lines. You should be back printing in less than 10 minutes.
Buddy
Corporate Computer
www.ccl-la.com
Sep 25, 2009 | HP Photosmart C6280 Printer
Changed out black ink screen says insert
It will be a hardware printing problem mostly. Try cleaning the parts with alcogol or/and elastic rubber. Also try to increase the force of contact with a sticky tape or like that.
Aug 09, 2009 | Lexmark P6250 All-In-One InkJet Photo...
My x1180, how do i change the ink cartridge
Here is a copy of the setup guide that should give you some good help:
X1100 Setup Guide
The cartridges are in cartridge carriers under the scanner unit cover.
Jan 12, 2009 | Lexmark JetPrinter X1185 All-In-One InkJet
76 people viewed this question
jasbo
jasbo
