Question about Dell XPS 400 PC Desktop
My dell xps 400 was shutting off and all i was getting was a solid amber light in front. I was able to hold it in for a bit and then press it and turn it back on for about 2 weeks now. It finally shut off once more and no amber light no led lights yet the led on mother board lights up when i plug the L375p-00 power supply. is the power supply fried or what?
  • 1,591 Answers
You more likely had a temperature issue with the CPU.
Had the CPU fan started to sound like an airplane warming up?
If so, you may have finally burned out the CPU.
Yes it's possible that it was reporting a problem with the power supply, but the only way to know for sure is to replace it.
In the meantime, eliminate everything else.
Disconnect power from EVERYTHING except the motherboard.
If it powers up, then it's possible that either your motherboard is failing (and now works under the decreased load), or one of the things you unplugged has failed.
If the unit springs to life, turn it off, and start reconnecting things.
If it fails constantly whenever 1 specific thing is plugged in, that thing or the motherboard chip that controls it is the problem.
Posted on Mar 12, 2011
Dell xps gen 4 diagnostic lights A C D green B amber also front power light is flashing green and amber
go to dell website and see what those lights are meaning, I can't help with no exact brand and model (Dell - model ....)
Feb 19, 2014 | Dell Dimension XPS Gen 4 PC Desktop
Led light is solid on my dell xps 400 and system wont start? any ideas?
Can you be more specific when you say the system won't start?
If the system does not turn on at all or turns on for a second and then shuts off it is very likely due to a power failure. If you have installed any new harware recently unplug it and try to start the system again. If problem persists it is likely faulty power supply which a fairly cheap fix.
Jan 06, 2011 | Dell XPS 400 PC Desktop
Xp420 dell doesnt boot just a solid amber light on mother board high rpm on fan that doesnt slow no picture on screen....?????
Solid Amber light is a No-Boot scenario for all DELL PC. It may be either Power Supply, motherboard, memory or Proc. If you try to call Dell customer support they might try to let you isolate the problem by opening up your pc. But they will replace the parts necessary if they found out that its broken and your XPS is still under warranty.
You can call 1-800-232-8544 be sure to have you Service Tag or Express Service code ready.
Jun 21, 2010 | Dell XPS 420 PC Desktop
Why did my xps 400 just quit, The only thing that works on it is, the cooling fan at high speed
The fans running full tilt are an indication of a NO POST failure with the motherboard.
The POWER LED on the tower, is it Solid Green? Solid Amber? Flashing Amber?
The diagnostic LEDs? (Numbered 1234) are any illuminated?
General trouble shooting is as follows:
  1. Power system off, disconnect all external connections except the power cord, turn the system on see if any change. If you get a change, reconnect items one at a time till you ID the failure. (Twice I've seen a bad mouse cause a no post, so don't assume items are good) If no change go to step 2
  2. If no change, then POWER LED is likely a solid amber. Open the tower, remove all PCI and PCI-E cards, see if the symptoms change. If they do, like before add items back one at a time till you ID the failure.
  3. Disconnect power to all drives, see if anything changes ....
  4. Remove the RAM, see if there is a change, if no change then replace the motherboard. If you get a change, try RAM modules individually see if one is faulty.
Dec 09, 2009 | Dell XPS 400 PC Desktop
Amber light blinking,replaced popwer supply ,still blinking amber
press and hold power button it is in hibernation mode when light is blinking power button is a momentary type of switch...
Dec 05, 2009 | Dell XPS 400 PC Desktop
I have a Dell dimension XPS 400/9150, 3 years old. I did updates and shut down. Tried to restart, but all I got was a flickering amber light. Won't start at all. Now no light.
Sounds like your power supply just failed. Unplug the power cord, open the case, and look for a metal box inside the case right where the power wire plugs in. Remove the box...usually four screws hold it to the case, remove all of the wires...marking each one and the motherboard so you'll be able to connect the new power supply wires. Most computer stores will have a suitable replacement. Easy replacement if you mark the wires/connections during removal. Just be sure to work with the power plug removed.
Nov 12, 2009 | Dell Dimension XPS PC Desktop
Dell XPS 600 turns itself on to solid amber
Hi. the mother board seems to be having some initialization issues during boot up. this is common when the mother board is failing. i would check to make sure the battery on this board is working. if it is, the board my be ruined.
power board seems to be fine.
please rate and god bless.
Mar 17, 2009 | Dell XPS 600 PC Desktop
No power to my computer.
hi
stuart
just read this carefully.................
Unplug the power cord and the display cable from the monitor. Now press the power button for 60 sec exact. Plug the cables and your system is working................ This is just a power drain.
Enjoy
Jan 13, 2009 | Dell DimensionTM XPS 710 PC Desktop
Computers & Internet Logo
181 people viewed this question
Alun Cox
