Question about ASUS Eee 900 Netbook
Baby got hold of netbook and was taping keys now the letter u is now no 4 how do i restore keyboard? thanks
  • ASUS Master
  • 32,281 Answers
The NumLk key has been pressed, press this key again and the NumLk will be released and the NumLk LED will turn off.
Posted on Mar 12, 2011
Cleaning the keyboard on my daughters laptop, I somehow screwed up all the function keys. Any way to restore just keyboard to factory default ? We don't want to do a total restore as we just installed...
HERE'S THE ANSWER TO YOUR PROBLEM:
Try to do it:
1. Turn off the computer.
2. Unplug the AC adapter.
3. Take out the battery.
4. Hold the power button to the right for 30 seconds.
5. Put the battery back in.
6. Plug the AC adapter back in.
7. Turn it on.
See if it works. If it works, Congratulations! If nothing happens, contact your service provider about it. Thank you!
Jul 04, 2011 | Computers & Internet
Problem description: hp 110-97TU netbook, windows 7 starter. without me touching the keyboard/touchpad or even type, it automatically continues to type in search text box letter ...
Hi Welcome to Fixya!
Obviously after the steps that you just did, its not a software issue.. Even though the Q key is not stuck physically, it could be a problem with the keyboard connections inside the computer..
And its really a bad thing that the warranty already expired because you will not be eligible for free hardware support.
The least thing you could do is have a local technician take a look on your netbook. They can open the keyboard for you and take a look for any malfunction on the keys or if its with the inside connections of the keyboard.
Hope this could help!
Hp netbook 110-97TU 1: Text box such as search prompts, google search text box, etc automatically types by itself letter "qqqqqqqqqqqqq......" 2: Keyboard keys/letters not working at all,...
having this issue may cause by hardware problem or key board malfunction, if the computer is still under warranty call your manufacturer and have it replaced.
Jul 03, 2011 | HP Mini 1000 Netbook
When you are typing it will type the symbols instead of the letters, you have to keep hitting the function button for the letters to work, sometimes it will work hitting it one time other times you have to...
Hi
Try system restore. Go to START>ACCESSORIES>SYSTEM TOOLS>SYSTEM RESTORE>CHOOSE PREVIOUS RESTORE DATES. Use other restore dates if needed.
Or try this
If your laptop keyboard types wrong characters, it is rather a software issue than an hardware one. This can happen if you accidentally press certain keys on your keyboard, which enable a certain kind of function.
Try the following steps in case your laptop keyboard displays wrong characters:
1.Go to the control panel option
Click ? 'Regional and Language Services' ? 'Languages' ? 'Details' ? 'Key Settings'
2.Select the option 'Switch Between Input Languages' and click on 'Change Key Sequence'
3.Ensure that all the check boxes are unchecked in this window and do the same for 'Switch to...(Keyboard Type)'
4.Click ?
'Ok' ? 'Ok' ? 'Apply' ? 'Ok'.
This should solve your problem
Jun 24, 2011 | Acer Aspire One AOD150-1920 Netbook
Hi my samgsung n150 keyboard has a problem when i type letter o it come 6 then i type letter l it become number 3 pls help me..tnx
If you look at the keys in question, you will notice that the U has a 4, I has a 5, O has 6, J has a 1, K has a 2 and L has a 3. These keys are part of the embedded numeric keypad that is turned on when NumLk is on. On the keyboard (usually at the top edge beside the Caps Lock indicator) is a NumLk indicator that looks like a little padlock with a number in its middle. It will be lit or a led directly under it will be lit when NumLk is on. To turn NumLk on or off (toggling) usually requires pressing and holding down the Fn key then momentarily pressing one of the function keys at the top edge of the keyboard which has the letters NumLk on it.
Apr 30, 2011 | Samsung N150 (36725723009) Netbook
How do i set the text on my facebook from small letter to big letters?
Hold down the "Ctrl" Button on the keyboard & press the" + " Key to make it big & " - " for small.
Nov 20, 2010 | Acer Aspire One Netbook
When i hit the letter U, I, O, P, J and so forth on my mini keyboard, I get the numbers 4, 5, 6, * instead. In essence I'm getting what on the upper right corner of those keys
your numlock is turned on. look for a key labeled fn and something like a padlock.. hold the fn key like a shift key, then tap the padlock.. this typically happens when someone plugs in an external full sized keyboard.
Sep 25, 2010 | HP Mini 1000 Netbook
Key button got pluged off
You probably broke a little tab that connects the letter to the actual button.
Just get some of that thick (foam) double sided tape. regular double sided tape wont work.
good luck
May 20, 2009 | Acer NSK8458AN Keyboard
ASUS Eee 900 Netbook Logo
60 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
