Question about GPS
I have a 1997 ford EL waggon i wanted to install a aftermarket stereo to it. so i drilled out the old stereo and took the 2 harnesses and the ground wire (black) out and cut all the harnesses off to wire my aftermarket stereo and found out that my car didnt start i have no i dear whats went wrong ive looked at all the fuses and none are blown car still turns over but dosnt run at all and cant rewire the old stereo for the fact that ive cut the harnesses realy short so there showing no wires i dont care about the radio atm i just need the car to start because my dad is useing it at the moment for work and has nothing else to get him to and from work please help!!!
  • 6 more comments
  • vcalbryce Mar 12, 2011
    but how would cutting all the radio wires stop the car from starting it dosnt make sence
    the model number for the stock stereo is fct014a2-a i looked at the 2 harnesses for a loop or if any connected together but none did i have my kenwood stereo if i connected that all up would my car start then?
    i dont understand could u make it simpler thanks
    i have a ford el 1997 i removed the stereo (model nummber FCT014A2-A) and removed two harnesses and the ground wire i think was seprete from them so all in all i removed 3 wires not included the attena i cut the harnesses off the 3 and now my car wont start it turns over but dosnt start i cant rewire the harneses back on because i have cut it to short could there be a immobilizer or somthing else dont care if radio dont work i just need the car to start ASAP thanks
    would completely wiring my atermarket stereo to the car make the car start again or would i have to install the factory radio for it to start and how would i do what u sugested seeing as i live in daylesford and the closest is ballarat and the car wonbt start to get it there
    ok but do think they would come out to by pass it or could they tell me over the phone a way to do it because i srsly have no way to get a car any way and my dad needs the car for work on tuesday so ive got 3 days to get the car to start or im dead would a ford dealer give me anouher harness for this make and model to wire it back to the car because stupid me cut the harness with abbsalutly no wire to work with
    so a radio shop like JB and supercheap or autobarn???
    :( i dont know what to do my dad needs to drive that car 60k to and from work i hope what u said works thanks for the help if u get on to ya freind could u email me?
  • 829 Answers
The radio is connected to the security system, the system must reconize the ignition key,engine computer and the radio for vehicle to crank.I think the ford dealer can bypass this feature with there factory scan tool.You may also try calling your local radio shop , they may know a trick or have the quipement to take care of the issue.FYI, never cut a wiring harness when installing a radio.There are aftermarket pigtails to adapt almost any brand of radio to any kind of car.Make for a good connection and a neat job.If you must cut a wire it should be soldered together and heat shrinked.Never use but connectors or the the old swist technique,that will be a problem for another day and can be a fire hazzard.Good luck.
Posted on Mar 12, 2011
  • 2 more comments
  • Donald Britton
    Donald Britton Mar 12, 2011
    No the security system will ne reconize the aftermarket radio, you will need to reinstall the factory radio or call a radio shop and see if they know a way around the security system.
  • Donald Britton
    The radio shop may help you over the phone.I dont think ford will sevice the wiring harness on the back of radio, they will want to sell you a radio.Another option is to find a salvage yard radio and take the back off of it and unsolder the wires( will require some skill)and solder those wires onto your radio.The salvage yard radio will not work in your car because of a vin number mismatch.It has the vin from another car burned into its memory.
  • Donald Britton
    Yes exactly , I tried calling a friend of mine that works at a place here and they are not open yet.
  • Donald Britton
    sure give me your email address.
  • 17,129 Answers
It is not advisable to cut off the original harness but to keep the connectors intact while a coupling harness extender to connect external systems can be purchased. This will prevent the loop connections from being cut off and thus produce similar problems.
I suspect there is a ground connection break to the harness that needs to take the circuit back.
Please check with the cut off harness if there were wires that looped or connected together, if so have it reconnected. Also the black ground must be connected to ground if there is no negative on the wire as it might be the ground from the old set body mounting.
So please get back to where you started , check the cut wires or have it wired as original but have your stereo connected with slits on the power and ground wiring.
  • Donald DCruz
    Donald DCruz Mar 12, 2011
    Some of the OE fitted sets have the line goingg back and it is possible in this case as the feedback goes back to the circuit. Check and see these on the old set that was removed.
Can i hook up a parakeet model number PWM 16 to my factory stereo in a 98 Ford Expedition
About 3,970 results (0.89 seconds) Search Results
    Ford Bluetooth® Wiring Harness - Crutchfield
    www.crutchfield.com/.../Ford-Bluetooth-Wiring-...
    Crutchfield Corporation
    Rating: 4.5 - ‎16 reviews - ‎$19.99 - ‎In stock
    Reinstall the factory radio and mount the Bluetooth kit, and you're ready to go. ... 16Reviews ... harness so that I could hook up an aftermarket amp to my factory radio.... works like it's suppose to. says it doesn't work on an 09 Escape but had no .... I purchased this harness to install a parrot ck3100 in my 07 Ford Edge.Missing: pwm
    70-5521 wiring harness for ford with 6 CD premium sub amp ...
    ? 4:30
    https://www.youtube.com/watch?v=0jqNafnki0o
    Aug 9, 2013 - Uploaded by codieraji
    Metra 70-5521 Radio Wiring Harness for Ford 03-Up Amp FordPremium stereo radio 6 CD changer with sub amp inputs. ...16:47. How to wire an aftermarket radio / I Demo install with metra harness and antenna ... How to hook up stock amp/sub to aftermarket head unit "ford sport trac" - Duration: 3:01. Pat.Missing: parakeet ‎pwm ‎98
    Car Stereo Wire Harnesses - Radio Wires for all Car Audio ...
    www.installer.com/main.php?page=harness
    Car Stereo Wire Harnesses - Car Stereo Installation Wiring - Stereo Harness ... If you
Feb 09, 2016 | Ford Cars & Trucks
Installed aftermarket stereo and now car want start but everything else works
Switch the wiring harness for the cd player back. t probably disabeled the ignition systime in the car.
May 01, 2014 | Brembo 2007 Dodge Charger - SXT, RWD -...
Aftermarket stereo turns on but can't hear anything 1997 explorer
Did the truck have the premium sound system? If so, you will need to connect the blue remote wire to the blue remote wire on the harness. You may also need a special harness to bypass the factory amplifier.
Jan 10, 2014 | Car Audio & Video
Im trying to install a new radio into 1997 Ford Expedition w/premium sound. However I cannot get any sound. I have the wriring harness.
Hello... I am sorry to hear you are having a problem I am assuming that you are using a wire harness adapter to interface between your factory harness and the aftermarket radios harness. If the aftermarket stereo has a blue/white wire, you need to connect it to the blue and the blue/white wires in the adapter harness. This will turn on the amplifiers. If your aftermarket stereo only has a blue wire, then use it as the connection with the blue and blue/white on your aftermarket harness adapter. Hope this helps. If you need any further assistance, let me know!
20 year car audio/video installer
Bay manager
Mar 19, 2011 | Car Audio & Video
Tried installing a new stereo system and had it in and going but the speedo wouldnt work so took out the stereo and it would work again then tired replacing fuse in stereo as it had blown and tried once...
your best bet is to buy a chiltons book for your car from an auto parts store. also i might add: reconnect your wires to the factory plugg you cut off and buy a wiring harness from a car stero installer or radio shack for your car it will automaticaly adapt your original harness (which your having trouble with) to a standard wiring setup for an aftermarket stereo. then its all about maching colors :)
Jan 31, 2011 | Car Audio & Video
Just installed aftermarket stereo in 1995 Ford
The memory (unswitched) wire, usually yellow, is not connected to a "hot all the time" connector...or its fuse has opened.
Jan 07, 2010 | Car Audio & Video
Need stereo wiring Diagram for 1993 Ford Tempo Gl
I just installed an aftermarket stereo in my daughters 93 Ford Tempo.
I have seen others post on-line and they were incorrect for my 93, the one I found my have been for a different year. THere are 2 wiring harnesses on the stock/OEM unit, one for the speakers (#1) the other for the power (#2). Here is what I found:
Harness #2
Constant 12 v+ : Green/Yellow
Switched 12v+: Yellow Black
Ground: Black/Yellow
Illumination: Blue/Red
Unused: Orange/Black
Harness #1
Left Front (+): Orange/Green
Left Front(-): Blue/White
Right Front(+): White/Green
Right Front(-): Green/Orange
Left Rear(+): Pink/Green
Left Rear(-): Tan(Brown)/Yellow
Right Rear(+): Pink/Blue
Right Rear(-): Brown/Pink
Hope this helps.
Dec 27, 2009 | 1993 Ford Tempo
Stereo stolen out of 00" Expedition and they took the harness
hot at all times: white/violet + light green/violet
hot in acc or run: black/pink
grounds: black/light green + black
instrument illumination: light blue/red
GEM module: gray/black
LF speaker: orange/light green + light blue/white
RF speaker: white/light blue + dark green/orange
LR speaker: tan/yellow + gray/light blue
RR speaker: orange/red + brown/pink
cellular/telephone: tan
this is for premium sound radio.
Mar 05, 2009 | 2000 Ford Expedition
GPS Logo
56 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
