I have bought a vga splitter to split one vga port in to 2. the other monitor isn't being registerd by th comuter when i use the splitter
  • 1,591 Answers
The computer will only see either one monitor or the splitter itself as the monitor, it won't recognize them separately or be able to put different data onto each (if indeed it is a true "splitter")
It's like the output from a satellite receiver. Just because you put a cable splitter on it so that you can have 2 TV's hooked up, both will be on whatever single output is coming out of the receiver, it doesn't let you watch 2 different shows, one on each screen. You'd need another receiver for that.
Likewise, if you want to see 2 monitors on the computer, there has to be 2 separate video outputs (some cards provide more than 1 output, but since you got a splitter, I am assuming this isn't the case for you).
Posted on Mar 12, 2011
Trying to set up 3 monitors in windows 7. using on board dvi to connect to one monitor and on board vga to connect to switch box (which then splits video signal to two vga monitors). can only get the dvi...
Sometimes it is difficult to answer a question without asking very basic questions. Using a DVI and a VGA ports will allow you to have screens with different things showing on them. If you use a splitter, the two monitors connected to the splitter will show the same thing on both screens. Is this what you want? I use a splitter at church to have Powerpoint on the main computer monitor, the program then shows on the screen on the wall and the TV monitor, as well as the second monitor at the computer. My splitter occasionally acts up, and I found that unplugging it and plugging it back in makes it work for another couple months. But a splitter for only two monitors is very cheap, no switch box involved.
Oct 01, 2017 | StarTech.com VideoView ST124 (65030772815)...
No Audio on Multiple Plasma tv's connected via 1*2 hdmi splitter
Too many connections here---likely a hookup issue if both sets work alone and frankly the wrong way to do this.
Apr 30, 2012 | Televison & Video
Using the splitter i can not get windows 7 to recognize the other monitor and enable multiple monitors
Hello there,
As you've said you're using a display splitter, the result will be identical screen on both monitors. splitters main function is to split VGA signals into N of outputs. where N=number of outputs. no matter how many monitors you attach to your splitter, the windows only recognize monitors attached directly to your video card. Windows requires a video card that has two or more output VGA or DVI outputs to get second extended monitor or display link device.
If you're video card has two outputs follow the instruction below.
1. plug the VGA or DVI other cable on the unused port. 2. power on the second monitor. 3. right click on the desktop, click screen resolution.
4. click the display in gray, Multiple Displays: it depends on the user.
5. I selected extended display. 6. apply and ok.
This spreads your desktop over both monitors and lets you drag items between the two screens. This is how most people use two monitors, and it's the default setting for desktop computers. you can use your mouse to grab the title bar (the top portion) of a window and drag it to your new display.
Hopefully this information is helpful. Thank you for using FixYa..
Jul 17, 2011 | Computers & Internet
We are trying to set up a dual monitor system so that we cn watch movies via the pc [not laptop] we have plugged in all the cables but still zilch
if you want to set up a dual tv monitor system using via pc as a source you will need a VGA splitter usually 2 or more output. now how are you going to connect the 2 monitor and PC to the VGA splitter. first make sure your tv monitor is supported by service input for PC unit. then prepare the accessories needed. the VGA splitter and VGA cable. vinceisaac_30.jpg vinceisaac_31.jpg sample image for VGA splitter VGA cable or connector how are you going to hook up the splitter and VGA cable to the tv monitor and PC
  • you need 3 vga connector and 1 splitter to connect a dual monitor system.
  • connect one end of the vga connector to the pc unit and the other end to the input port of splitter.
  • now the 2 remaining vga connector connect to the output of splitter either of the port, then the 2 end wire you must connect to the input port ( pc service port ) of the 2 tv monitor. make sure you set up the right input either with the remote or at the tv unit to recognized the pc source.
  • you almost done the connections now at this point plug the tv monitors, plug the dc adapter supply of the vga splitter and lastly turn on the pc unit to view movies. i hope it will help you just ask me if you have further questions thanks for choosing the fixya.
Jun 05, 2011 | Televison & Video
I have 2 identical Dell monitors on vga splitter plugged into port on laptop running Win 7. The NVIDIA control panel will only recognize the 2 Dell monitors as 1 display + 1 laptop display. How can I set...
you will have to change the settings in the control panel to an extended desktop once you have this lead connected click start control panel display change display settings you should a no 1 and a no 2 with detect and identify keep an eye on the television screen when you select the number tabs this may vary depending on your operating system when you select the no 2 tab this should be the extended tesktop always click apply after making any changes
Click start control panel administrive tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! red x right click select reinstall drivers hope this helps
http://majorgeeks.com/SiS_UniVGA5_Graphics_Driver_For_Windows_7_d6264.html
Apr 11, 2011 | Impact Acoustics 2-Port DVI-D VGA Splitter...
How to connect dual monitors to one pc
First of all your pc must be the right O/S and secondly you must have 2 VGA ports to be able to use 2 monitors. And vista and win 7 are the only O/S to be able to do this easily. You can always get a VGA splitter. tho. Hope this helps
Apr 07, 2011 | Computers & Internet
I have a new macbook pro and want to use a diamond bvumd3 to have 3 independent displays. my external monitors are both Dell 2310 with 1920 x 1080 capability. I have the bvumd3 connected into my macbook...
You would have to purchase separate BVUMD3 devices in order to get multiple extended monitors. Since each BVUMD3 has one DVI port with a USB hub, the DVI port is the only port available that allows video. Using a VGA splitter will not work with our device since each DVI port is allowed to carry only one video signal through to the monitor. You could purchase separate BVU195 devices if you do not need to use the USB hub on the BVUMD3.
Dec 27, 2010 | Diamond Multimedia Diamond BVUMD3 USB...
I just got the Gigaware 2 port usb powered vga splitter and I have ywo monitors connected. Both monitors show the same thing but I want to extend the desktop across both screens, however Windows XP does...
A display splitter will only mirror the screens, you cannot extend the desktop via a splitter.
Most portables cannot support dual monitors without a docking station.
Jan 07, 2010 | Computers & Internet
Cant extend workspace
The splitter you bought allows you to split one video signal into two. For example, a teacher using a computer to teach a class. She has one computer, one monitor she can see and then the splitter allows the students to see what she sees. To display independent screens you'll need to add another card to your system. Microsoft Help and Support lays out how to do this with Win 2000. No splitter involved.
Apr 10, 2009 | Computers & Internet
Splitter not splitting.
Could be...try to connect each PC by then selves straight to the jack to make sure its not ur PC. If both work and connect the splitter, if problem still exists it the splitter......trash it!
Oct 22, 2007 | Unicom Network splitter (SMJ-50108-B)
Computers & Internet Logo
59 people viewed this question
David Payne
David Payne
