Question about Gateway Computers & Internet
Hi all, I have 2 hard rives on my PC one is the slave, I was going to put in a plain old toggle switch to shut off power to the slave drive when not in use...But if the drive gets switched "on" while PC is powered up, would that be a terrible thing? I know you need to power down b4 plugging in a HD, but what about this method?
  • 77 Answers
It depends on the interface ("connector") of the hard drive.
If it's USB (external) or SATA -- the interface used by most computers today -- then hotswapping is possible and you can safely plug it in. Before switching it off though, make sure that the computer is not writing or reading any data on the disk.
If it's IDE, plugging the hard drive in or turning it off while the computer is running can damage the HDD or the computer.
Posted on Mar 12, 2011
My hdd cables is damaged .Can I disconnect my cdrom cable and use it as a hdd cable because I don't need cdrom cable now.I am using old p4 machine and ide cable .
yes you can use the ide cable from the cd rom in place of the hard drive ide cable.
I assume you have two cables that are ide in the pc
you could make the cdrom drive a slave via its toggle switches and the hard drive as master and run them on one cable if the cable has two plug ends on it for two drives . depends on what type of ide cable you have.
If the hard drive is a master drive setting on toggle switch you can run it on the cd rom IDE cable
Jan 28, 2017 | Computers & Internet
I need to put my hard drive into an enclosure but I cannot figure out if I need to switch it to a slave before adding it to another computer
i have done this alot for my customers and its really simple. if you look up your drive and get the jumper settings for it and set it to cable select or master in a one drive enclosure it will work well. i do not recommend putting it on slave because some enclosures will not recognize the drive, I do recommend having an enclosure with a fan on board and an external power switch. the reason it the fan will extend the life of the drive and the power switch eill allow you to power it on and off without having to flatten (power hot swap) the drive. Hot swap is ok but this is better than just unplugging the drive. removing the power from the drive keeps the drive in park until you re-power. as long as the drive is "parked" it is les likely to cause read/write sector errors.
If you have any problems let me know and please leave positive feedback for me. Jethro
Feb 01, 2011 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Can I add an additional internal hard drive?
Yes, you can add additional hard drive.Please follow the below steps to add the drive sucessfully.
STEP 1:
Make sure you have room for an extra hard drive, here's one way to do this:
1. Restart your computer and go into the BIOS menu as per below instruction.
Steps to enter BIOS:
After turning ON, immediately press the F10 key if your computer was built in 2006 or later (came with Vista). Press the F1 key if your computer was built before 2006 (XP or earlier). Press the key once every second until a BIOS Setup utility screen opens.
2. Go to the "Standard CMOS Settings."
3. In this menu, you will find four settings labeled as follows: PRIMARY MASTER:, AUTO/PRIMARY SLAVE:, SECONDARY MASTER:, SECONDARY SLAVE:. Change all fields to auto detection.
4. Reboot your computer.
5. On the first or second screen, you will see something like the screen above and it will say detecting (drive(prim/sec)) : (name of the drive if present). If any of them say none, remember which drive it is. If all of them have a drive name, all your bays are filled and you can't add a new hard drive without removing a disk drive or hard drive. Consider making an external USB drive.
STEP 2:
1.Shut down your computer.
2.Unplug all of the cords from the back of your computer and pull the computer out from the desk.
3.Remove the case screws. If you're having difficulty, it's a good idea to consult your manual on how your particular case is removed. Put the screws in a safe place so you don't lose them. Remove the side panel and place it out of the way.
4.Find the area where all the flat ribbon cables (or SATA cables, which are smaller and usually red) connect to the main board. Find the cable that corresponds to the free drive either primary or secondary.
STEP 3:
1.Set the jumpers so the drive knows whether to act as a master or slave. The jumpers are the set of pins on the back of the hard drive. They'll have a couple of rubber or plastic blocks covering some pins. Find the diagram or instructions for your new drive on to set the jumper for the master/slave.
2.Find the empty bay in your computer case. Using the screws that came with the drive or computer case, mount the drive.
3.Connect the cable to the hard drive. If it won't go in, make sure that the safety bump is aligned with the hole.
4.Connect a Molex power cable, (a smaller connector with red, yellow, and black wires.)
5.Put the side panel back on the computer and put the screws back in.
6.Plug all of the cables back into the rear of the computer, and connect them to their power sources if you unplugged them.
7.Boot up the computer. Go into your BIOS at startup.Check the BIOS auto detect to ensure the second drive is detected. On the screen that shows that primary master/slave,secondary master/slave you should see the name of your new hard drive.
Thanks & Regards
Rizwan.
Jan 31, 2010 | HP Pavilion a350n PC Desktop
I want to read the files of my old Hard drive?
ok you have a pc. now, plug the IDE connector to your old hard disk and plug the power connector also. Now, you have 2 hard disks. Your old hard disk must be plugged into the secondary IDE slot. Dont touch anything with your original hard disk. Just add your old hard disk to your PC through the secondary IDE slot and using IDE cable. When your Windows OS opens, you will see a new Hard Drive when you open My Computer. It could be Drive E, F or G
Oct 09, 2009 | Maxtor Hard Drive
Installing old maxtor HD on newr pc, have to change it to a slave
J50 is the one furthest from the power connector. To make it a slave remove ALL of the jumpers.
Jul 26, 2009 | Maxtor Hard Drive
How to detect the hardrive?
setup the first drive as slave ( sometimes No Jumper ) then the furthest away drive as Master.
If this fails, and you have 2 IDE Slots on the motherboard. ( Primary/Secondary ) Put 1 drive on primary as Slave. And DVD Rom As Master ( same Cable ) Then put second drive On Secondary IDE Slot. ( Set As Master Or Slave )
If none of these solutions Work For you, check to see if Both Channels are activated in the Bios.
Thankyou For Using Fixya.
Mike @ compurepair.
Jan 28, 2009 | Maxtor Hard Drive
Trying to add another internal hard drive to Dell Dimension 3000
Ok... one end of the ide cable goes to the board... make sure that's plugged in correctly and has a blue connector.... second... the last drive on the other end has to be the master... the drive before that is the slave... if that setup is not working ensure that the drivers are set for master and slave... also make the power is pluigged into both drives
Robert
Jan 24, 2009 | Dell Dimension 3000® Pentium® 4...
Hard drive short-circuit
Try taking the drive out of your computer and placing it in another computer as a "slave". Allow the other computer to boot up and seeif it recognizes your hard drive.
If it does, access your files that you need and copy and paste to an external hard drive till you can replace your computer with a new hard drive. It's worth a try.
Mar 31, 2008 | Computers & Internet
Dvd not read or played
Try to boot from the DVD rive by using any a windows installation disk. If you can't, then boot to windows and download and update your firmware. If still the same thing, load bios defaults, shut down system, unplug system from power outlet, push and hold down the tower's power button for ten seconds, replug system, turn on system, try to use the dvd drive. If still no go, replace dvd drive.
Feb 18, 2008 | Acer Aspire™ T180 PC Desktop
Maxtor Diamondmax 80GB ATA 133 help!
there are several programs you can use to get your data off.
You will have to slave your new drive on to the IDE cable that your old one is on, you can then use symantec ghost to clone the old drive to the new,
Acronis true image is the other program you can use, put acronis true image on the new drive and the slave the old drive and take and image of it then recover it to the new drive.
Hope this helps
Dec 06, 2007 | Maxtor (L01P080) 80 GB Hard Drive
Computers & Internet Logo
151 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
