Question about Pride Mobility Products Legend 3-Wheel Scooter w/35 AH Batteries & Charger + Flat Free Tires - Color Viper Blue -Brown Fabric Seat Coverings
I need the electic input/output specifications for 3 wheel legend scooter \r\ncan you assist me please.the original transformer is 115V -1.5A-60HZ I"am using my scooter in Israel where voltage is 220V. Thanks Meshulam Druckman. e-mail; meshrox@hotmail.com
    Problem Solver:
  • 11 Answers
Please visit:www.alldatasheet.com its free Colin
Posted on Mar 12, 2011
Has anyone a circuit diagram and possibly information about the transformer output voltages for a Pihsiang mobility charger model MB-24/3 battery charger?
Hi again i have no data on Ac voltage output AT A GUESS I WOULD THINK IT WOULD B APROX 35 TO 38 VOLTS one thing i did find u can still buy them at MONSTER SCOOTER PARTS ITEM NoCO4-1179 PRICE $183-99 PHONE NUMBER 800-798_0325 GOOD LUCK. input : 100-120 VAC, 50/60Hz 1.5 AMP. U CAN BUY NEW ONE'S ON E/BAY,,..hi output is 24 volts 3.0 amps hope this helps..........
Dec 11, 2015 | Health & Beauty
I need to buy a power cord for the 11-410
just make sure the specs for the replacement plug is correct:
AC ADAPTER
input: 110-115V 60Hz
output: 12V 500mA
pin size that plugs into the unit ~ 9mm or a bit tad over 3/16"
with that adaptor, it takes up to 36 hours to charge it up to FULL
with a comparable DC adapter, it takes only 8-10 hours
Dec 17, 2012 | Power Center Jumpstart 11-411
I have a Ferguson step down transformer that takes input as 240V and outputs 115v The model is : TS 115/2000EC I need the wiring diagram for the output side
If it is 240 to 120/115, there should be two high side wires and two low side wires and ground wires, isn't that true?
Please post back, thanks.
Gary
Mar 20, 2011 | Vacuums
Where is the fuse inside the power supply model fsp200
The unit is only 200watt and the fuse cost about $2,Thats if there one built into it,
The replacement power supply is about $20-00 NZD
Probably 20minutes to fix (for a novice) depending on their skill level and tools available,
BEST ADVICE Replace it
Power is something you dont want to mess with because it can kill.
The power packs are replaceable but people arent.
Be very careful and dont mess with the power.
I am an Electrician and I respect power.Misterdj
Mar 24, 2010 | AOpen (FSP200-60SAV) 200-Watt Power Supply
Hp Pavilion getting no power after relocating pc.
the Power transformer has diferent outputs, +5V,-5V,3V,12V and so on.., but has a standby output a low power 5v to power button function.
Your PC have Power supply Defective,
so your must find a usual spare power supply on the market, compatibilty as 115V input and more of 350W power, to have stabilty.
Nov 29, 2009 | HP Pavilion a1519h (EX271AA) PC Desktop
Pride Legend scooter won't hold charge
check the wiring from the batteries as a wire could have come loose.
Regards
GeWiz
Sep 23, 2009 | Pride New Mobility Legend 4 Wheel Scooter
The original power specs
As I search the internet I found out no replacement for this kind of the adaptor model number 090-02180-13, there are some people looking for this kind of adaptor is a faulty a pervasive problem with the TV. There are literally hundreds of complaints on the internet. Most deal with a faulty AC Adaptor and the inability of the company to provide a replacement part.
I have a solution for this adaptor problem we better improvised the parts inside. The faulty parts of this adaptor arise in the transformer. This transformer is easily to burnt because of lower amperage. So we make it higher amperage so it can resist the load heat and cannot burnt easily.
Maybe you can do this for yourself, open the adaptor case, when open already look for the transformer, the visual picture of transformer is a bulky metal with many windings. Take this out and bring it to electronic shop that know how to rewind a transformer. Tell them to reworks or rewind the transformer, only the output voltage will be change input is the same. This is the
NEW SPECIFICATION:
  • INPUT 100-240 V
  • OUTPUT + 24VOLT DC AT 12 AMP
  • 12VOLT AT 6 AMP.
This is the result of new specification when the reworks or rewind is finish ,put it back to the adapter box,and then you can use it.This is higher amperage I mean it to you before,it can resist overheating.If ever happens that you can't find in your place know how to do reworks of the transformer here in philippines i do the rewind or reworks of the transformer ,but the problem is.very far to your place it needs shipment to carry this out .I price you 120 dollars including shipment and i assure it to you that adaptor will last long because of higher amperage .
When i search i found a site that can make an ac adaptor only you give the new specification and give where you are using the adaptor give the brand name PLTV-32 and they will make it..try this option also ..LCDPAYLESS.COM
Jun 23, 2008 | Protron PLTV-32 Television
DC Power supply specifications
here is the info you need...
Input Power 100~240V, 50~60Hz
9V DC,1A Max
Hope this helps...
Feb 09, 2008 | Computers & Internet
50Hz to 60Hz conversion
Hi, Your idea is basically sound and should work as long as the UPS originally is designed to produce 240V 60Hz and has its own built in timebase. The reason is that the input as long as the voltage matches makes no difference (50 or 60 Hz). By design, the UPS converts the input voltage to DC to charge the internal battery. The battery then powers an electronic circuitry that produces the 240V 60Hz. The input is then isolated from the output in terms of frequency. This is a common design, however, there are some (not many) that uses for its local oscillation sampling from the source and therefore will replicate the input frequency to its output, but very rare; it's better that you know they exist. Hope this be of some help/idea. Post back how things turn up or should you need further information. Good luck and kind regards. P.S. The only problem with 50 and 60 Hz is heat buildup which is tolerable and still within safe parameters. The only time the 50/60 HZ makes a big difference is when motors are used, timers such as in the early designs of microwave ovens, washing machines, etc., pumps and other highly inductive consumers. Most electronic devices converts the AC input to DC and therefore the frequency has negligible effect. Of course others may see it differently.
Sep 15, 2007 | Liebert UPStation GXT2700RT-208...
Pride Mobility Products Legend 3-Wheel Scooter w/35 AH Batteries & Charger + Flat Free Tires - Color Viper Blue -Brown Fabric Seat Coverings Logo
29 people viewed this question
Top Pride Mobility Products Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
Robin Hill
Robin Hill
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
