Question about Tefal Avant Deep Fryer
T-Fal Avante' deep fryer
My deep fryer lid will not remain close. Unfortunately, the latch is unable to hold onto the piece it latches onto due to a small area of the piece is chipped. Is there any way I can replace the lid? If so, what site could I go to.
Thanks,
Kirk
  • 52 Answers
SOURCE: Rival Deep Fryer -CF 153-WM
MarBeck.com - Small Appliance Replacement and Repair Parts 800-959-5656 M-F 8-5 CST Should have it. Good luck and pls review me if this helps
Posted on Jan 30, 2008
SOURCE: cool touch t-fal deep fryer
Try this it is for another model.
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000010517.pdf
It a 12 page manual.
Posted on Jul 27, 2008
SOURCE: Need to find an instruction manual
I need an instruction, anybody out there got a spare or knows where I can can get one?
Posted on Oct 31, 2008
konzzz
  • 255 Answers
SOURCE: Power cord fpr a T Fal FR4015
if you can't find one, make one.that's my motto.anyway, write the specs of you deep fryer and bring it in a hardware store.then, ask for wires, like duplex wires, that is heat resistant.then, a heavy duty plug.duplex type wires are two wires combined only separated by insulation,like the cord of your tv set.then to connect it to your fryer,just follow the cord where it is hooked, replace it with your new custom one.i say custom because you made it yourself.i hope this help.
Posted on May 15, 2009
  • 17 Answers
SOURCE: How do I find a power cord for teh T-Fal Deep
These two websites sell T-Fal parts:
http://www.thegourmetdepotco.com/store/store_partaccess_index.asp?ManufacturerID=26&CategoryID=32
http://www.smallappliance.com/department.asp?cur=USD&cam=drg_247-10231&sid=18956&mid=32&gid=18963&shopBy=Brand
I also found a few on Amazon.com:
http://www.amazon.com/s/ref=nb_ss_hg?url=search-alias%3Dgarden&field-keywords=t-fal+deep+fryer+power+cord&x=0&y=0
Hope this helps!
Posted on Aug 02, 2009
My vulcan lg 300 deep fryer latch won't turn what should I do
Some fryer valves have a safety lock, usually a slide on the handle near the valve body that must be released to open the valve. Check for this first. It's very rare for a fryer valve to stick unless it was forced shut with something partially blocking it. If not, let the fryer cool completely. Dip as much oil out as possible. Then disconnect the gas line and, with help, turn the fryer upside down draining the remaining oil into a suitable container. At this point, you have little to lose. Take a large wrench or piece of pipe to get more leverage and try to force it open and free it up. Do not use so much force that you damage the kettle. If you get it free, check to see that it does not leak before putting oil back in the fryer. If it leaks or fails to come free, replace the valve.
May 23, 2014 | Vulcan Kitchen Appliances - Others
The gas lid cover latch is broken
The dealer or an auto salvage yard is the only source.
Oct 31, 2012 | Cars & Trucks
This morning I opened my trunk to my 2055 Pontiac Sunfire and when I went to close it the black casing around the latch on the frame of the car came off so I put it back on and when I went to close the...
You may have inadvertently locked the latch when putting the plastic piece back on look at the latch mechanism and where the latch locks on the bar put a screw driver in the latch mechanism and then operate the lat to open it should open up then try shutting the trunk lid do it with the plastic piece off first to be sure thats the problem because if you have the plastic piece on you may make it nearly impossible to open it up. Then if it works put the plastic piece back on then make sure the latch is open and then close it does it work? if yes you did it if not write back to me for more help. Thanks for using fix-ya.
Apr 23, 2010 | 2005 Pontiac Sunfire
Trunk lid won`t close
make sure the latch isn't already in the closed position. next if you've already slammed the truck several times and haven't broke the latch yet, you may have bent the latch that's attached to the truck lid as the sheet metal in this area is very flimsy. using a flash light , slowly close lid while peering in to see if the latch is lining up. you should be able to tell if its bent and in which direction. i had this similar problem and i simply grabbed a hold of the latch and pulled it forward, bending it back into a position where it will line up and latch on bottom piece. ( the part attached to the body and not the truck)
Jan 11, 2010 | 1994 Buick Roadmaster
B1765 tefal Kettle lid will not remain closed. I
Use a dremel and cut 2-3mm of the plastic away from each side of the sliding latch. This allows the latch to extend to its normal position. Works as new!
Oct 31, 2009 | Tefal Kitchen Appliances - Others
I have a mdl CZF725 rival deep fryer and the lid will not stay down.
The problem is that the heating element and front control panel is not sitting in correctly. Remove the heating element/front control panel. Grab the heating element and gently pull it away from the control panel. Use care as you can break the elements off of the control panel. Reinsert and attempt to close the lid. If it does not close, then repeat this process being careful to not over bend the elements. The lid uses two plastic extensions to latch to the control panel and if the control panel is extended away from the fryer front, the lid will not latch. Also the fryer will not work as there are sensors in the control panel to sense if it is close enough to the fryer.
Jul 18, 2009 | Rival Kitchen Appliances - Others
Trunk will not latch?? or stay shut
I bought some grease and sprayed all the trunk latch pieces but then I found out the problem. On the bottom part of the latch [not the lid but the attached part] there is a spring that has a rubber pad that has to be compressed when the lid closes to completely latch. I noticed the side of the latch on the trunk lid had scratches from the latch slipping past the rubber pad on the spring. The solution was easy. I took a screw driver and wedged the padded area so it would make direct contact and now it latches just fine.
May 20, 2009 | 2006 Kia Optima
Jetta 2003, trunk won't lock
More than likely the spring inside the latch has come undone. To save some money you can remove the latch from the trunk, open the latch and reset the spring. To Remove the latch you will need to remove the carpeted cover on the trunk lid (there are about 10-15 phillips screws holding it on.) Once the cover is off disconnect the rod going to the latch by opening up the clip thats connected to the actuator. Disconnect the wire harness, Remove the 2 10mm Nuts holding the latch to the lid. Remove the black plastic cover on the latch and remove the electrical piece (the plastic cover wraps over the latch and is secured buy 2 plastic pressure snaps). Look down into the latch and you should see a small spring...on my Jetta the spring wasn't connected. take a small pointed object ( I used a light tester) and reattch the spring to the black hook. Mine had some broken plastic in it and After I removed that it worked fine. Once the spring is back into place reassemble the trunk and you should be good to go. No money spent, and it only takes about a half hour or 45 mins to do.
Dec 01, 2008 | 2003 Volkswagen Jetta TDI
Tefal Avant Deep Fryer Logo
63 people viewed this question
Top Tefal Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
paul
paul
Oscar Netto
Oscar Netto
Are you a Tefal Kitchen Appliances - Other Expert? Answer questions, earn points and help others
