Question about Eclipse 21000 8-Band Car Equalizer
I need to know the scematic of the 4 wires that power it up which one goes where
Hi, I have a LXW18JEZRW-1 model regridgerator and the relay got burned. I called the technician and told me that the relay and the protector needs to be replaced. He took the damaged parts off and left. He...
there should be a scematic located on compressor terminal cover. one wire will be for common designated c the other two are for start winding s and run winding r . Do not cross up wires to start winding and run winding as this will burn out compressor. follow scematic and all should be well.
Dec 25, 2010 | Refrigerators
Battery goes dead intermittently after parking
drain in your wires, if you have had altinator tested and a new battery also new voltage regulator if equip. check for bare wiring use a load tester and measure the load some times it might be a acc.light stuck on or a pinched wire find a wire scematic and find how your vehicle is wired
Oct 07, 2009 | Lexus IS 350 Cars & Trucks
I need a scematic for the Frigidaire FP170TT-1. I want to replace the defrost timer but need to know where to put the floating wire on a universal replacement timer.
If the actual plug for the timer , has a white wire at one end , then it goes : term1,wire2,term3,space,term4 , extra wire on the timer goes to term2 . If no white wire in the plug , then the extra wire goes onto term4 .
Sep 20, 2009 | Refrigerators
I need to know what color are for what on my radio wire harness
Not for sure if I can help.Someone forgot the golden rule.NEVER CUT THE WIRING HARNESS.I dont have the wiring scematics in front of me but the older models had RED for power,BLACK for ground,and the wiring going to the spreakers should be an off color running together going to the speakers.Probably has a six speaker system.Hope I helped.
Feb 03, 2009 | 1994 Chevrolet Camaro
How do you wire up 2 4 ohm dual voicecoil subwoofers for 1 ohm?
Both + on Both Subs to + Terminal on amplifier.
Both - on Both Subs to - Terminal on amplifier.
Jan 15, 2009 | Kicker DCVR124 -- 4 Ohm Dual 12in CompVR...
Scematic
Hi there!!
If you have an echo board what kind is it? I can give you the connections and where they go it just depends on which echo board you have!! I can also tell you where that talkback goes!! Let me know
Dennis
Dec 10, 2008 | Cobra 148 GTL 120-Channels Base CB Radio
Eclipse 21000 8-Band Car Equalizer Logo
Top Eclipse Car Audio & Video Experts
xxxxxx xxx
Are you an Eclipse Car Audio and Video Expert? Answer questions, earn points and help others
