When wash is done d2 is on d3 is on red and d4 is on and door want open
    Brigadier General:
  • 6,277 Answers
Sorry you do not state the make and model of your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
Here are my complete, general pre-typed guidance notes for checking filters and motors ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 12, 2011
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 12 Answers
Sounds like the button/switch for your door is either dirty,jammed or broken or the relay is going bad. try shutting it off for 30 seconds then try the door again otherwise you may have to call in a tech
I have a 95 silverado c1500 with 4l60e trans and it wont go into overdrive
overdrive is the fourth gear.D1,D2,D3,D4 now drive truck at 80 kmh
cruise at steady speed no fuel pedal movement, downshift from D4 to D3 you should feel RPM raise .. after push brake pedal a little you should see RPM raise 300 to 400 rpm.
shift pattern is 1st gear ,second gear,3rd gear and lock up(torque converter clutch). 4th gear with lock up
hope it helps
Mar 29, 2014 | 1995 Chevrolet C1500
Honda civic automatic transmission work
Check all trans sensors if it’s high mileage and fluid has not been changed regularly then you can bet a complete $2,000-$3,500 rebuild is due!
Jan 11, 2018 | Honda del Sol Cars & Trucks
What causes the D4 shift light to stay on?
Check tranny fluid--motor warm in park
Oct 02, 2017 | Cars & Trucks
How to Drive Auto Transmition 30 km Speed D3 Or D4
some people will tell you that d3 is for town and d4 for the open road,that is totally wrong.D3 is for engine braking when going down a mountain(saves the engine/gearbox doing too many changes)so leave it in D4 for everyday use.....also saves you fuel..
May 28, 2010 | 1994 Honda Civic
I have a 1995 honda accord and for some reason the car drives better on d3 is this okay to do or do i have to drive it on d4 and what are these d4 d3 d2 d1
The d is for drive, the number is for what gear you are using.Driving in 3rd gear all of the time will decrease gas mileage, and increase engine wear, but as long as the engine rpms aren`t too high there is no immediate damage.
Oct 27, 2009 | 1995 Honda Accord
92 honda accord ex - No power on D4..
D4 is slipping and not engaging. This means you need a transmission. you're losing a gear
Jul 24, 2009 | 1992 Honda Accord
Starview codes
5A 01
98 B0 BA 52 D3 21 08 D4
D2 EA 29 B7 B5 52 E9 AD
WORKING FOR ME AT 5.20PM
Nov 29, 2008 | StarTech.com StarView SV211K 2-port KVM...
Cannot solve game 100 on Professor Layton & the curious village
imagine the dots as a complete grid A-F across the top and 1-6 down the side now join the dots like so A1-B1,B1-B2,B2-A2,A2-A1///C1-E2,E2-D4,D4-B3,B3-C1///D1-F4,F4-C6,C6-A3,A3-D1///
E1-F2,F2-E3,E3-D2,D2-E1///C2-F3,F3-E6,E6-B2,B5-C2///D3-E4,E4-D5,D5-C4,C4-D3///
you should have only 4 dots left to join,good luck
Nov 26, 2008 | Nintendo Professor Layton & the Curious...
I just picked up a 87 honda accord and just want to know what gear i drive it in it has l2 d3 and d4 can you help got me confused
D4 - this gear means that all four automatic gears will be able to work (1,2,3,4)
D3 - Three gears will be able to work (1,2,3)
D2 - Two gears (1,2) - L2 means the same thing
D1 - One (low) gear (1)
For your car, drive it in d4. this means that all forward gears will work, including overdrive (4th gear). It will be fine to leave your car in this gear.
Jul 20, 2008 | 1992 Honda Accord
Washing Machines Logo
21 people viewed this question
Top Washing Machines Experts
