Whirlpool top load washer
I'm trying to figure out how to remove the agitator in my Whirlpool top load washer. The instructions that I have say simply to insert a screwdriver into the outer cap or dispenser and pop it off. The cap that I have to remove is one piece...and I have been trying to pry off the whole top portion...the 2 inch or so upper cap...but with no success. Can someone help me here???
Thanks!
Bill
  • 246 Answers
Bill,
On most top load whirpool washers (not including the calypso or the cabrillo) there are 2 main styles for getting the agitator off.
The first and easiet are for the older styles. This will be easy to identify as there is a green ring around the fabric softner dispenser holding it on. Raise the ring up and the dispenser will come off. Underneath you will see a plastic cap. Pry this off with a small flat hear screw driver. Underneath there, there will be a 7/16" bolt. Take it off with a rachet and lift the agitator from the bottom and out of the way.
The second and slightly more complicated method is for the new style. This can be identified by the 4 evenly spaced slots just underneath the fabric softner dispenser. First gently rock the top of the fabric softner side to side. the white top should come off as well as a clear plastic cup underneath. You will be left with 4 white plastic shafts sticking up just above thse slots mentioned earlier. Taking care not to break these shafts, rotate the remaining top piece of the agitator counter clock wise. Once it rotates, pull/ pry it off. Underneath there will be a clear plastic cap with 2 tabs on it. Pull the cap off by these tabs. Remove the remaining 7/16 bolt underneath and lift the agitator off by the bottom.
There are many variations of agitators, but one of these 2 methods (or even a mixture) should get you taken care of. One other thing to mention. Once you take either of the perviously mentioned styles off, you may find a white square hole under neath the dispensers. With this style, you use a 1/2" rachet to unscrew it counter clockwise and the 7/16 bolt is underneath.
If this doesn't seem to match what you have, get me the model number (just underneath the lid to the center rear) and I can get you some step by step directions just for your model.
Posted on Aug 01, 2008
Cannot remove top agitator from bottom agitator on whirlpool ultimate care 2
Easy once you have removed the agitator put both feet on either sides. In other words hold it down and pull. The factory tabs needs to be broken. If that fails used a long screw driver and try and break off the tabs.
Apr 28, 2014 | Whirlpool Ultimate Care II LSQ9564J Top...
Agitator Replacement (have parts)
See the Whirlpool Service manual for the Cabrio washer:
The Sears Oasis is basically the same machine:
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/409753510a90c8be852571e90073421b/$FILE/8178583.pdf
May 19, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
My washing machine spins but does not aggitate what do i need to do?
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
Also see the Whirlpool / Kenmore installation and operations manual for top load direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Also look at the Whirlpool parts list for top load direct drive commercial washers (the consumer model is basically the same.)
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
The Whirlpool / Kenmore top load direct drive washer uses an agitate shaft from the transmission with splines on its' top that fit into slots in the agitator. If the slots in the agitator are damaged / worn, the washer may not agitate.
Remove the fabric softener dispenser, remove the top agitator cap (a short screwdriver works well), and you'll see a 1/2" square drive bolt. Use a 1/2" socket extension to remove the bolt, pull up on the top agitator and carefully turn it over. You should see four plastic "dogs" that allow the top agitator to turn one way only. If they are worn, they are easily replaced.
After removing the top agitator, you should see a bolt (I think it's 5/8").
Carefully remove the bolt and the rubber washer under it and the main agitator should come off. You'll see the top of the transmission agitator shaft with it's splines. Check them and the slots inside the main agitator.
If the splines on the transmission agitator and main agitator are OK, the washer spins and drains and the timer moves through its' cycle, the problem points to an agitate gear in the transmission itself.
See the parts PDF for the transmission.
Replacing the gear in the transmission is a bit complicated (and messy) but it's a lot less expensive than a $170 transmission.
If you decide that you want to work on the transmission (it's not really that hard) post another question on Fixya and I or someone else should be able to walk you through it.
Oct 09, 2009 | Kenmore 24032\24036 Top Load Washer
How do i remove the agitator on my whirlpool ultimate care II top loader washer
first you remove the cap on top of the agitator then you remove the inner cap then you use a long extension with a 7/16 socket to remove the bolt the agitator will pull right up
Sep 21, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool topload filss, will not agitate, spin or drain.
This sounds like you need a new motor coupling and an agitator repair kit on this unit. We have parts and will be happy to assist you with your repair.
When you purchase your parts through us, we provide part removal/installation instructions.
You may contact us at:
WWW.Accurate-Appliance-Service.com
We look forward to working with you and hope this gets your washer in good working order again.
Have a great evening, Ella
Apr 16, 2009 | Whirlpool LSR5132PQ Top Load Washer
Top agitator won't spin
Your agitator dogs must be replaced.
With a flat blade screwdriver pry off the top cover on the agitator.
Remove the 7/16 bolt inside.
Pull up on the agitator and remove it.
Purchase the agitator dog kit from the appliance parts store.About $10.00.
Mar 10, 2009 | Whirlpool LSB6200KQ Top Load Washer
Clothes mover of whirlpool top-loading washer is loose. Agitates.
You need to replace the agitator dogs inside the clothes mover (agitator). take of the top then the cover, remove th bolt and take the top half off. you should see four "dogs" that need to be replaced.
Jan 25, 2009 | Whirlpool LSQ9600L Top Load Washer
My Whirlpool washer won't agitate or spin . But it does drain the water.
i also had the same problem, and it ended up being the coupler. It was not hard to replace, it cost me about 19.00. I didn't follow full recomende instructions. I tipped the washer backwards. Removed the drain pump and the motor itself. Then I removed the old coupling and placed the new one. The washer is working like new...
Oct 18, 2008 | Whirlpool LSR5132PQ Top Load Washer
TOP LOAD WHIRLPOOL WASHER BRAND NEW CRACK IN OUTER PLASTIC TUB.
loosen the screw bolt located at the back cover,it has also a plastic lock in the side to side of the plastic cover,find it by sliding a small flat srew.
Feb 21, 2008 | Whirlpool LSQ9610L Top Load Washer
Open Questions:
Washing Machines Logo
151 people viewed this question
Top Washing Machines Experts
