Question about Denon AVR-1907 Receiver
My outside volume control heats up and sometime my denon 1907 goes to protect mode.Please help.
    Brigadier General:
  • 8,546 Answers
It has a serious electrical problem. Keep a fire extinguisher handy.
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Posted on Mar 12, 2011
In denon avr 1907 amplifire after working10minets it trunoff why
Hi
possibility of turning off
there are several cases.
1.short circuit on one or more of the speaker wires.
2.overload and over heat turns the protection on.
3.parts need to be re-soldered.
hope this helps
Feb 24, 2016 | Denon Audio Players & Recorders
Denon AVR-2800
Hi, This is because your unit goes in to protection mode because of some bad connection in the input/output section .Disconnect your spkrs,inputs..turn the volume is Down all the way and power it up,Check your wiring for shorts at the inputs and outputs. at your service sreejith
Jul 31, 2007 | Denon AVR-2800 Receiver
Why do i have to power on and off my times with my denon receiver before it connects/
That is called the protection mode, Because of a internal problem with the amp, That is causeing it to over heat, End shut down,
Dec 02, 2012 | Denon AVR-1907 Receiver
Red power light blinking on my denon avr 1907, tried reset procedure, no speakers hooked up now and it still goes from green light to blinking red light and shuts off...Any clues?
This is a protection mode. The receiver protection circuit detects an internal problem like missing power supply voltage or blown channel and shuts down the receiver. You need to bring the unit to a repair facility.
Sep 26, 2011 | Denon AVR-1907 Receiver
Denon avr 1907 low volume on all chans.with the
Maybe the audio amplifier IC are fried and need to be replaced
Apr 22, 2010 | Denon AVR-1907 Receiver
Getting out of protect mode I have a Denon 787 receiver. It was working fine for 8 months. All of sudden, my reciever goes into protect mode after playing for about 30 min. Right after it goes into protect...
most of the receivers come with a cooling fan inside see if its working they usually work when you turn the volume up,, if its working that means you are playing it to loud if you lower the volume a little it will play just fine..( if the fan inside is not working thats the reason it goes into protect mode and it means you must have it repaired,, it goes into protect mode to prevent furter damage to the unit or the speakers,,
Dec 18, 2009 | Denon AVR-787
The receiver will not stay on. Has a flashing
Need more info here but it sounds like you have a short one one of your speaker wires that is sending the receiver into protect mode. The other option is that volume is too loud on zone one or two especially of you have multiple speakers hooked up to zone 2 and the ohm loads are becoming unstable.
Nov 22, 2009 | Denon AVR-1907 Receiver
Protect is ON
Either there is a bad capacitor in the protection unit or you can find the wire that goes from volume control to protection unit and unplug it.
You can also try turning the volume all the way off before turning on, then slowly turn up from there
Jul 20, 2009 | Denon AVR-900 Receiver
Denon AVR-1508 Receiver problems - cuts off and goes into protect mode
Usually when the unit runs for a while before shutting down there are two possibilities:
1) There is a small amount of DC current present that effectively heats up the speaker coils enough to cause a temporary short circuit that kicks in the protect circuit.
2) The output transistors or bias transistors are sensitive to heat and breaking down again causing the protect circuit to kick in.
A few experiments to try:
1) Does the time to shutdown change depending upon the volume level?
2) Is there any background noise coming from the speakers? Listen to a blank tape for example. Is there a hum or any other noise that you would not normally expect?
3) If you have a DC voltmeter, check for any voltage between the speaker lines.
Update this and we'll try to narrow this down.
Dan
Aug 18, 2008 | Audio Players & Recorders
Denon AVR-1907 Receiver Logo
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
