Question about Braun K 3000 Multisystem Food Processor
The rubber gear attachments with the grinding glass jar is somewhat burned because if i put the vegetable to grind it wont but if i will start the machine empty without any vegetables it works.Can you pls advice were i can get the rubber gear for the machine. Thanks
  • 4 Answers
Are you sure the rubber gear is burned? have you turn the plastic lock on the bottom, so everything is thight? have you checked that the plastic O-ring is well placed?
Posted on Mar 31, 2013
Kalorik blender replacement glass jar
I would guess pretty difficult to find if you can't get from the manufacturer. Have you contacted them yet? http://www.kalorik.com/site/
Apr 27, 2014 | Moulinex Food Processors
Tip
Bringing and blending aplliances
Generally, a blade or grinding or blending/mixing part that is permanently attached to a metal shaft from the appliance motor is held on that shaft by a 'shear pin'. This pin breaks when something is put in the appliance that the grinder, mixer, blender can't gring, mix, or blend. This is to protect the motor from overload. Afterwards, The motor will continue to turn, but the blade or paddle, or whatever will not turn.
The shear pin needs to be replaced.
The shear pin passes through one side of the base of the bade/grinder/paddle assembly, through the motor shaft, and out the other side of the blade/grinder/paddle.
The piece of the pin must be removed from the shaft, and from the two sides of the blending/grinding part. This is generally a press-fit, and some effort may be required to accomplish this.
When the pieces have been removed, a common 'roll pin' of the appropriate diameter should be inserted to hol the turning part on the shaft. It must fit tightly, and some effort should be required to insert the new pin. // '); }// ]]> Back to Edit // '); }// ]]> Publish preview_graphic.jpg
on Feb 07, 2010 | Food Processors
Replace processing glass jar for bravetti quad blade food process
type bravetti in search bar. There might be something you can use in your quest.
Apr 08, 2009 | Bravetti Quad Blade Food Processor
Plastic gear broke
So, rather than pay for an entire new motor and wait for two weeks forthem to get it to me, I just made a new gear/broken thing. I crazyglued the old piece back together again and used it to make a plastermold...like the way people do with their kid's hands. Then I filledthe mold with JB Weld and let it dry. After that, I drilled a hole inthe new JB weld gear so that it would fit over the metal part in thebullet(that actually spins).
Glued it on (with more jb weld) and the thing has been making my smoothies and grinding my coffee with no more issues.
Sounds complicated, but it wasn't too bad. Funny thing is, the newpiece is probably heaps stronger than the cheap plastic thing thatbroke in the first place.
Do it yourself, or e-mail me: sanfransimo@gmail.com
I'm tired of made-to-break products and could make anyone else one of these things for around 10 bucks!
Feb 14, 2009 | As Seen On TV Magic Bullet Food Processor
Grater/slicer doesn't spin on my Cuisinart BFP-703 food processor
The gear box spidle operates the regular s-shaped blade as well as the grating/slicing disc. Does the s-shaped chopping/grinding disc still spin? If not, you can get a new gear box. If it does spin, replace the grating/slicing disc - because the plastic may be cracked, as you say. All of these parts are still available from Cuisinart, so I'm not sure why they weren't any help - I've always been able to order from them.
-Tha Mp3 Doctor
Feb 01, 2009 | Cuisinart BFP-703 SmartPower Duet Food...
Food proccessor jar damaged
yes ask the shopkeeper to give u used one
Jan 12, 2009 | Siemens MK-22201 Food Processor
Cannot attach Cover to Base on "Vegetable Chef" with my Moulinex
do you know about this:  http://www.cpsc.gov/cpscpub/prerel/prhtml86/86051.html ?  It is a recall on the covers.
Dec 30, 2008 | Moulinex DG6 Food Processor
Bravetti Chopper Model FP 105H
Not positive as to your problem, but I was just given one of these and thought it didn't work. On closer inspection, I found a little switch that needs to be depressed from the bottom side. When I pressed it with a tiny screwdriver while holding down the bar on top, the motor runs!
I just have the white top with the motor and the glass jar thing. So I'm on a search for whatever is supposed to fit between them. There's room for a seal between the two, and I imagine it has something to push the tiny button, to activate the motor (guess technically it's a safety interlock).
In case it isn't obvious where that button is, turn the motorized plastic top upside down and look at the center. There's the star drive in the middle, and four little depressions, or holes around it. One of them isn't white inside. It's the magic switch! When I push it with a screwdriver and push the power bar, the thing comes to life...
If that works it for you, then your new mission is to figure out what pushes that button and put it in the right place.
Oct 21, 2008 | Bravetti SB212H Quad Blade Food Processor
Grind beef for chili?
The food processor will pulverize the beef in seconds if you do not pulse it. Really, the food processor will tend to make the beef very fine. You can use the 3mm or 4mm slicing disc to make more of a ground beef (noodle-like) cut.
-Tha Mp3 Doctor
Jan 29, 2007 | Cuisinart DLC-8S Pro Custom Food Processor
Food processor stopped working
hi there is no reset switch follow these instructions and it suppose to work http://www.useandcaremanuals.com/pdf/FP1300-1400Series791.pdf when you used it did you smell a burned stench? is the unit smells still from it? then probebly the coiles are burend - sorry cant help.... http://www.blackanddeckerappliances.com/customercare/home.jsp good luck
Mar 21, 2006 | Black & Decker FP1300 Quick N Easy Food...
Food Processors Logo
56 people viewed this question
Top Braun Food Processors Experts
eyecam
Are you a Braun Food Processor Expert? Answer questions, earn points and help others
