Question about LG 32LC7D Television
I have an LG 32LC2R TV. I was watching a DVD via that HDMI cable input and the screen just went black. There was power to the unit but no picture. Not sure about sound because I use sound from the DVD unit. I have looked on-line about help, but none really help. Can you give me some advise please? My TV is apart on my desk and I don't see anything out of the ordinary, no burned components etc.
  • 1,591 Answers
Try the solution I posted (click HERE) and see if that helps!
If not, post a note back here.
If the link doesn't work, paste this into your browser navigation address bar
http://www.fixya.com/PostComment.aspx?thid=8624692&prdid=920509&ctgid=101
Posted on Mar 12, 2011
Everything working fine, then home screen no longer displays on TV. On startup, pink dots go across TV screen, then TV goes black. Signal from most recent input is not coming trhough the audio or TV.
I have the same problem. I have an LG lcd tv as well. I have my cable box connected to via hdmi into the reciever then from reciever to the tv via another hdmi cable. I can watch tv and like the problem above see the pink dots on boot-up but I can't get the home screen to display.
Jan 08, 2013 | LG LHB975 Theater System
G'day, I have an LG HDD/DVD recorder (model RH298H) connected to an LG plasma screen digital TV via an HDMI cable. On the TV I have crystal clear digital television (and able to tune all the digital TV...
You have probably found out now that you would need to get your digital reception by connecting a set top box to the LG, say to AV1, then select AV1 when making a recording.
Apr 17, 2011 | LG RH1999H DVD Recorder/HDD Recorder
I have a 55" LG
Easy solution; this is a very common problem. Connect Cable or satellite box / DVR directly to one of the TV HDMI inputs. Connect an optical audio cable from that box to receiver so sound is surround through your speakers. You cannot connect DVR directly to receiver because the anti pirating chip will shut off the picture and produce a green or no screen at all.
You can, however, connect a BD (Blu-Ray) player via HDMI cable directly to your receiver without that problem. Connect HDMI output from receiver to a second HDMI input on the LG.
Contact me if you need more help! All the best, John
Nov 14, 2010 | LG INFINIA 55LE8500 LED HDTV
LG 32L4DS this is my TV... my wife was watching and the screen went black no picture no sound any suggestions or is it a recyclable?????
Tv now turn on,tv have power LED light indicator flashes?Tries tv unplug,replug it back like an hour later,the tv now,should resetting itself back to the factory setting.The tv should work now.Not,than the power supply board is dead.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Oct 25, 2010 | LG 32LC2R 32 in. HD-Ready LCD Television
How do i use it so my tv programming is in surround sound?
if the Comcast cable box has an HDMI output, it should connect directly to one of the TV HDMI inputs. Then connect the LG DVD unit HDMI output to the second HDMI input of the TV. Use two HDMI cables. Do not buy the expensive Monster HDMI cables. If you have already done so, I recommend you take it back for a refund, then buy the low cost HDMI cables which will work just as good and then you can bank the savings toward a new Porsche Boxter!! Now we have the video connected from both the cable box and the LG system.
Now--what do you do if the cable box does not have an HDMI output--just use its component output and your component cable (red, blue and green) to connect to the TV component input. This will still get the video to the TV and good HD pictures. Hum--do you have an HD cable box? You did not say and I just assumed that you did since you got the HDTV. If not, let me know with a follow up question and I will assist in that area further.
Now for the audio connections--The DVD player will not need any connections since it in the LG unit. The sound will come out the speakers when you start playing the DVD. The cable box is where we get the TV audio to feed the LG unit. If the cable box has an optical output, use an optical cable (again the low cost one)and connect to the optical input on the LG.
This will get the TV audio to the surround system. If no optical output, use the red and white (left/right) audio connections and connect to one of the two the LG audio inputs. To hear TV audio on the LG speakers, just switch to that input or the input associated with the optical input.
To watch DVDs, switch the TV to the HDMI input to which you connected the LG unit. For TV, go to the other HDMI input (or component input).
Switch the LG to the audio input to which you connected the cable box to get TV sound.
Hope this gives you food for thought. If so, and you have more questions, just come back in with a follow up.
Sep 11, 2009 | Audio Players & Recorders
HDMI, picture but no sound
Check the menus for both the DVD and TV to be sure that the audio is being sent thru the HDMI cable. Some sets and DVDs will separate the audio from the video be default unless told to send it down the HDMI. Update this if that does not resolve the problem and post the make and model of all gear in the chain.
Thanks,
Dan
Mar 19, 2009 | LG 32LC2R 32 in. HD-Ready LCD Television
I'm simply looking for the most efficient way to hook up my HD-TV with HDMI inputs to both my cable box (with HDMI inputs) and my DVD player/recorder so that I can record from the TV I watch.  ...
The way you have it hooked up right now will not work unless you have a coaxial out on your cable box going to the dvd recorder. Even then, picture quality will be severely degraded. The best way to do it is to leave your cable box hooked up to your TV via HDMI and connect your dvd recorder to your cable box via component video if your dvd recorder has a component video input. If it doesn't, then just use the composite video input. That way your picture quality will be better and you will still be able to record with the TV off.
Jan 02, 2009 | Insignia 37" LCD Flat-Panel HDTV
I have an LG LCD TV (42LC2D) & a LG HDD/DVD Recorder (DBRH197). The HDD/DVD is connected to the TV via a HDMI cable. Generally, when I watch DVDs, I change the Input on the TV to HDMI, however since...
First thing to do here is to check the connection adn if possible try a different cable , because sometimes this can only be a connection or a cable problem,, as for making it unlock so you can watch any DVD on it, there's a lot of site there that is offering that service to unlock the regional code of this unit...
Hope that helps.........
Sep 15, 2008 | LG Televison & Video
Hook up sylvania lc370ss8 LCD TV to a lg lht734 DVD home theater system
Hook a digital optic cable from the Tv's digital ouput to the Recievers digital sound in. This should fix it. You might have to switch the input of the reciever.
Mar 21, 2008 | LG LHT734 System
Lg 32lc2r, only showing picture in black and white
Make sure that the color control level is set to the default or 50% to start with. This should be in the Video menu.
The colour for the tuner and for the encoded base-band video uses a circuit area called the colour demodulator. It is possible that this cirucuit area has failed and needs servicing.
Jerry G.
Jan 08, 2008 | LG 32LC2R 32 in. HD-Ready LCD Television
LG 32LC7D Television Logo
206 people viewed this question
