The handle for the door has snapped off - Washing Machines
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 12 Answers
You can order replacement parts online from the manufacturer you will need the make and model number when ordering. you may also order from www. repair clinic.com which is usually cheaper and they have a how to site also. Good luck
Posted on Mar 12, 2011
2 Suggested Answers
SOURCE: The door handle of my
The same thing happened with my Indesit WD1. I now use a flathead screwdriver to open the door. There's a horizontal ****, about an inch high between the lever and the door (sorry, this is hard to describe). If you insert the screwdriver in the gap as far as it will go (at about a 45 degree angle to the door), then gently press the handle of the screwdriver towards the machine, you should feel the door release.
Posted on Jan 19, 2011
The door handle snapped off Servis Gem 1000
use a screw drive to activate what the handle would have done
if it is a simple push to close /pull to open handle ,then use something flat under the door lip and force it open with a twisting motion.
May 22, 2015 | Washing Machines
What part do I need? It opens from the inside. The handle is not snapped.
Are you saying the inside door handle isnt snapped,but the door wont open by pulling on the inside door handle or is it the outside door handle thats not working??Both the inside and outside door handle has a spring and other components on the backside of the handle which cant really be seen unless you remove the whole door handle assembly.One of these components are most likely broken or the rod that attaches between each handle and the locking mechanism(part that locks into the door striker to keep the door closed and releases it too)might have come loose from the back of the handle.The outside handle is usually mounted to the door by pop rivets or bolts/nuts.The inside handle is usually mounted with screws,but it really depends on what kind of car youre driving.Youll probably have to remove the handle to inspect it for damage.Open the door and watch the locking mechanism for movement while youre pulling on the door handle.If it doesnt move when you pull on the handle,the handle is definitely broke or the rod has come loose from the back of the handle.
Mar 09, 2015 | Cars & Trucks
Need to get door handle and window lever off 1963 pontiac tempest??
there is a special tool that slides in behind the crank and lever that pops the snap ring out the back side and they just pull off, then you put snap ring back on the handles and push them back on when ready
Jun 10, 2012 | Cars & Trucks
Repair driver side door
tHE DOOR PAIEL IS SURRONDED WITH 6 TO 8 PLATIC RETAINERS THAT SNAP INTO THE DOOR FRME.WHEN YOU TRY TO POP THEM OUT FROM THE DOOR FRAME BE CAREFUL NOT TO SNAP OF THE RETAINERS. yOU CAN DO THIS WITH A SCREWDRIVER. " may be a screw in the door handle or the pull handle. Sorry about the caps lock was on. hope this helps.
Tommy
Jan 07, 2012 | 2000 Dodge Intrepid
My inside door latch (driver side) snapped off...what do I need to do to replace?
Remove the inner door panel. The handle will now be accessable, just get one from the dealer and put it on. The door panel is held on with snap inserts around the perimeter of the panel about every 6" or so. There are also some screws in the arm rest and handle. A flat screwdriver slipped under the panel, starting at bottom, will release the snaps.
Sep 02, 2011 | Jeep Grand Cherokee Cars & Trucks
The door handle of my Indesit WD10 washing machine has snapped off. I have wet clothes inside. How can I get the door open and my clothes out? It snapped the plastic where the door handle connects to the...
Jan 12, 2011 | Washing Machines
The manual window handle on my 2003 Escort ZX2 snapped?
You will have to replace your "window regulator". Normal 0
Locate and remove the screws that hold yourinterior door handles in place (they may be hidden by snap in, or snap onclips). Remove the interior door handles. Your panel is held in place by snap in clips; use a small pry bar topull them from the door (try to get as close to, or directly under the clips toprevent them from tearing out of the door panel). Once the clips are pulled,pull the panel upward to remove it from the door. Once you have access to the inside of the door, you will be able to see the bolts that retain the window regulator, remove them, and replace the regulator.
Jun 01, 2009 | 2003 Ford ZX2
Need Help Putting A Door Handle On A 1996 Dodge Avenger
Start by disconnecting your negative battery cable. Then you need to locate and remove the screws that hold your interior door handles in place (they may be hidden by snap in, or snap on clips). Once you remove the screws that hold the interior door handles, remove any wire connectors to the handles. The interior door panel itself, is held on by snap in clips, and you will need a small pry bar to pull them from the door (try to gat as close to, or directly under the clips to prevent them from tearing out of the door panel). Once the clips are removed from the door, pull the panel upward to remove it from the door. After you gain access to the inside of the door, you will see a area for your new door handle to set in place and operate the door latch. Place your new door handle in place and tighten the nuts that retain it. If has a electronic key code, plug in the electrical connector.
Install everything in reverse.
I hope this helps you, and I wish you luck on your repair.
May 07, 2009 | 1996 Dodge Avenger
Driver's side interior door handle snapped off
there is plastic snaps that attatch the panel to the door all the way around the panel which you can buy a tool to remove the panel without breaking the snaps,the door handle may have a cable hooked to it that releases the latch and it might be stretched causing the handle to pull hard
Apr 24, 2009 | 1989 Ford F 150
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
