Question about Yamaha Audio Players & Recorders
Power come on then goes off - Yamaha Audio Players & Recorders
    Brigadier General:
  • 8,546 Answers
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Posted on Mar 12, 2011
Printer goes off and never powers back automatically
Check the wakeup settings on the printer. Some were shipped with sleep mode on, but all all wakeup events disabled.
Oct 28, 2014 | HP LaserJet Pro 400 M401DN Mono Printer
When I press power, light blinks for about 15-20 minutes, then goes off. Press power again, on solid for 30 seconds, then goes off. Press power again, TV finally comes on.
Your television is in need of repair. Hard to tell what exactly needs to be repaired but when the power light blinks in that way then this is the TV's way to tell you it needs to be serviced.
Apr 25, 2010 | Toymax Magnavox 37MF331D 37 in. LCD TV
Power light comes on and then goes off.
power light comes on and then goes off
Dec 08, 2009 | Acer Aspire 3680 Laptop
View Sonic VA720 monitor goes out after power goes
replace the logic board, not the power supply board. you can find logic board on ebay as low as $29...
Nov 15, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
CASE WIRES TO PANEL1 CONNECTIONS
The hdd red wire gooes to pin #1 the hdd white wire goes to pin #3 the power sw orange wire goes to pin #6 the power sw white wire goes to pin #8 The reset sw blue wire goes to pin #7 the reset sw white wire goes to pin #5 the power led green wire goes to pin #2 the power led white wire goes to pin #4.
Now the layout of the pins is the long row (5) pins are the odd number pins 9 being the odd one and 1 is the other end of the row. 2 through 8 start at the pin accross from 1 : : : : . I hope this helps you.
Aug 22, 2009 | PC Chips MB PCCHIPS SiS746FX M848A V5.0...
I have a denon avr amp it powers up then goes in
disconnect all connections cycle power if the power stays on reconnect equipment one at a time cycling power after each peice reconnected. If the power goes back to stand by with nothing connected the reciever needs repair
Jul 18, 2009 | Denon AVR 2808Ci Receiver
Power goes on and then clicking noise in back and power goes off. jvc hd rear projection
this sounds like a power source problem! also the flyback converter on the circut board could be bad!
Dec 10, 2008 | Televison & Video
35 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
