Question about Plantronics Backbeat 903 Bluetooth Wireless Stereo Headphones Headset
I am not able to connect the headset and my BB
    Prodigy:
    An expert who has answered 500 questions.
  • 537 Answers
Remember that newer phones are like small computers, so they may become corrupt over time and you may need to reset them every so often. Simply turn your phone off and remove the battery for a few seconds, then replace the battery and turn it back on again. If this does not resolve the issue, delete any pairing information for your BackBeat 903 headset and pair it again with your phone, carefully following the instructions on the link below for the Plantronics BackBeat 903.
Plantronics BackBeat 903 User's Guide
Good luck from Headsets Direct!
Posted on Oct 25, 2011
Music player through my bluetooth
Hi Mike Cronk,
I see that you have a Bluetooth Headset and that you are tryingto connect it to your BB.
You mentioned it will not play or you cannot hear Audio From it from your BB?
Did the Bluetooth Headset sync to your BB? you need to make sure that the headset is sync properly on your BB and that the BB is dectecting your Bluetooth Headset. make sure that the BB is also set to be detected by any device for the Bluetooth to detect your BB as well for proper syncing of both devices.
try your Bluetooth headset on another devices as well see if it will sync to a different device just to see if the Bluetooth headset is working fine.
I hope this helps,
michaelvincentc
Dec 25, 2011 | Jabra BT2080 Bluetooth Headset
ATT BB Bold 9000 pairs with plantronics bluetooth headset fine but always drops connection when call is made
Make sure there are no other bluetooth devices interfering with the connectivity between headset and phone. Remove the Plantronics headset from the phone menu, if it's showing up. If possible, remove and re-attach the battery of the phone. Power off the headset. Pair the headset to the phone again and you should be okay.
Aug 11, 2011 | RIM BlackBerry Bold 9000 Smartphone
How do I pair a Bluechip BH20 Headset with Blackberry Curve
Manage Connections > Set up bluetooth > Search for device > Turn on bluetooth headset into pairing mode > Select on BB > Type in pin (usually 0000)
Feb 10, 2011 | Cell Phones
I can not pair my headset HS820 with my BB 8520. My BB does not recognize it...what can i do?
First Ensure that your Blackberry 8520 is in discoverable mode (Settings>Options>Bluetooth) once in Bluetooth hit Menu (the button to the left of trackpad, Select options to turn Discoverable on, once you have done that ensure your bluetooth is in Pairing mode (solid blue light, except Plantronics brand which will alternate Red and blue lights) then have the device search and it should find it, select connect, then enter the headset (typically 0000 unless Bluetooth owners manual says otherwise) and it should pair just fine from there
Hope This Helps!
William
Sep 20, 2010 | Cell Phones
How do I pair the h7oo witt the bb 8830
Depending on the phone... try and remove the current bluetooth device. Go to the Manage connection app and choose blue tooth. Or go to options, Bluetooth. you will then see what is or isnt connected. Close the headset. Go to the phone and choose discover, or search. Open the headset and press and hold the big button. It should then turn purple and should be recognized. After this, it will ask for a passcode.
Also make sure the battery on theheadset is charged before doing this.
The passkey will be 0000, four zeros.
Aug 04, 2009 | Motorola Mobility H700 Headset
Wont' pair with BB 8830
I had the same problem. Here is what you do:
When your headset is off push the multifunction (on/off) button and keep it pressed until the blue light turns solid blue (i.e. is not blinking). Now you can pair it and your BB will detect it. If you do not wait until the light remains lit it will not happen. Unfortunately this point is not well emphasized in the instructions of use for the device.
Enjoy
Dec 07, 2008 | Samsung WEP200 Headset
Plantronics p590 + BB Pearl
Pearl 8100 can not output media audio to Bluetooth. Another BB might.
Sep 12, 2008 | Plantronics - Bluetooth Headset Plus Base...
Persin on other end can;t hear me!
Certain headsets don't work with certain phones. Your best bet is to look for a headset that other blackberry users have used. TRY HERE
Aug 13, 2008 | LG HBM 730 Bluetooth Headset Wireless...
Connect jabra to blackberry
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.
3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select BT150 once a connection is detected.
5.The passkey "0000" is now entered to confirm the connection has been made.
6.The cell phone screen will now read "Bluetooth Connection".
Tips:
1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works.
Thanks for using FixYa.
May 19, 2008 | Jabra BT150 Wireless Headset
Plantronics Backbeat 903 Bluetooth Wireless Stereo Headphones Headset Logo
227 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
skiffy99
skiffy99
Level 1 Expert
shaun taylor
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
