Question about Zanussi ZCG5001XN Gas Kitchen Range
The ignition switch it not work - Zanussi ZCG5001XN Gas Kitchen Range
2002 Olds Intrigue ignition switch does not work properly. Sometimes I have to "jiggle" it for several minutes before it will work. Yesterday I had to move the shift lever before it would work and t
there is no connection between the ignition switch and the shift lever. One turns the power on to run and start and the shift lever prevents start until neutral or park is set . Therefore it is possible that the fault is not in the switch but in the adjustment of the neutral switch on the transmission.
Jul 20, 2014 | 2002 Oldsmobile Intrigue
In my 1999 dodge caravan the ignition only turns the engine over after repeated attempts.
Sounds to me like the ignition switch itself. If there is no click or absolutely nothing and after several key turns it will work then the ignition switch itself is going bad. I'm not positive if this vehicle has a security key. If it does try another key if have more than 1 for the vehicle or get a replacement key. The ignition switch will either need replaced or could be the switch no longer able to read the security key if it has one.
Apr 21, 2014 | 1999 Dodge Caravan
I'm working on a 97 geo prizm and need to find the ignition relay,I rplaced the ignition switch and have no power getting to the switch,there is power at the harness and I can bypass the switch an
If you can jump it at the switch and get it to start, then the ignition relay must be working. It is hard to tell from your post but I think you are using power from another source to do this? I am thinking you have a blown fuse on the wire the furnishes power to you ignition switch.
Feb 12, 2012 | 1997 Geo Prizm
2002 Grand Prix heater/lights, My heater randomly works and if the heater doesn't work either does my head lights. I'm thinking it's my ignition switch?
If you mean that the Daytime Running Lamps (DRL) does not work when the blower motor does not work, then YES it COULD be an ignition switch problem. However, not very likely (please read on). The regular HIGH and LOW beam headlamps do not require the ignition switch to operate.
The main circuit that runs your regular headlamps also runs the blower motor HIGH speed. This has nothing to do with the ignition switch.
This circuit also operates the Power Mirror circuits and the Hazzard Flashers. You may want to check to see if these are also malfunctioning when this happens.
The Circuits for your other blower speeds go through the ignition switch along with the DRL control module, but your HIGH speed does not. So if it is your ignition switch, your HIGH speed should still work and your regular headlamps should still work. You will lose only your lower blower speeds and DRL if it is an ignition switch problem. You will have a bunch of other stuff going out if it is an ignition switch also. The ignition switch circuit that runs your DRL module also runs your Powertrain Control Module. So if it is an ignition switch problem causing your DRL to shut down, your engine will also be shutting down.
Jan 08, 2012 | 2002 Pontiac Grand Prix
My windshiled wippers ,heater, radio, and turn lights stoped working
THE TROUBLE IS YOUR IGNITION SWITCH. THIS IS NOT THE IGNITION KEY & LOCK CYLINDER. THEY WORK TOGETHER, BUT THE ELECTRICAL IGNITION SWITCH IS ON THE STEERING COLUMN UNDER THE DASH. YOU HAVE TO REMOVE THE LOWER DASH PANEL & LOWER THE STEERING COLUMN. TO GET TO THE IGNITION SWITCH. GET A NEW IGNITION SWITCH,TO SEE WHAT IT LOOKS LIKE. THE DIMMER SWITCH FOR THE HEADLIGHTS. IS MOUNTED PIGGY/BACK ON THE IGNITION SWITCH. IF YOU HAVE NEVER DONE THIS IT'S PRETTY TRICKY. THE ROD GOING IN THE DIMMER SWITCH WILL HAVE TO BE SECURED. IF IT FALLS OUT, THE STEERING WHEEL & A LOT OF OTHER NIGHTMARE STUFF WILL HAVE TO BE REMOVED, TO PUT THE ROD BACK IN PLACE. BOTH SWITCHES ARE ADJUSTABLE SO EVERYTHING WILL WORK RIGHT.
Jan 23, 2011 | 1993 Jeep Grand Cherokee
Headlights, fog lights, heater blower, wipers, temp reading in dash and gear indicator all not working. they all stoped working at same time. any help?
Sounds like your ignition switch shorted out - all of those functions only work with the ignition on. I'm betting your parking lights still work right? Change the ignition switch and I think you'll be set.
Nov 16, 2010 | 1998 Audi A4
Acura RL 2000 Remote needs Program Instructions
TURN ON IGNITION SWITCH WITH ENGINE OFF.POINT THE REMOTE TRANSMITTER AT CENTRAL LOCKING SIGNAL CONTROL MODULE LOCATED BEHIND PASSENGERS SIDE C POST.WITHIN 4 SECONDS PRESS LOCK OR UNLOCK.WITH REMOTE TRANSMITTER.WITHIN 4 SECONDS SWITCH IGNITION OFF.WITHIN 4 SECONDS SWITCH ON IGNITION WITH ENGINE OFF.WITHIN 4 SECONDS PRESS LOCK OR UNLOCK USING REMOTE TRANSMITTER.WITHIN 4 SECONDS SWITCH OFF IGNITION SWITCH.REMOVES KEYS FROM IGNITION SWITCH WAIT 10 SECONDS THEN TRY USING REMOTE TO SEE IF IT WORKS DOOR LOCKS.IF THIS PROCEDURE DONT WORK.TAKE TO DEALERSHIP.
Jun 22, 2010 | 2000 Acura 3.5RL
1991 Dodge Spirit ignition problem
The "SPRING-BACK" Action is Originated in the Ignition Switch itself (THE ELECTRICAL SWITCH) I think that is where you should Look. On these models, the ignition lock and ignition switch are removed as an assembly. Refer to IGNITION LOCK .
Disable airbag, refer to Air Bags and Seat Belts/Air Bags (Supplemental Restraint Systems)/Service and Repair . After procedure has been completed, rearm airbag system.
  1. Disconnect battery ground cable.
  2. Remove tilt lever.
  3. Remove three Torx column cover attaching screws, then the upper and lower column covers.
  4. Using tamper proof Torx bit tool No. 440-TX20H or equivalent, remove three ignition switch mounting screws.
  5. Carefully pull switch away from column. Release two connector locks on seven terminal wiring connector, then disconnect from ignition switch.
  6. Release connector lock on four terminal connector, then disconnect from ignition switch.
  7. Remove ignition lock from ignition switch as follows:
    1. With key inserted and switch in Lock position, use a small screwdriver to depress ignition lock retaining pin flush with lock cylinder surface.
    2. Rotate key clockwise to Off position. Ignition lock should now be unseated from ignition switch assembly. Do not attempt to remove ignition lock at this time.
    3. With ignition lock in unseated position (lock bezel approximately 1/8 inch above halo light ring), rotate key counterclockwise to Lock position, then remove key.
    4. Remove ignition lock from ignition switch.
  1. Reverse procedure to install, noting the following:
    1. Connect two wiring connectors to ignition switch. Ensure switch locking tabs are fully seated in connectors.
    2. Install ignition switch on steering column.
    3. On column shift models, shift lever must be in P position and park lock dowel pin on ignition switch assembly must engage with column park lock slider linkage.
    4. On all models, verify ignition switch is in Lock position (flag parallel with ignition switch terminals).
    5. Apply a dab of suitable grease to flag and pin, then position park lock link and slider to mid-travel.
    6. Position ignition switch against lock housing face. Ensure pin is inserted into park link contour slot.
    7. Install ignition switch retaining screws and torque to 12-22 lb-in .
    8. With ignition lock and switch in Lock position, insert ignition lock into ignition switch until it bottoms.
    9. Insert key, then while carefully pushing ignition lock toward ignition switch, turn key clockwise to Run position.
    10. Check for proper operation on ignition switch in all positions.
FOR PICTURES EMAIL ME AT MY NICKNAME HERE ON FIXYA @AOL.COM
Feb 12, 2009 | 1991 Dodge Spirit
Key for ignition
Ignition Switch
REMOVAL & INSTALLATION
  1. Disconnect the negative battery cable.
  2. Remove the steering wheel.
  3. As necessary, remove all under dash panels in order to gain access to the ignition switch.
  4. As necessary, lower the steering column to gain working clearance.
  5. Disconnect the ignition switch electrical connectors.
  6. Remove the ignition switch retaining screws from the studs. Disengage the ignition switch from switch rod. Remove the switch from the vehicle.
To install:
  1. Position the lock cylinder in the LOCK position.
  2. To set the switch, position a wire in the opening in the outer surface of the switch through its positions until the wire drops down into the slot.
The slot is in the bottom of the switch where the rod must be inserted to allow full movement through the switch positions.
  1. Position the ignition switch on the column studs and over the actuating rod. Torque the retaining nuts to 40-64 inch lbs. (4.5-7.2 Nm).
  2. Remove the wire from the slot in the housing. Continue the installation in the reverse order of the removal procedure.
Jul 17, 2008 | 1997 Ford Explorer AWD
Zanussi ZCG5001XN Gas Kitchen Range Logo
32 people viewed this question
Top Zanussi Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Zanussi Kitchen Range Expert? Answer questions, earn points and help others
