Question about Thomson Televison & Video
Model 27LCDB03B-simply appears to be "dead" won't power up-not the fuse
  • 979 Answers
Hello Chris, Hi, your TV's power supply section is not functioning properly. If the fuse is in good shape, then the auxiliary power section of the power supply is not functioning, this section powers the switching oscillator and IC that sends the pulse to the switching element like power transistors to create a main secondary voltage. the main secondary voltage is the circuit that produces all voltage needed source by the TV. what you can do if you are up to it.
A. Visualize any bulging capacitors, replace them. B. Measure the voltage across the following section in particular order so we can find the faulty parts.
  1. the AC input on the Power supply board. (none means open switch or power cable)
  2. the AC after the line filter circuit. (none means open line filter)
  3. the DC on the filter capacitor. (none means problem on the rectifier)
  4. then the AC on the switching element or input on the main transformer. (most likely you won't have any voltage reading hear.)if you do have continue.... (none means you scratch your head, this is the hardest part) check all low value resistors, high wattage resistors open or shorted diodes.
  5. the dc on the secondary filter capacitors.
If not have this checked by a technician, its to complicated for you.
Posted on Mar 12, 2011
It won't power on. It had a blown fuse.
Most likely you have a dead short on the front end of your power supply board. Unless you have electronics repair experience, this is not something I would do on my own.
Jan 31, 2013 | Philips 32pfl3504d/f7
27LCDB03B
does the power light change when you try and power up.
try www.tvs-services.com they may have a kit for this model which must be fitted by an engineer
Jan 14, 2012 | Thomson Televison & Video
2004 Jeep Grand Cherokee Laredo: electrical system starting to fail?? Hi! I hope someone can point me in the right direction :) I have a 2004 JGC-L that I LOVE, but the electrical system seems to be...
note that you never once said car can be driven? why?
job1, can you do job 1?
battery is going dead
if head lamps are dim its battery going dead, (not dash HEADs?)
notice is did not say battery was bad only discharged.
if engine starts is charge.battery lamp glowing.
i engine is dead, can crank it.
get a jump, call AAATOW
or find a loaned battery that is charged.
buy a battery charger and use it.
also cars can have phantom drains, as you sleep battery goes dead. (ask)
Mar 15, 2017 | 2004 Jeep Grand Cherokee
Pioneer 65" TV Model # SD-643HD5 won't power up.
I would suggest replacing the board itself, chances are what caused those fuses to blow is still faulty. did you check those fuses again after you powered it back up?
Jun 12, 2011 | Pioneer Televison & Video
MDR515h/f7 Dead....Think it is fuse? How can I replace it? THANKS
You can replace the fuse (if the unit is not under any warranty) by carefully opening the top cover - the fuse is a small glass tube in the power supply (near where the cord connects) check its rating and voltage (the replacement MUST match the original). You should be able to reach this easily without further disassembly of the unit.
If replacing this inexpensive part does not restore any power to your unit, then you have a faulty/defective power supply circuit - this should really be tackled in a fully equipped workshop with adequate facilities by a qualified technician; it is not meant for end-users to repair when it fails due to the potential dangers involved. Experience suggests in many cases a dead unit is not just a blown fuse, but a switchmode power supply failure.
Try replacing the fuse first - then consider submitting unit to a service centre for a quote, then you can decide afterwards if it's economical/worthwhile repairing.
Mar 20, 2011 | Magnavox MDR513H/F7 Player
Today when I went to turn on my dishwasher it made a few weird clicking sounds and then didn't start up. Now it seems "dead" and I can't even get any of the lights on the panel to light up no matter what...
Hi well i see this type of thing quite frequently, IF as you say there are NO LED's Lit at all. Then perhaps the circuit breaker or Fuse has, tripped, blown? Please check this, while at the Breaker box, recycle the Breaker, remove replace any Fuse.
See if this makes any difference? If it doesn't then unfortunately it appears that the main Board must have gone faulty, most likely in the Power Supply, if nothing is active at all.
If you wish to DIY, then you will have to obtain a service manual, simply Google, the exact name and model of your unit, and the words service manual after them, this should give you a link to a manual, sometimes, one must buy them. follow the troubleshooting steps in there, and then order the part and replace.
However if you do not wish to DIY, then my advise is to contact your local service agent and arrange for a service call, ask for a "Quote" before allowing any work to start.
Sep 04, 2010 | Dishwashers
Unit dead after power surge Model Pv7451 tape inside unit
Sounds like a blown fuse. If the fuse is ok, then the power supply is completely dead, probably blew out the power IC. You should at least be able to get the tape out by simply manually turning the tape deck motor until the tape releases and exits the machine. It isn't always easy and can take a while to do if your turning it by hand, but it always works.
Mar 21, 2009 | Televison & Video
MY THOMSON SCENIUM BOARD IS DAMAGED!!
CALL 01245392539 AND THE UK THOMSON SUPPLIER WILL BE ABLE TO TELL YOU IF IT IS STILL AVAILABLE
Feb 11, 2009 | Thomson LCDB 03B 27 in. Television
Televison & Video Logo
253 people viewed this question
Top Thomson Televison & Video Experts
 Grubhead
Grubhead
Are you a Thomson Televison and Video Expert? Answer questions, earn points and help others
