Question about Pioneer PDP-4360HD 43 in. Plasma Television
I have a Pioneer PDP-R05G media receiver and PDP 435-PG plasma display. After power up the tv turns off after about 2 seconds, and the media receiver green power light flashes 8 times then pauses and cycles again while the Plasma display power light returns red (as if on standby). the unit has not been used for approximately 3 months but was working fine previously.
  • Pioneer Master
  • 12,061 Answers
This is a classic "Hic-upping" switchmode power supply problem. The protection circuitry inside the SMPSU, has sensed a severe potential problem, and is attempting the shutting of the set, down to avoid a fire, explosion, or both.
This set had developed a problem, that is so severe that the set must be shut down, (This set should be removed from the Power),
What is happening is the internal "Fault" that is causing the Protection Circuitry , to detect the problem and attempt to shut down the set, keeps restarting the set, because as soon as it shuts down, the "Faulty" component(s) cool down?, and the "Fault" ostensibly "Clears" so the PSU starts up again, only for the component(s) to heat up, whatever, again and fail, so it shuts down, and if left unattended, this would continue on until the part eventually failed. As related this is called a "Hic-upping Power Supply". Any fault that involves the power supply is usually quite serious, and needs a professional, usually, unless one is familiar with servicing current day, televisions.
And in my professional recommendation, you should get a "Quote" for repair, from, an, Approved Service Center. Now, this point is very important for a good result, Always contact, their "Local" or a, "Head Office" Philips in your case. Ask them, for a referral to an authorised servicing center, where you ask for a "Quote". Now, when you get the information you want, then you can decide as to repair of replacement.
The reason we want an approved agent, is that way, all the engineers are trained on their own brand sets, they have seen almost all faults, and will get the job done quicker, and for less cost, and usually have parts on hand, also sometimes, there has been a service bulletin in issued and the repair may be subsided or even free. There are many, many, many reasons that display this symptom, one must work through the troubleshooting steps to isolate and identify, the Cause and repair that and any damage done.
http://www.pioneer.owner-manuals.com/PDP4360HD-service-manual-PIONEER.html
service manual link above,
as an aside here, sometimes things in storage can quickly degrade especially big low value capacitors, these increase in internal resistance, and all sorts of problems ensue, this is why, say, military things are cycled at least weekly when in "Moth balls" to prevent exactly this.
Posted on Mar 12, 2011
Do I need a digital set top box if I have a pioneer PDP-R05G media reciever
Turn the receiver on and select TV. If you can't tune X.X channels (no decimal), you need the converter.
Apr 02, 2017 | Pioneer Televison & Video
Pioneer PDP-R05G
A clear symptom of panel failure is described here. If you wish to get more details, check this site. Pull up older posts there. Check the site with patience, as it has over 2350 posts now. All are related to electronic equipment repair help. If you search the site in Timeslide option, which can be selected from the drop down list at the top left of the display window, it will be easy to locate the related post. Replacing panel will cost around 80% of the total cost of a new TV http://electronicshelponline.blogspot.com/
Apr 23, 2013 | Pioneer PDP-4360HD 43 in. Plasma...
I am looking to buy a Pioneer media receiver model PDP-R05G - can anyone help me? This suits plasma panel PDP-435PG
I am also looking for a PDP R05G receiver.
If you're upgrading your TV to digital, let's know if you'd like to part with the redundant analogue R05G
Ian +61 7 5444-5521
Apr 14, 2010 | Audio Players & Recorders
Pdp433-pg pioneer display which media receiver ?
give Tops Electronics in Haverhill Ma a Call they had a couple in stock about a month ago 978-374-9877 158
Dec 10, 2009 | Televison & Video
How to play PDP-434PG with PDP-R05G
I do not know how to solve your issue sorry, I need the media centre you have for a PDP435. Would you like to sell the media receiver PDP-05G ?
0212624139
Aug 27, 2009 | Pioneer PDP-4360HD 43 in. Plasma...
Pioneer media receiver won t turn on
If the light on the media reciever doesn't come on then the power supply in that needs to be replaced by a service tech. If you disconnect the 2 cables from the media reciever and the panel and then try to turn on the panel it should light with red and green squares for a few seconds but will turn off as it needs the media reciever to be connected.
Mar 29, 2009 | Pioneer PureVision PDP-4340HD 43 in....
Pioneer media receiver pdp-r04u
try testing dvd player direct to tv dont use uvsal remote go to tv turn it on and change inpput to dvd see it works
Feb 06, 2008 | Pioneer PureVision PDP-4340HD 43 in....
Can I use media receiver PDP-R04U with PDP-436PU display?
You need the pioneer media cables hooked up to the media receiver to the plasma unit itself. each end has 2 different plugs. one has 2 thumb screws and the other is a squeezable end that clicks into place. They MUST be on before you plug in any power what so ever!!!! And yes, other information is being passed through.
C-Dog
Sep 18, 2007 | Pioneer PureVision PDP-4340HD 43 in....
Pioneer PDP-4360HD 43 in. Plasma Television Logo
1,702 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
