Hi my teco 32 LCD Tv wont respond to my remote control and also the buttons on the television.on the screen it just says 'switching to DTV' and wont seem to go off that.Ive even switched the tv off and on a number of times and taken the cables out and in could you tell me what else i could do to reprogram the tv.
  • cherelle_kel Mar 12, 2011
    thankyou for your response.do you know who i would contact to fix the problem?
  • 11,800 Answers
What you see if the sign of a corrupted firmware - the small program that runs the tv. This is caused by the failure of the processor of the tv. All you can do is to try a reset: press the menu and channel up buttons simultaneously for 5 seconds. I this doesn't fix it then, unfortunately, this isn't something you can fix yourself - the mainboard will have to be replaced and this is a job for a professional, you will have to call one.
Posted on Mar 12, 2011
  • Azrael SRL Mar 12, 2011
    The best would be to phone Teco
    http://www.teco.com.au/contact-us.html
    they can provide you with a list of the repair shops available in your region.
VW37L 37 in. LCD HDTV input button wont work
Have you find out if the problem is with your remote control? For instance, you are able to control your TV using a Universal remote control. My 32" Vizio TV had a similar problem, initially thought it was related to my remote control but in fact the TV didn't respond either to an universal remote control of my SAT receiver that I eventually use to just turn on and off the TV. I've found out that the problem was with a little board on the TV located at the left down corner viewed from the front side of the TV and that receives the signal from the remote control. I found the board on ebay for about $5, replace it and the TV responded again to both original and universal remotes.
Nov 11, 2013 | Vizio VW37L 37 in. LCD HDTV
Mintek dtv-265-d tv &dvd
Can you tell me which remote you have so that i can give you the codes for it.
Or is the problem that your remote control is not working?
Waiting for your reply..
Feb 22, 2008 | Mintek DTV-320 32 in. LCD Television
Hi ive got a teco 32 LCD television it doesnt seem to be responding to the remote and also the buttons on the the tv.on the screen it keeps saying 'Switching to DTV' and wont go off that.we have tried...
One of the things I'd try ( I can't say for sure if you can or not because you didn't provide a model number) is to disconnect the front panel buttons.
You can only do this if it leaves the infra-red still connected.
Turn the unit on with the remote.
This will eliminate a stuck front button as the cause.
If the infra-red transistor is part of the front panel board, you cannot use this method to eliminate the front panel as the possible cause.
Mar 12, 2011 | Televison & Video
Teco 32" flat screen whilst watching my tv the
I would love to help you.
Please respond by PRESSING REPLY OR COMMENT
Did you experience any storms recently? IE. the power cut off unexpectedly?
Bruce
Jan 13, 2011 | Sanyo 42 in. LCD TV
When I turn on my Sanyo 32" Lcd tv the only channels available are 1,2,6 and 8 even when using the manual buttons on the tv set. the remote control is also acting faulty as most buttons do something...
Hi my name is Roety,
I can help you with your issue ,
If you have already run the atuoprogram that programs and locks the channels in with a good cable or antenna connected then you may have a TV problem, but I'll bet its just not program yet.?
If I have helped you with your issue
If you have more questions you can still respond
I will reply asap
Thanks
Apr 14, 2010 | Sanyo DP32746 32 in. LCD Television
Samsung LE32R74BDX 32 in......
just spoke to Samsung support and it turns out that the freeview tuner had froze and needed resetting. To do this put TV on standby and then push in series these buttons on the remote: 'info, menu, mute, power' the TV will then turn itself on and display a menu. Press the 'down arrow' untill you've highlighted option 12 - 'reset' and then press the 'right arrow' to enter the option. TV will turn off and when you turn back on it will start in 'plug & play' mode as if new. Set the time and country options and then it will perform a complete scan. I've just retuned mine and all back to normal. Hoorah!!!! :-)
Oct 03, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Need to switch to dtv from reg tv but dont have fac. remote
most universal remotes will only do basic functions on your tv like changing volume or channels only some will do menu functions or change input source. if you have a universal remote with a input or source button you can try it some cable and satelite remotes have this function and are discribed in the user manoal. If all else fails you can order a original remote from the manufacture or your local tv repair shop
Apr 27, 2009 | iLO 3200 32 in. LCD Television
Screen is blue says composite, no signal.
TRY AND FIND VIDEO BUTTON ON TV REMOTE AND PRESS VIDEO BUTTON. ON THE MENU USE UP OR DOWN ARROW ON REMOTE TO CHANGE FROM COMPOSITE TO ANALOG TV.
Feb 01, 2009 | iLO 3200 32 in. LCD Television
DTV
press on the DTV button on the remote control & then DMENU, select CHANEL , auto search, its very simple.
Jan 11, 2008 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Nothing works on remote
Hi, check out my (admittedly lengthy) fix here:
http://www.fixya.com/support/t300197-tv_w_built_in_dvd
Hope it helps!
Ryan
Nov 21, 2007 | Mintek DTV-373-D 37 in. LCD HDTV
Televison & Video Logo
66 people viewed this question
Top Televison & Video Experts
Electro Med Services...
