Set doesn't operate. Front panel LED's pulsing rapidly
  • 2 more comments
  • John Williams Mar 12, 2011
    If I disconnect the outputs from the power supply, will the power supply operate? Is the power supply board itself likely to be the problem? I have disconnected both inverter boards and the fault remains the same
  • John Williams Mar 15, 2011
    Your reply was very informative, thank you. Unfortunately I still haven't solved the problem. I have checked all the capacitors with an ESR meter, and all are OK. None are domed. I haven't been able to find any dry solder joints or open circuit fusible resistors either. Can you offer any other suggestions? If I could be certain the fault lies in the power supply board, I would buy a new one, but am just a little fearful that I might purchase the boardand still have the same problem because the fault llies elsewhere. I have disconnected the two inverter boards with no change in symptoms.
    Kind regards,
    John
  • John Williams Mar 18, 2011
    I'm sorry to be so intermittent in replying to you. I have only just been able to get back onto this job. But I do appreciate very much the helpful comments that you have already made.
    In this set the standby power supply in on tjhe main SSB board. It seems to be operating as far as the seconary vol;tage rails are concerned, but not having a schematic I am not able to trace the voltages any further. However I am almost convinced that the main board is faulty, as I have disconnected all other boards and the fault remains the same - the front panel
    LED's pulsing at about two times per second. When you press the 'on' button there is no attempt to fire up the main power supply board. I would welcome any comments on those observations. Many thanks.
    John
  • John Williams Mar 19, 2011
    The model no is Philips 42PFL9532. Thanks
  • 2,098 Answers
This is an indication of out-of-regulation in the power supply section. The very common caused of this fault is the dried-up/leaky electrolytic capacitor in that section. It will drop the supply from normal voltage and will disable the unit and blinking error appear. Sometimes it has a bulged/dome at the top but not all, it is better that you have a capacitor checker/tester to determine its condition. Also, bad solder joints can produce the same symptom, it is hard to spot, you should use table lamp/portable lamp for finding the cold solder. Secondary reason of fault is the open fuse/fusible resistor in series with the output of regulator IC/transistor, shorted/openRegulator IC/transistor, shorted zener diode(all are in the power supply section) and the microcontroller. Best that you check the output voltage of each regulator to determine where the fault came from and narrow the job.
If you don't have necessary tools and test instruments, and can't do the job yourself, I would advice you to look for a professional to troubleshoot the problem. Don't attempt to work in the power supply if you don't know the safety precaution of handling it, there some stored electricity enough to hurt you with a little mistake only.
If you confirmed that the power supply board has a missing voltage and you don't want to troubleshoot it, you may look online for the replacement. Check the availability at ebay.com or shopjimmy.com.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on Mar 12, 2011
  • 1 more comment
  • Jdvillanueva
    Jdvillanueva Mar 15, 2011
    check the output voltages from the power supply (feeding the main board, t-con board, inverter board, etc.)to isolate it from fault. Let me know the reading...
  • Jdvillanueva
    check it connected to the load, then if you find some voltage drop, disconnect the load, test it again if the voltages will normalize...
  • Jdvillanueva
    Jdvillanueva Mar 18, 2011
    may you please give me the exact model no. of your unit to assist you further regarding on the error code...
  • 11,800 Answers
This is the signal sent by the power source when it has been forcefully shut down by its own protection system. This is what happened: a part inside your tv has failed; when you have tried to start the tv that failed part has started to draw a lot of current; this has lowered the output voltage on the power source dramatically; this in turn has triggered the protection system which has shut down the source.
The only way to fix it is to open the tv, test it, identify the failed part and replace it - since this is a big failure you will have to start checking with the output stages on the power source itself, the electrolytic capacitor are well known for that. At least a good experience in electronics is required for that, you will have to call a certified repairman. In the mean time keep the tv unplugged from the mains, keeping it powered only makes the defect larger.
If you decide to have a go at it yourself here are some basic instructions on what to look for and how to do it
http://www.youtube.com/watch?v=YCSNWi3UHf4
http://www.youtube.com/watch?v=1gC3KRfQXwo
  • Azrael SRL Mar 12, 2011
    Yes, the board should operate. If it doesn't then the defect is in the power source itself - either try to find out what is wrong with it or just replace it whole.
LED TV pulsing
How many have 'blinking' issue with Samsung led tv - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJan 26, 2011 - I am trying to get the number of people affected by this nagging blinkingissue with the latest Samsung led tv's. If possible it would be useful to ... Samsung LCD TV Screen flickering (LN55C630K1F)
Jun 11, 2015
Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
DLP Twon't turn on, blinking green lamp light then shuts dow ...
Jun 11, 2015
Samsung LED with flashing standby light on front
Apr 17, 2014
More results from www.cnet.com
EASY How to Fix Samsung LCD TV Flashing Flickering ...
? 3:43
https://www.youtube.com/watch?v=i-jQZ-TQdgU
Jun 4, 2012 - Uploaded by Tampatec
How to Fix Samsung TV Flickering Blinks Flashing Flat Screen Picture ... LED LCD TV FIX, How To For Samsung Double Image, Black Vertical ...
Jan 18, 2016 | LG Televison & Video
Hitachi C2143S TV
you have a very unhappy tv...sounds like you have a relay clicking, or worse, something about to fail. the led pulsing is a warning signal, and going pure red means that you have a major failure inside the box.
you doing the service yourself, or open to a service pro coming in for this?
Mar 07, 2008 | Televison & Video
Why doesn't my magnavox led tv turn on?
if just an stand by indicator at the front panel check for bulging capacitors at the power supply board.
Sep 30, 2012 | Funai Magnavox 19" Class 720p 60hz LED TV...
LG 17LX1R flashing red LED - TV won't power up
Try changing the input device to something you are sure, works such as a DVD player.
Switch off TV manually, switch off power, remove plug and retry after 48 hours.
If problem persists, please refer it to a qualified service technician.
Aug 02, 2012 | LG 17LX1R 17 in. HD-Ready LCD Television
Manual switch ok but remote not fundtion sharo tv
Be assured that fault does not lie with the remote handset itself. In that case repair or replace it.Remote control system has two parts. One is the remote hand set and the other lies within the TV or other device for which remote controller is being used. The hand set transmits commands in shape of singnals of particular frequency and pulses per second depending on the key pressed. The other part of the remote system lying within the TV receives, decodes and responds according to the commands received in shape of signals of particular frequency and pulses of paricular width and sequence. The remote controller uses invisible infra red light as the carrier of the signal. As the light moves in straight path, no obstacles should block straight line of sight path between the remote hand set (the transmitter) and IR sensor window (part of the receiver). Hence remove the blockage from the front side of the TV.Check if the IR sensor is not defective. Check if the associated circuit and components inside the TV are not defective.Check if the TV has any switch for selecting only manual mode and locking the remote mode.Hope, some sytematic exercise will bear the successful result.
Feb 19, 2012 | Sharp LC-32SB21U 32 in. LCD TV
APC 1100CI-IN UPS NOT EORING ON GENERETOR WHAT I DO? PLZ SEND SULATION E-MAIL singhpintu987@gmail.com
Hello Sing,
There is a possibility that your UPS doesn't like the voltage or frequency that the generator is feeding it. As per an APC knowledgebase article, the size of a generator should be 3 to 5 times higher that the total Watt/VA load that it would be supporting.
There are also instances wherein the sensitivity threshold of an APC BackUPS is set too high that a slight change in voltage/sensitivity would cause the unit to switch from online to on battery too frequently. This can be addressed by lowering the sensitivity either by their APC PowerChute Personal Edition Software or via the front panel switch.
If you are going to do it via the software, it needs to be installed on your computer. Prior to downloading it, make sure that your operating system is compatible with it. Suppose that your operating system is compatible, once the program is installed you will need to open it up and look for the Sensitivity option and from there you could select Low, Medium or High.
If you are going to do it via the front panel switch/button the UPS should then be turned off but plugged in to an input source. Press and hold the On button until you see that the LEDs are flashing. Once the LED is flashing, press the button again to set the desired sensitivity. Low sensitivity would show the On Battery LED flashing. Medium is On Battery and Overload LED while High is On Battery, Overload and Replace Battery LED flashing. If you'll see a flashing Online LED it means that you are cancelling or exiting the program mode of the UPS.
Below are some helpful links from APC
*** You will need to login in APC before you can download the software. Choose the correct PowerChute Personal Edition Compatible with your OS and create an account online.
Jul 22, 2011 | APC Back-UPS CS 500VA UPS System
What is the green light that blinks on the left side of the printer just below the usb port?
Heartbeat LED
The heartbeat LED indicates that the formatter is functioning correctly. while the printer is initializing after you turn it on, the LED blinks rapidly, and then turns off. When the printer has finished the
initialization sequence, the heartbeat LED pulses on and off.
Oct 19, 2009 | HP LaserJet 4700 Printer
Green light on front rapidly blinks after power outage. No picture, or can't turn on
This unit, when first plugged in or after power interuption takes 70 to 90 seconds for the digital module to boot up. During the time the LED blinks green and the set will not respond to anything. After the appropriate amount of time the blinking should stop and the set should operate normally. If the blinking never stops then you have to have the Digital Module repaired.
Apr 25, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Apex Digital GB4308 remote
Programming the Remote Control Remote-control switchover Press VCR/DVD, SAT/CABLE or AUX to select the device you want to control. To program the remote control Press and hold VCR.DVD, SAT/CABLE or AUX for over 2 seconds until the LED on the remote control turns off. Release the button the LED will light again (the remote control enters the PROGRAMMING mode). Enter three-digit code number for your equipment. If the correct code number is entered, the LED blinks three times. If you enter a code not listed below, or you press any other buttons than SEARCH and 100+, the LED turns off. To search codes Press ad hold VCR/DVD,SAT/CABLE or AUX for over 2 seconds unil the LED turns off. Release the button (the LED wil light again) and the remote control enters the PROGRAMMING mode. Press SEARCH. Press CH+/- to search codes downwards or upwards. Each time you press CH+/-, the code number decreases or increases by 1 while the remote control sends the code number for POWER button on your device. If the desired code number is found,press 100+ to program the code for your device until the LED blinks three times.Then the remote control exits from the PROGRAMMING mode and returns to norml operation. Or press any other button to exit from the PROGRAMMING mode after the LED blinks rapidly eight times, and the operation is not active. To check the current code number Press and hold VCR/DVD, SAT/CABLE or AUX for over 2 seconds until the LED turns off. Release the button (the LED will light again) and the remote control enters the PROGRAMMING mode. Press 100+ . You may read the code numder according to the LED display status as follows. * If there is no operation within 20 seconds during the steps mentioned above, the remote control will automatically exit from the appropriate operation. Code Number First - digit 0 1 0 1 Second - digit 0 0 4 5 Third - digit 0 6 3 0 First - digit Blinks rapidly once Blinks once Blinks rapidly once Bliks once Secod - digit Blinks rapidly once Blinks rapidly once Blinks four times Bliks five times Third - digit Blinks rapidly once Blinks six times Blinks three times Bliks rapidly once
Jan 05, 2007 | Apex Digital GB4308 43" Rear Projection...
Televison & Video Logo
62 people viewed this question
Top Televison & Video Experts
