Question about TP-LINK TL-WR740N 150Mbps Wireless Lite N Router IEEE 802.11n IEEE 802.11g IEEE 802.11b Built-in 4-p... (813120016543)
Hello , my problem is the following : I wanted to do upgrate current firmware and then stopped , router is dead and I can not connect to it thanks my router TP-LINKwr740N
    Scholar:
  • 97 Answers
Try resetting your router by pressing the reset button at the back. If that doesn't work, see if you can reinstall the firmware using a different method than using the modem interface. Did the manufacturer supply a CD with the modem? Maybe you can use that to install firmware as well.
Posted on Mar 12, 2011
How do I get into the network and firmware menu?
Try the following
Via Net
Is it reasonable to assume your router requires password / ssid to secure internet access ?
Due to age of this device,
(1) Lower / disable current router security settings
OR
(2) connect device directly to modem. ( softest, easiest way )
This may require you to disconnect modem from router, reset your modem then connect cable direct between modem and DTR 40.1 device.
When completed, the Modem ( and Router ) may need be reset, prior to re-connecting network
Firmware update information link ( from manual )
http://filedepot.onkyousa.com/Files/own_manuals/Firmware_Update_for_the_DTR50_1_40_1_DHC40_1_100110.pdf
Step 3:
Go to "7-6. Firmware Update" menu.
Note that the Firmware Update option will be grayed out
for 30 seconds after AV receiver/controller is turned on.
Please wait
( system attempts internet link for approximately 30 seconds ? )
Not outputting Sound ( trouble shooting ) link
http://www.integrahometheater.com/faqs_detail.cfm?detail=1&id=347
Hope this was helpful
May 12, 2014 | Integra Thx Dtr 40.1 Receiver
How do I determine what firmware version my MAXg USR5461 is currently running?
The latest firmware release for that router is found HERE.
Be very careful to follow the instructions; especially I suggest connecting direct cable to your router to insure there are no interruptions in transmission. Since I don't have a USR I can't tell you where the current firmware number is located. However, the usual places are directly on the router itself, perhaps on the bottom or rear. Also check the manual, although usually manufacturers don't use this because many times they supply manuals for several models and don't want dated material. It wouldn't hurt to send an e-mail to USR support, most of these companies are pretty good about responding. My suggestion is to flash your firmware only if you have a problem and no other choice.
If your flash goes bad or is interrupted your router will be bricked.
Oct 02, 2013 | U.S. Robotics MAXg USR5461 (738168036790)...
My router hangs up every 5 minutes
You first may want to try updating the firmware of the router.
Here's a link to the firmware downloads for this unit:
http://www.edimax.com/en/support_detail.php?pd_id=305&pl1_id=3
If this does help you may want to reset the router back to factory default (you will lose all current custom settings)
I do hope this helps.
Best of luck!!
Mar 07, 2011 | Edimax BR-6226n nLite Wireless Broadband...
Firmware
Hello jagancs1,
The Belkin Router's software (firmware) can be occasionally updated. To check for new updates, go to the Belkin Router Setup page http://192.168.2.1/ . The following choices will appear to update firmware and save current settings:
•Select Firmware Update (Near the bottom of the left-hand panel)
From time to time, Belkin may release new versions of the Router's firmware. Firmware updates contain improvements and fixes to problems that may have existed. Click the link below to see if there is a new firmware update available for this Router.
•Firmware update Options:
Firmware Version > #.##.##
Check for New Firmware Version > [Check Firmware]
Update Firmware > [Enter file name/Browse]
[Update]
•NOTE: Please backup your current settings before updating to a new version of firmware. Click Here -> http://192.168.2.1/system_c.stm to go to the Save/Backup current settings page.
•Save/Backup Settings
You can save your current configuration by using this feature. Saving your configuration will allow you to restore it later if your settings are lost or changed. It is recommended that you backup your current configuration before performing a firmware update.
*Saved File name is user.conf*
If this solution is helpful please click a thumbs-up rating below.
Have a great day,
martyshaw152
Jul 04, 2010 | Belkin (F5D7230-4) Router (587009)
Why haven't you found solutions for the posts above???
Hello joe_east,
[Update]
Have a great day,
martyshaw152
I just hooked up my linksys wrt160n router and myself as well as my roomates are having connection issues. The is no problem when the computers are connected to the router through an ethernet cable, but if...
Try to upgrade the firmware of the router. Firmware is the software of the router.
Download the latest firmware of the router. Go to the manufacturer's web site and download the firmware of the router.
Open the set up page of the router and upgrade the firmware of the router. Once you upgrade the firmware of the router, reset the router.
On the router you will find a small reset button, hold it down for 30 seconds. release it. wait for 1 minute. Now unplug the power to the router and plug it back in.
Now you will need to reconfigure the router according to the Internet service provider.
Click here for step by step instructions.
Apr 08, 2010 | Linksys WRT160N Wireless Router
Router drops connection
Its your bad luck that u purchased this router. Basically Its a very cheap product from china. It got hot & dies very soon. This is major problem with this model. Company suggesting the firmware upgrade but i didn't find a single solution with that. So the best answer is to replace it with another model.
Thanks for contacting Fixya
PLZ GIVE RATING BY CLICK ON YES OR NO.
Mar 22, 2009 | Encore ENHWI-N Router
I upgrated the fireware for my D-link 502T, but I found it is dead. only power light is on. I tried reset, but it seems not help, then what so I do? thanks a lot!
The only thing to really try is holding the reset button and trying to logon to the router with a web browser. If the firmware update failed i don't believe there's much that can be done.
Aug 04, 2008 | Computers & Internet
Belkin Pre-n wireless router
Check your device to see if it is due for a firmware upgrade. Esp. depending on your ISP, log into your device that you have from your ISP ( whether dsl modem, cable modem, etc.) and then follow whatever procedure it needs to determine your current firmware version.
Jun 16, 2008 | Belkin Wireless Pre-N (F5D8230-4) Router...
Firmware upgrade
Firmware Upgrade Instructions:
Please download and unzip the firmware file to computer's local hard drive and then follow the instructions in the "readme.txt" file to upgrade the firmware.
Warning : -
Firmware upgrade failure may permanently damage the unit and causing it not to function. If the issues in the "Release Note" do not address the problem you are experiencing, please do not upgrade the firmware. Never upgrade the firmware using a wireless connection. Firmware upgrade will reset the Router to factory default state (all current settings will be replaced by default settings). When necessary, please write down the Router's current settings before performing the firmware upgrade. Please do not load the previously saved Router "configuration file" to the new firmware.
If you need assistance performing the firmware upgrade or if you have any questions, please contact our Techsupport Team http://www.trendnet.com/support.
Feb 16, 2008 | Trendware TEW-452BRP Wireless Router...
TP-LINK TL-WR740N 150Mbps Wireless Lite N Router IEEE 802.11n IEEE 802.11g IEEE 802.11b Built-in 4-p... (813120016543) Logo
415 people viewed this question
Top TP-LINK Computers & Internet Experts
Martin Murray
Robert
Level 1 Expert
Are you a TP-LINK Computer and Internet Expert? Answer questions, earn points and help others
