Question about Maytag Washing Machines
Changing belt on maytag sav2555 - Maytag Washing Machines
2 Suggested Answers
  • 15 Answers
SOURCE: Hello
Hey wats up. Im spidapig, whaddup joemac?
Posted on Jul 13, 2008
  • 410 Answers
SOURCE: I have a maytag washer with a broken belt. Model
I am not a repair professional. I am a 78 year old man who has been making his own repairs for about 50 years. So the washer or dryer ID doesn't mean much to me. I came to fixya looking for a schematic for an really old AM/FM radio and found that more than 4,700 people were asking for help with a washer repair. I recently had a washer repair of my own and at that time I found an excellent video which showed me how to take my machine apart. This video made it possible for me to do my own repair. If you are repairing a dryer or a front load washer I suggest you
go to www.applianceaid.com where they have very good step by step trouble shooting and repair information on both washers and dryers as well as other appliances. If you have a direct drive top load washer and need help taking it apart this video is an early christmas present. I was so impressed with it that when I saw all these people needing help, I wanted to tell them about it. If you look at the back of your washer and the panel is solid (no small inspection plate to remove which would indicate you have a v-belt drive) chances are you have a direct drive and this video is just what you need. You can see it at www.acmehowto.com You will probably still need help in determining what the trouble is and how to fix it. After viewing the video or if you have a v-belt drive rather than a direct drive, I suggest you go to www.applianceaid.com where they have very good
trouble shooting and repair nformation on most
washers and dryers. I think you'll find what you need
there. Don't worry about the timer, they hardly ever
go bad. Good luck with it. If I have helped you, please rate my advice on fixya.
Posted on Dec 04, 2009
How do I change the dryer belt?
Hi
Please check the bellow links to get the instructions as to how to change belts:-
http://www.ehow.com/how_4841992_change-maytag-dryer-belt.html
http://www.ehow.com/how_4841963_change-belt-maytag-dryer.html
http://www.applianceaid.com/maytag-dryers.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Feb 02, 2011 | Maytag Dryers
I have a maytag washer with a broken belt. Model no.SAV2555 AWW. how do you replace the belt. Thank You
Dec 03, 2009 | Maytag SAV5710 Top Load Washer
Changing dryer belt on maytag performa
Here is a link for both old-style and new-style Maytags.
At the top of the page you'll see the word "here" -- click on the appropriate one to get the belt-change procedure.
Charlie
http://www.applianceaid.com/maytag-dryers.html#belt
Aug 31, 2009 | Maytag Dryers
Need to change the belt on my Maytag Performa Dryer
The belt is a 341241, a pretty standard belt. To install it you must get the front panel off. Do this by using a putty knife: 549402b.jpgUse this hady DRYER BELT ROUTING guide
Mar 26, 2009 | Dryers
Hello
Jul 12, 2008 | Maytag SAV2555A Top Load Washer
Maytag SAV2555 will not spin
it does( withiut looking at it myself), sound like the pulley/helix are just slipping past eachother and not engaging one anoher, does the sloped side of the pulley(wehre it meshes with the helix appear to be rounded over???) thats really the only reason i could see to replace the pulley.. for get trying oto spin the belt can you grab hold of the p[uley and try spinning it directly????. rfeason i askl is that in order to replace the pulley, youll need to rease th springs around the bottom of tub, and remove the entire unit from the cabinet, after removing unit, turn unit upside down, you need to remove the motor,, then unbolt the 3 white legs form the outer tub, and remove the 3 brake pads bolted to underneath uint with 3/8 nuts, the stansion then will lifht up giving you room to remove the pulley. awful alot of work if not needed,
Apr 15, 2008 | Maytag SAV2555A Top Load Washer
Maytag washer sav2555
the pulley will not remove very easily , it wold require removine the milk stool, motor and some other parts, not the easiest hing to do especially if not needed, the helix you removed, take a look at it , the sloped ends of it should create a pretty sharp angle, then a 90degree drop off, the slopes om the pulley should be the same, they should not apppear to be rounded off,helix is probly 10 bucks if needed and if its at the helix that you see the "slipping" and "clicking noise, before condeming the tranny i would start with tthe helix, if after re-installing it it still clicks up and over pully perhaps try adding another spacer under the bolt before tightening. the idea behind the pulley and helix is that depending on rotation of the transissiion, the helix "pushes against" the pulley adn spreads the brake plate, releasing the brake allowing the tub tospin freely
Apr 06, 2008 | Maytag SAV2555A Top Load Washer
Wont spin and makes a noise
def needs a pully to add tension in order to spin. reconnect adn watch what it does. where does noise appear to come from??? sometimes the lower most "helix" strips out on machine and sounds as if theres amototr boat in you machine.Its the bottom most item on the centraal shaft of the transmission held o by a 1/2 bolt. if either that or the pulley above it strip it wont dissengage the brake assy and will "motor boat" with no action from transmission
Apr 02, 2008 | Maytag SAV2555A Top Load Washer
Washing Machines Logo
75 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
