Question about Poulan Pro 22inch 625 Series Briggs Stratton Gas Powered Side DischargeMulch Front Wheel Drive SelfPropelled Lawn Mower With High Rear Wheels PR625Y22SHP
I have a Briggs and Stratton 625 series mower that will start but not run for more than 30 seconds. I was told to change the spark plug. I noticed that there is oil on the spark plug and in the hole where it is supposed to go. That's not right is it???
  • 23 Answers
Sounds as if the problem is in the fuel system. When water develops in the tank, the weak fuel cannot keep the motor running. Use a solution for removal of water condensated gas tanks.
Posted on Mar 12, 2011
  • olson322000 Aug 07, 2011
    What solution is used to remove water in the fuel.
Lawn mower ran out of oil and stopped running put new oil in and still not running is there something to do after putting oil in to make it run
If you can turn blade by hand first removing spark plug you then can try squirting 30w oil into plug hole and turn blade by hand. replace plug and try to start. Depending on whether you gouged the cylinder it may start.
Jul 06, 2014 | Poulan Pro 22inch 625 Series Briggs ...
What kind of oil goes in my craftsman 625 model 944.367600
Tecumseh engines usually recommend SAE 30 oil. Briggs engines allow 5W 30 or 10W 30.
Aug 01, 2013 | Craftsman 675 Series 190cc 22" Briggs ...
What is the correct gap setting for a Champion RJ2YLE spark plug used in a Toro Lawn mower?
Briggs & Stratton Part Number 799876 replaces Champion plug RJ2YLE. For use in Quantum Series 625, 675, and 725 engines built after Date Code 110701xx. The gap for this spark plug should be set to .020". This spark plug should not be used with Quantum Series 625, 675, and 725 engines built before Date Code 110701xx, or any other L-head engine family.
Apr 20, 2013 | Toro Garden
We have a briggs and stratton mower that has been in storage for 5 years with very few hours on it, it will start but dies shortly after.
needs to have carb cleaned out. most likely the main jet in the carb is plugged. symptoms include only running on choke and dies when choke is turned to run. or if you only have a primer bulb, it will only run for only a few seconds every time it is primed. if you are qualified to work on the carb, dont forget to start with fresh gas and possibly new fuel line and filter. R
Sep 03, 2012 | Poulan Pro 22inch 625 Series Briggs ...
Where is the oil plug on a Poulan Pro 625?
Hi ca rishell
The oil drain plug is under the mower, look for the pipe plug in the engine housing, be sure to remove the spark plug wire before working near the blades as a safety item...
Free Answer, Please rate me
Apr 16, 2011 | Poulan Pro 22inch 625 Series Briggs ...
Just looking for the type of oil I need to use for my poulan pro 625 series
Briggs and stratton sae 30 engine oil or any other reputable brand sae 30 engine oil is fine. Regards Phil
Apr 15, 2011 | Poulan Pro 22inch 625 Series Briggs ...
Gas Push Mower - Briggs & Stratton, will start but run for
The jet in the bottom of the carburetor is clogged up. The engine will prime but after that fuel is burned off, the engine stops. The jet is not allowing fuel to be sucked into the engine.
Sep 29, 2009 | Garden
Poulan Pro 22inch 625 Series Briggs  Stratton Gas Powered Side DischargeMulch Front Wheel Drive SelfPropelled Lawn Mower With High Rear Wheels PR625Y22SHP Logo
1,098 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
