Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
"Ink cartridges not recognised" it
  • Epson Master
  • 17,130 Answers
Remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken . It is possible that the head is not reacting to the need of the command , can be an issue with ink drying , can
also be poor ink cartridge contacts
Posted on Mar 12, 2011
Canon mx350
Hello, your error is - U140 The ink cartridge
cannot be recognized.
A non-supported ink
cartridge is installed. Install
the supported ink cartridge.
Please check that you have the correct ink cartridge.
Nov 01, 2013 | Office Equipment & Supplies
Epson stylus sx200 refuses to acknowledge black ink bought direct from epson
I believe the DX series and the SX use the same system
# Determine which ink cartridges are not recognised.
# With the ink cartridge holder in the ink cartridge replacement position, lift up the ink cartridge holder lid and take the cartridge or cartridges out.
# Check that the cartridge is a genuine Epson ink cartridge - look for the EPSON branding and T0xxx codes on the cartridge labels.
# Check that the cartridges are correct for your Epson product.
# Wipe the green Intellidge Chip on the cartridge that is not recognised.
# Check the chip contacts within the ink cartridge holder for any debris or dried ink and wipe with a lint-free cloth if necessary.
# Check that the plastic at the bottom of the cartridge has been pierced.
# Check that the cartridges are in the correct slots.
# Reinstall the cartridges into the ink cartridge holder in the correct order.
# Push the ink cartridge down firmly. It should click into place.
# Repeat this for any ink cartridges that were removed.
# Push the ink cartridge holder lid down. It should clip into place and be secure.
# Press the Stop button, this will return the ink cartridge holder to the right hand side of the unit.
# If the error light flashes after the print head returns to the home position, the ink cartridge may not be installed properly.
# If the red light is no longer displayed, but Status Monitor still reports a Non-Genuine Ink warning.
# If the red light is still on the printer, and Status Monitor indicates that an ink cartridge is not recognised, follow the steps below.
# If the problem remains, there may be a fault with the ink cartridge.
Dec 30, 2010 | Epson Office Equipment & Supplies
How to install new ink cartridges
Check whether you have tear off the protection seal on the new cartridge.
Did you lock the cartridge in fix position?
Check if it is the correct type of cartridge for yr printer.
Nov 16, 2009 | HP DeskJet 940c InkJet Printer
I get a message saying ink cartridges cannot be recognised
make sure you are using the correct type of ink cartridges, then remove the ink cartridge, make sure they have ink on them. If they are new, remove any plastic covering on them. try to shake the ink a bit. with the printer turned off, unplug it from the power outlet, pres the power button for about 5 to 10 seconds to fully discharge residual power, install the cartridges making sure they are securely in place, plug the printer again and try printing again.
Oct 27, 2009 | Epson Stylus D92 InkJet Photo Printer
No cartridge the printer say. i put new cartridge in
It mean that the black cartridge is not recognised. It the black cart is original or compatible? Some printer won't recognise cartridge, if the black and colour is not same type. Try to install the black only. Is it recognised?
May 30, 2009 | Brother MFC-3360C All-In-One InkJet...
How to use non HP ink cartridges
only the non hp cartridges which have written the compatibility on it can use with the printer. make sure it has the model number written on the non hp cartridge.
Dec 20, 2008 | HP PhotoSmart C4385 All-in-One Printer
Canon INkjet MP170 not recognising cartridges
make sure the contacts are clean! get a new cartridge, and it if does the same thing...its UR printer.
Dec 19, 2008 | Canon PIXMA MP170 All-In-One InkJet...
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
256 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
