Question about Garden
Hi, I am in Australia and I am trying to chase up a pocket device for measuring sheet metal thickness in Metric, either digital or the old style of gauges that have different size cut outs that you can slide over. They are very hard to find locally. Are the cheap digital pocket clamp gauges reliable( the ones I see on ebay from Hong Kong etc. Thanks for your time.
  • Darryl Traves Mar 13, 2011
    Hi Joe, Thanks for the link to the conversion chart. No, I don't have a english/imperial gauge either, all I have is a couple of sets of vernier calipers, one of them you have to read with a magnifying glass on the vernier scale. I was looking for something to fit in your pocket and can read easily and quickly. I have seen a couple on ebay and amazon, the digital ones look like they are spring loaded and fit in the palm of your hand, that would be very quick and easy to read if they are accurate. There are quite a few different brands of the slide over slotted variety and I almost bought one but I realized when it said decimal equivalents were on the back, it actually meant thousandths of an inch not metric. The thickness of metal I deal with varies from 0.4mm to 5.0mm. Thank you for your time once again, ( you are the one who helped me with the husqvarna brushcutter problem, that carby cleaner is good stuff, I have managed to get a mower going better with it as well as 2 old brushcutters, within our family circle, that were headed for the rubbish tip/dump,) Thanks again, Darryl.
  • Darryl Traves Mar 14, 2011
    Thanks, that is what I was looking for as one of the options, on amazon, I just needed to hear from somebody who has used one and can vouch for them. Thank you very much!
  • 8,197 Answers
Hi welcome to fixya.
I see that you are looking for a good gauge to mesure with. I have this one on the link below and have had no problems. It works great. Please look at the link below to see and order.
http://www.bonanza.com/booths/tvactools/items/DIGITAL_THICKNESS_GAUGE__SAE_and_METRIC_new_caliper_mic
Posted on Mar 13, 2011
  • 10,865 Answers
Hello. Here is an excellent set of conversion charts that you may find useful
http://www.offroaders.com/tech/sheet-metal-gauge-thickness.htm
especially if you do have English gauges.
Regarding the cheap ones, they may be accurate but to be sure I would obtain one and check it myself with a set of metric feeler gauges available at any auto parts store to check spark plug gap. Joe
Thanks for choosing Fixya!
Posted on Mar 12, 2011
How did a guage become a measurement?
" the thickness, size, or capacity of something, especially as a standard measure, in particular." In its utilitarian sense , the term gauge refers to a standard of measurement. A 12 gauge wire has a defined diameter, and it is standardized, so if you buy 12 gauge wire in various places across the country, the wire will have the same diameter , wherever it's purchased. The same applies to gauges of metal, or the thickness of the metal. Standard measures such as linear measures , inches, mm, feet, cm, are all standardized measurements. Standardization creates consistency and the ability to replicate something.
May 16, 2014 | Computers & Internet
When i drive over 50k(australia) my front drivers wheel sqeaks and it does it too occasionally when i break. been happening for over 2 months so i rule out that its dirt in the breaks. what could it be...
wow first post ever for country, im GOBSMACKED !!!!
wheel ?steering wheel or tire/wheel.?
hard to find, they are, all squeaks.
first is to see if possible to do, no moving (big safety issue, yes)
bounce the corners of car hard, by hand.?
jack car up spin tires. by hand,
lever them below off ground, to see of balls are shot.
inspections here, look at every inch of suspenson and parts.
Brakes, i hope nothing breaks the brakes.
The brakes all squeak this is normal try lightly pressing the brake pedal, gently while moving slow, squeaking now is 100% normal and harmless. (the pads act like Guitar strings)
Use pad glue to halt it, or ignore it like me....
the pads have wear markers, they have this device that makes noise when pads get too thin, (look at em)
bad wheel bearings.
brake backing plate bent.
caliper guide pins rusted.
and lots of other things bad or just ok , old and making noise, like
suspension "A" arm bushing rusty, or stable bar , same.
moving noise is real hard to find.
Sep 12, 2013 | 1997 Honda Prelude
Is this table saw safe for sheet metal cutting
No. A table saw IS NOT safe for sheet metal cutting. I have seen bar stock aluminum and copper cut on a table saw (at least 1/4 inch thick) but trying to cut thin sheet metal would be a bad idea. The two main problems are that the sheet metal is too flexible and the teeth are much larger than the material is thick.
Dec 19, 2012 | Craftsman Sears Table Saw Manual Model...
How can I ground my LX300 Sony Turntable? The hum at high volume levels is due to lack of a ground from the turntqble and the receiver. Perhaps one of the screws on the bottom which holds one of four pads...
hi,
take a wire connect its one end to the screw on the bottom on ur turntable and the other end to ur receiver's turntable ground. if there is no such point. connect it to chase, loosing any one screw of ur receivers top cover.
or take metal sheet( same dimension of ur turntable legth and width ). put ur turntable on it. make a connection from the metal plate to to ur chase.
ok
Dec 17, 2010 | Sony PS-LX300USB Turntable
I would like to know where I can obtain (In Australia if possible) a superior drive coupler, ie. metal parts as the standard under engineered plastic parts continue to break too easyly and often. Also...
This is the best place to find and order online. Millions keep using it and have not got any complains yet.
http://www.thefind.com/query.php?query=superior+drive+coupler+washing+machine+australia
Do get back to us for any further query and do not forget to accept it.
Thanks for contacting fixya.com
Oct 12, 2010 | Washing Machines
I have 1981 Yamaha SX 650 and can't find the point gap and valve adjustment settings anywhere? Any answeres
Hi, the points gap is 14 to 16 Thou. Inlet valves 4 thou, exhaust valves 6 thou. I dont know the settings in metric, so using a set of imperial feeler gauges, that measure in thousands of an inch.
An easy tip for setting the points, is use the thickness of a standard cardboard, Business Card, it is the correct thickness for your points gap.
Jul 21, 2010 | 1981 Yamaha XS 650 H
Seat post size for 98 dyno nitro 24 bmx bicycle
start with the seatpost itself, most of them have the size stamped on them below the minimum insertion hash marks. It is almost always measured in metric, millimeters usually, like: 25.4mm (which is 1 inch).
If the size is not stamped on the seatpost (it was most likely cut off or scratched beyond recognition) then you can measure the diameter in inches, multiply by 2.54 to get the metric measurement in centimeters, multiply that by .10 to get millimeters and then call your local bike shop for a replacement.
Dyno bikes are made by GT, it was there "budget" brand of BMX bikes, so you can google GT bikes and find a local dealer or you may be able to order direct from GT. From the year of your model, most likely the bike is steel (cro-moly or hi-ten) and these bikes normally have a smaller seatpost size, like the above mentioned 25.4mm. Aluminum frames usually have larger diameter tubes with thinner wall thickness and will require a larger diameter seatpost.
May 15, 2010 | Bike Extreme Lite Youth Shoulder Pad
I have an old vitantonio tortellini maker (model #520) but i have lost the instruction manual
1. Make your favotite pasta dough, roll out thin.
2. Place a sheet of rolled-out pasta dough on the metal plate, press down with the plastic mold to create the ravioli pockets.
3. Fill the pockets with your choice of mixture (cheeses, meats, spinach).
4. Then brush the top of the pasta sheet with egg wash or water and place a second sheet of pasta dough over the first.
5. Then use a rolling pin to press down on the assembled raviolis.
6. The pressure of the rolling pin will adhere the two sheets of pasta together and will cut the raviolis apart along the edges of the metal plate.
7. The result is a dozen perfect homemade raviolis!
Sep 27, 2009 | Kitchen Appliances - Others
Is it possible to make my Humminbird 787c2 to show METRIC unit instead of IMPERIAL?
hi
Did u bought Humminbird 787c2+GPS or just Humminbird 787c2 ?
If u bought Humminbird 787c2+GPS i like to know, do the built in GPS UniMAP work in australia ? i bought one myself. Thanks.
Mar 27, 2007 | Humminbird 787c2 GPS Receiver
Garden Logo
18 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
