Question about JVC Audio Players & Recorders
When record has finished playing, the arm keeps running in the inner groove. No lift and return to base. What's wrong? The outfit is quite old, but none of the new gadgets I've purchased can match this old one in sound quality. PS Have approx. 1100 vinyl, mostly late renaissance and eary baroque. Also 1500 CD's (?), but nothing stands up to my JVC QuartzLock Model QL-A5. "Happiness is a good advice!" Svein Bue, Oslo, Norw.
  • JVC Master
  • 17,130 Answers
I am glad to find a real Audiophile and I fully agree with you for the quality that analogue tracks give out.
The arms mechanism needs a resetting as when the arms comes to the end there is a link to detect and make the arms to be lifted up and brought back like a clock work. so there is an issue here which needs attention - mechanically. You need to look inside the unit, manually turn and find the fault.
Posted on Mar 12, 2011
THE TONE ARM ON MY ROCKOLA 459 SLIDES OVER THE RECORD WITHOUT PLAYING.
Hi
It sounds as if the tone arm has become unbalanced. Make sure the turntable is on a firm flat horizontal surface and at the opposite end of the arm from the needle there will be a weight and a means of altering the position of weight on the tone arm. This weight keeps the needle on the record but only lightly when positioned correctly. If positioned too far from the pivot post the needle will as you have experience skip virtually straight across the record. You need to adjust the weight so that the needle just sits in the groove and plays without being too heavy. It is best to use a record you are not too worried about for this testing as the test record can sometimes get scratched.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 11, 2014 | Audio Players & Recorders
My Mt 750 Fisher turns on the table spins a moment but the arm does not move what is wrong?
What you have is a record changer; and malfunctions today are probably more likely that in the past--even after the prestigious Fisher name and price had been largely supplanted in the post war years--before mfg quality control as a customer fault under protection (for sellers) by Warranty dodges had come to the fore. (In actuality, while record changers would would have been favored by record producers--for the rapid rate at which they destroy records--they would have been looked upon with disdain by pro disc jocks as well as high-end audio equipment producers (including Fisher) in favor of single play turntables that don't destroy records that must be played "on the air," repeatedly, hundreds of times per week in successsion.)
1. Did you unclip the tone arm from its resting post?
2. Remove record and turn off platter (name for a turntable record support) drive motor, and unplug the player machine.
  1. While manually rotating platter in PLAY direction (that's CW), actuate PLAY lever to its extent, release, and watch for tone arm movement as you continue platter hand rotation.
    1. (Oh yes, make sure the record hold-down arm is up and rotated outward to prevent hold-down-arm drop from causing changer to return tone arrm to stow post and dis-actuating START lever...such features once accurately called "self stop,: today inaccurately called "auto stop."
      1. ...by the way, could your problem be that you did not lower hold-down arm onto record(s)? ...making the changer mechanism below the platter "think" that all records had been played...so that it swung and stowed tone arm and then Self Stopped the player rather than repeat-playing the top-of-stack record (in order to save changer and record wear and tear)? Is your problem now solved? Just in case not, continue...
  2. As you hand rotate and watch, the tone arm (and release spindle with no record on it) should "recapitulate" its normal, record changing and playing motions--you are simply "handing" in for the platter motor.
  3. If there is a "hitch in the changer's stride" (that means a jam) it will also occur and be felt operating the changer manually. At that point, you will have "set" the changer mechanism in conflict-fault position for facilitating inspection to find the specific problem.
  4. Note that since record-changer-/turntable-type players are permanently confined to level-only use, that means the turntable/changer platform need not be affixed to its base (some are--some aren't) so it might be possible to simply lift the turntable/changer platform assembly up off the base to inspect underneath. Some (possibly most) turntables/ changers, on the other hand, are apt to be fastened to the base (lest the furniture be bumped into...but those typically did little more than prevent tone arms from skating some ot the time) in a suspension arrangement (if not rigidly) that incorporates helical thrust springs and hold-down screws at each hold down point, typically 4 in number. Detaching the platform is apt to involve simply looseing and then over loosening the screws...or by some other obvious or not so obvious means.
    1. Being mindful of any hard-connected wires, unfasten, lift, and invert changer platform to inspect underneath.
    2. Take appropriate corrective action at point of jamming.
    3. Revert and refasten platform and re-run manual-unpowered operation to confirm corrections.
    4. Return power to player and test using a record.
    5. Thank yourself for posting your question...if all or some of the above works.
Oct 19, 2014 | Audio Players & Recorders
The turntable turns and the arm lands on the record but then it moves back to rest on it's base and shuts off. What's wrong?
The auto reject/auto return switch setting has been shifted.It needs to be readjusted possibly at a specialist repair shop.It's the small lever that trips when the pick up reaches the correct end of the record run out grooves.
Jul 13, 2014 | Denon DP-29F Analog Turntable
How can I stop the tone arm from returning too early on smaller records?
The adjustment for auto return position is normally at the tone arm base on the left side under a rubber grommet. Use a flat blade screw driver to move adjustment screw, then test. Keep fine tuning until arm lifts at desired position. Cheers John. Stylus City NZ
Jun 14, 2014 | Crosley 0187SST Turntable
Jvc service center
If it does this when playing a 12 inch record then it could be that the device has been set to play a 7 inch record. The skating across is either a worn stylus, wrong skate setting (if it has one) or not enough stylus pressure. To correct the pressure one. Make tiny adjustments to the weight on the end of the arm. Each time you need to test by playing a record. If it sits in the groove and doesn't skate, plus doesn't make a rumble sound, you have the pressure right. Too much pressure causes it to rumble, too little and it will leave the groove. If the weight is numbered try it at 3, then take it up to 4 + in small steps, testing it each time you move up. It's a case of trial and error to get it right.
Dec 29, 2017 | Audio Players & Recorders
After an album side is finished, my Thorens TD 185 turntable disc refuses to stop spinning.
Some turntables do not return the arm to the rest. However if it did so previous then something could have broken or become out of place underneath the turntable. The only way to check is look under the turntable by removing the base and looking for signs of damage.
Aug 19, 2013 | Thorens TD 185 Turntable
Tone arm on technics Sl-BD22 lifts before the end of an album
the anti-skate is set wrong, this stops the arm skatting on to the label in the middle of the record & destroying your stylus tip.
Mar 03, 2013 | Technics SL-BD22 Turntable
Tone arm keeps returning to rest on Crosley CR249
Hi, Try this. with it turned off. Lift tone arm across a record to the run out groove and set it down. Now power up and hopefully it will reset itself. In all honesty I would sell it and get a decent old school player. John. Styluscity.com
Nov 09, 2011 | Crosley 0187SST Turntable
Aiwa turntable px-e860: Hi, I've inherited this timetable from a friend and it's worked fine until recently but now here's the problem: if I push start, the arm lifts up, moves to the record...
Hi, I;m not familiar with that exact model however the problem you are describing is commonly caused by the automatic operation at some point not being allowed to complete its full operation. Ie the tonearm has been returned manually to its rest position before reaching the end of the record. Try this. With the player not powered up lift the tonearm across to the record run off groove and sit it there. You may feel some resistance which is normal as the mech has to eswt itself. Now turn on the power and turntable. The arm should automatically return from there to its rest. Try auto operation after that. Let me know how you go. Cheers John. styluscity@gmail.com
Oct 10, 2011 | Aiwa PX-E860 Turntable
I have an old Califone 1400 all records skip new needle
There's not enough pressure to keep the stylus down in the grooves. Increase the weight (on the end of the arm).
Feb 10, 2010 | Audio Players & Recorders
173 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
