Question about Acer TravelMate 4200 Notebook
I forgot the administrator password kindly tell me how to recover and change it
  • evilgeniusha Mar 12, 2011
    What operating system is your computer running? It is most likely Windows XP, Vista, or Seven
If you lost windows password, you can go into safe mode (F8 when booting up) to recover windows password while you forgot user account password,but if you forgot administrator password,there is no way to...
As far as I know , there are two main methods to solve the windows password problem as follows:
1st Method:
Start system and when you see Windows Welcome screen / Login screen, press ctrl+alt+del keys twice and it'll show Classic Login box. Now type \Administrator\ (without quotes) in Username and leave Password field blank. Now press Enter and you should be able to log in Windows.
Now you can reset your account password from \Control Panel - User Accounts\.
Same thing can be done using Safe Mode. In Safe Mode Windows will show this in-built Administrator account in Login screen.
2th Method:
Windows password Recovery software:
for example:Windows Password Recovery Tool 3.0 . It is easy and convenient to use.
http://www.windowspasswordsrecovery.com
Aug 19, 2011 | Microsoft Windows Vista Home Premium...
Forgot password
You can reset a lost or forgot Windows password with 4 methods below:
1. Another valid administrator account which can normally log on.
2. A password reset disk or a repair disc, which is created in advance ( before you lost password ).
3. Third-party software to create a bootable password reset CD/DVD or USB, like Windows Password Breaker.
4. Re-install. Will lose data.
Feb 14, 2011 | Lenovo ThinkPad X200 Notebook
Forgot password i cannot get in from the point where I am asked for the password
I suggest you try hard to remember your password! If you really can not reset your windows administrator password, I recommend Windows Password Seeker, passwordseeker.com
I had removed Windows password with the tool successfully on my computer. Hope it helps! You simply do as follows:
Step1, download Windows Password Seeker.
Step2. Remove your Windows Password with the tool.
If having some questions, you can read carefully at: http://www.passwordseeker.com/howtouse.html
Mar 06, 2010 | Compaq Armada M700 Notebook
How do I reset administrator password
click start
control panel
switch to classic view
click user accounts
then click computer administrator
change password
Feb 12, 2010 | Toshiba Satellite A100-S8111TD Notebook
I forgot my password on my computer
I know a windows password recovery tool called windows password buster. This software could help you recover the password.
Nov 28, 2009 | HP Computers & Internet
Can't get pass windows login forgot password for os how do i get in
I know a windows password recovery tool called Windows Password Buster. This software can help you reset the password.
Nov 04, 2009 | Microsoft Windows XP Professional for PC
Forgot password and unable to do anything now
If you forgot the windows login password and want to recover or reset windows password, there is two methods to reset windows login password:
Methods 1: Use the password reset disk to recover the Windows password, by this methods, you need create a Windows password reset disk before you have lost or forgotten your Windows admin password.
Method 2: Using Windows Password Recovery software to recover Windows password
As an easy method to recover the forgotten Windows password, there are only four steps as follow:
Step1: Download Anmosoft Windows Password Reset V8.0( http://www.resetwindowspassword.com
)and install it.
Step2: Burn the ISO image file onto a blank CD/DVD or USB.
Step3: Boot up your Windows PC by the bootable burned CD/DVD or USB in minutes.
Step4: Remove the forgotten Windows password on the operation interface and logon PC without password.
Apr 17, 2009 | Computers & Internet
Logon password
You can use a program like Windows Password Recovery Tool to get the admin password. It is a live cd easy to use.
When you load it in graphical mode select the windows installition and then select the user you want to reset password.
(make sure you boot from cd/dvd or usb first)
Apr 08, 2009 | Microsoft Windows XP Home Edition
Password
there is a linux based tool, which can help to change the administrator password by changing the sam database. You have to arrange the tool.
Mar 04, 2008 | Computers & Internet
Acer TravelMate 4200 Notebook Logo
29 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
