Question about Refrigerators
I have a problem with my Euroart WD50SS-1 as it works fine for a few days then suddenly both temp gauges on the front keep flashing HI and then stops keeping my wine cold ready to be drunk I checked the manuals that came with it but nothing in the manual tells me what to do.
catriver
  • 878 Answers
SOURCE: fridge not staying cold
Solo, firt make sure you do not have a build up of frost on the freezer inside panel. This would indicate a defrost problem. Your post states that the cooling problem is intermitant which leads me to believe that the automatic damper is at fault. It could have a build up of ice on it which is causing it to bind, or it could just be going bad. Your model does have the manual defrost timer which could be sticking at times, that is why I suggest checking the back freezer panel for frost buildup. Catriver..post back.
Posted on Dec 01, 2006
bobotfel
  • 236 Answers
SOURCE: Wine cooler gets too cold (freezes)
Check your thermostat setting, if the setting is ok then something wrong with your thermostat control.
Posted on Jan 21, 2008
SOURCE: fridge wont get cold and freezer gets cold then gets warm
I Had The Same Problem , Went To partselect.com  You Will Find A Solution And Reasonable Priced Repair Parts There
Posted on Apr 18, 2008
skotkolr
  • 558 Answers
SOURCE: Fridge and Freezer losing cooling
thermostat control to deice the freezer is malfunctioning need a service tech to replace it so it doesn't keep the deicer on . Its exactly that, a warmer to deice the coils.
Posted on May 27, 2008
SOURCE: Haier Wine Refrig runs to cold
change your temperature sensor, it's broken and it's going to down temperature
Posted on Sep 03, 2008
2014 Gilera Runner ST 125 temperature gauge keeps flashing
Hi, Anonymous and the usual suspects are:
1. Grounded temperature light/gauge circuit.
2. Faulty thermostat temperature sensor.
3. Faulty cylinder head heat sensor.
4. Faulty thermostat.
5. Faulty light or gauge.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
http://www.apriliaforum.com/forums/showthread.php?277723-warning-light-coming-on-and-temp-guage-icon-flashing
gilera runner over heating problems
Gilera Runner 50 1997 Service And Repair Manual
Gilera RUNNER VX VXR 125 200 125 2003 Parts
http://www.bellamoto.rs/upl/files/Runner%20ST%20125%20-%20200%20UPUTSTVO.pdf free owners manual
Feb 18, 2018 | 2011 Gilera Runner ST 125
'05 Grand Am 3.4 V6 Temp Gauge not Working all of a sudden.
Sounds like a temp sensor or wiring problem.
You may only have one sensor for both the gauge and the engine computer.
If the computer temp sensor fails, or is not sending a signal to the engine computer, the fans will run as a precaution to keep the engine from overheating.
If you have replaced the correct sensor, it could be a wiring problem, or the engine coolant could be low enough to not touch the sensor.
If the coolant sensor is not sending a signal, the check engine light should also be on.
Apr 07, 2015 | Cars & Trucks
The car was driving fine when suddenly the wind screen started fogging up. The air con was ON auto and temp set at about 22 Degs on defrost at the time. So I increased the fan speed to remove the fog. Same...
This is speculation, but the fogged windshield, the noise behind the dash, and the temperature gauge actions lead me to the heater core. When they develop any leak they fog the windshield, and enough fluid loss or an air pocket could explain the temp gauge readings.
Oct 16, 2013 | Cars & Trucks
2006 f150- temperature gauge stays cold but "check gauges" flashes in mini message center.
Since the temp gauge is not working correctly, you get the warning message.
Could be a faulty temp sensor or a problem in the wiring harness.
Apr 08, 2013 | 2006 Ford F-150
Temp gauage not working chevy S10 1998
In the early 1990s there were two sensors, one for the gauge and one for the computer. If your engine only has one, it sends a signal to the computer and then to the gauge on the dash. If the sensor is working, the gauge on the dash may be faulty.
The sensor will not work correctly if the cooling system is low on fluid.
Dec 10, 2012 | Cars & Trucks
I have a ford 2001 windstar. the other day the temp gauge went close to High. After an hour of sitting while we went shopping. It didn't move from normal on the way home. we added 1-1/2 gallons of water...
If you absolutely need to drive the van without having it serviced ensure your coolant/water is topped off prior to setting out. Make sure you have LOTS of water on hand to top it off if needed and keep a very close eye on your temperature gauge. You should also stop every few hours even if the temperature gauge stays in the "normal" range to ensure its operating at the correct temperature. There could be a few things wrong with the van, but damage to the radiator or cracked hoses could be likely culprits.
That being said I wouldn't recommend any long trips before having this issue fixed.
Sep 28, 2010 | 2001 Ford Windstar
Fuel gauge, temp gauge, and auto door locks stopped working while in transit. checked obvious fuses, found no problems. did not check all fuses. Ideas
I had a similar problem with a 2001 Saturn. We checked every fuse and they were all fine. We finally did a 'reset' on the car's computer by disconnecting the battery and reconnecting it a few minutes later. Everything was back to normal after that.
May 27, 2009 | 2002 Chevrolet Malibu
Samsung side by side srs580dw stops freezing and chilling
Since the temps on the display don't show correctly I'd assume something is wrong with that. If the temps are sending info out that the unit is OK and at proper temp (when it's not) then the compressor won't turn on because it thinks the fridge is cold enough. Soooo... I'd suspect that control board. It's item 48 on this diagram http://www.partselect.com/Schematics/Maytag/SS10-2.gif
Jan 13, 2007 | Samsung RS2630WW Side by Side Refrigerator
Refrigerators Logo
75 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
