Question about Maytag Dryers
MGD5740TQo - were to buy and how to replace electric igniter
    Problem Solver:
  • 11 Answers
Any appliance parts store, or better yet! Call an appliance repair guy! He will have the parts already
Posted on Mar 12, 2011
Key is stuck in ignition receiving no electricity
You are not the only one:
Key stuck in ignition, wont start, dodge ram pickup - Fixya
www.fixya.com/.../t14560159-key_stuck_in_ignition_wont_start_dodge
Oct 6, 2012 - key stuck in ignition, wont start, dodge ram pickup - Dodge Ram 1500question. ... 631 Answers. SOURCE: 1999 Dodge Ram 1500 Pickup error code p0171. This code means ... Jun 28, 2011 ' 1987 Dodge Ram 50 · 1 Answer .
Aug 23, 2015 | 2011 Dodge Ram Pickup 1500
Electrical engine noise through my stereo of 1994 chevy full size truck
you will probably have to install a ground loop isolator you can find them at best buy or any car audio dealer
Sep 25, 2012 | 1995-1997 Chevy 1500 Truck Ignition...
Maytag Peforma Series MGD5740TQO Runs - does not heat Cleaned all lint from dryer and hoses
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 16, 2011 | Dryers
Hi - I've replaced the thermostat. Furnace runs then shuts off before reaching temperature. Winter in Wisconsin is cold! We now think it's the 1018 series hot surafce ignition control box , but...
When you replaced the stat, did you set it for gas or electric heat?? makes a differance!!
If your heat is starting, the ignition box is doing its job.
Jun 25, 2011 | Heating & Cooling
Remove ignition lock to switch link 1995 suburban
The ignition lock assembly contains two components: a lock cylinder to deter theft and an electrical portion that supplies power to electrical components such as the radio, electric windows, and windshield wipers. The electrical portion of the ignition switch also provides power to the starter motor to start the engine.
The ignition lock is an anti-theft device that prevents a vehicle from being driven unless the ignition key is in the ignition switch. If the ignition key is not in the ignition switch, it 's impossible to turn the steering wheel.
To replace the ignition switch cylinder lock, the trim panels around the steering wheel are removed. Then the tamper-proof hardware that attaches the ignition lock assembly to the steering column is removed. The ignition lock assembly is removed from the steering column, and the lock cylinder is replaced. The new ignition lock is reattached to the steering column, and the trim panels are replaced.make sure you dissconect battery first the 1997 had a recall on the ignition switch dont no if the 1995 had a recall if so they will replace for free
Dec 08, 2010 | 1995 GMC Suburban
Neptune 5500 gas dryer runs but no heat. I cleaned out the exhaust ducts already.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Nov 04, 2010 | Maytag Neptune MDE5500AY Electric Dryer
My ignition switch is quit and i dont have money to buy another one how can i bypass it and make bike run. is there a place i can download a repair manual free
Assuming the problem electrical. Take the switch assembly off the bike , put the key in and turn to the ON position, push the three tabs on the contact base and remove it. Now the electric base of the switch can be taken out and cleaned or replaced. If the key tumblers are damaged you will need to buy a complete switch assembly.
Sep 24, 2010 | 1984 Honda VF 1100 C
Tailights, Marker lights, Flashers and dashlights
ignition switch may be bad not cutting electricity to car when shut off. the way the ignition switch works, is that when car is shut off, there should be no electricity going through it. if in doubt or ya need help, go to any auto parts store and buy a haynes manual, they are based on a complete teardown of car for about 20.00, make sure you buy one for your make and model and year vehicle.also check main ignition fuse in fuse box.
Dec 22, 2009 | 1999 Plymouth Voyager
How to replace spark igniter - Jenn-Air SEG196 gas-electric range
took off the knob to the ignition system to clean and spray got onto the ignition under the dial and now the two front burners won't ignite unless I turn on one of the functional back burners then turn on the front burner. How do I repair this?
Jan 22, 2009 | Jenn-Air JGR8850 Gas Kitchen Range
1977 ford short
I mean the ignition switch and lock barrel, the one where you put the key inside. Buy the Haynes manual and check 'finding a short circuit' and 'Removal - ignition switch and lock barrel' under 'body electrical system. In the manual it will show step by step with pictures what to do.
Regards
Jun 01, 2008 | 1981 Ford F 150
Dryers Logo
65 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
