Question about LG Washing Machines
Wm22077cw,drain pomp problem. - LG Washing Machines
  • LG Master
  • 17,130 Answers
Location of the drain pump is at the drain outlet,. With the set of tools and your expertise , remove the drain pump, clean and back-flush all the dirt. if possible test from the outside, if not refit the pump and test.
Posted on Mar 12, 2011
My washer is maintaining water and continues to run after the cycle is complete?
You have problem with pomp or swich put pomp to work .Replays pomp or switch.
Dec 12, 2016 | Washing Machines
I need to remove the oil pomp on a 1.2 el fiat polio
drain engine sump and remove sump pan ,before changing pump check oil pump pick up not blocked
Jan 13, 2014 | Cars & Trucks
LG intello front load washing machine not starting Select cycle as always and press start nothing then it beeps and flashes all lights
check filter and drain pomp...if ok check motor brushes .. bsc appliances 07779933829 postal service too.
Feb 26, 2011 | Washing Machines
Wont drain for spin cycle
in the previous statement i meant to say,if its plugged and cant drain then it wont advance to the spin cycle
Oct 16, 2010 | LG WM0642H Front Load
Hello! Our Bosch-Siemens clothes washing machine SIWAMAT 2105 has the following problem: When it want to eliminate water, the water pomp doesn't work(we hear just some noises). We already manually...
Make sure you use high efficiency detergent.  The front load machines take a special kind of detergent to make them run smoothly.  Check your drain hose for clogs, and clean the pump again.  If none of these fix the problem, you will probably need to replace the pump.
Nov 07, 2009 | Siemens WIQ1633 Front Load Washer
WHIRLPOOL DISHWASHER FILLS @ FIRST WASH CYCLE BUT WILL NOT DRAIN
CK THE POMP OR THE DISPOSER WERE THE DISWAHER DRAINS IN TO FOR BLOCKIG
Jul 16, 2009 | Dishwashers
Washing Machines Logo
48 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
